Project Hand Banana
Discussion in 'Some Assembly Required' started by madrider5150, Nov 7, 2016.
  1. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    17,282
    Orange County, CA
    EDM is basically freakin lasers man
    #81
    madrider5150 likes this.
  2. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,462
    PNW
    Electrical discharge machining, interesting, Ive only known that acronym for terrible music
    #82
    villageidiot likes this.
  3. villageidiot
    Apr 29, 2010
    17,282
    Orange County, CA
    I got a guy. If you don’t wanna fuck it up, or can’t get it out, let me know, he’ll turn it out in a day. You can ship to me and I’ll take it there, and pick it up. Or you can probably ship directly to him, just not sure if he does shipping or not.
    #83
  4. madrider5150
    Oct 15, 2013
    1,462
    PNW
    I appreciate that, dont suppose you know a ball park figure for that? At this point Im considering upgrading the heads to 04+ or buell XB or sending mine to hammer for lmpact service. Just depends how much Ill spend to get these heads working properly again. I used to have a buell thunderbolt that put out 90-100 hp, damn was that thing fun! Some upgraded heads should get me close I think.
    #84
  5. villageidiot
    Apr 29, 2010
    17,282
    Orange County, CA
    It’s usually about $40-60 a hole.
    As for having the heads done. If you did the basic 1250 swap, doing the head work usually requires different pistons, so call hammer on that to make sure you’re not throwing good money after bad etc
    #85
  6. madrider5150
    Oct 15, 2013
    1,462
    PNW
    That's pretty reasonable.
    Hammer site said about the 04+ heads could be used with flat top pistons, just lower compression or something but I'd make sure. This has been a very expensive learning experience haha
    #86
  7. villageidiot
    Apr 29, 2010
    17,282
    Orange County, CA
    The best learning experiences are the most expensive
    #87
    sperz1 and madrider5150 like this.
  8. fast1075
    fast1075 Not a Lemming
    Dec 28, 2013
    2,007
    Flaw'da
    If you are going the Buell route, change the whole top end. Don't forget that half the magic is the cams.
    #88
  9. madrider5150
    Oct 15, 2013
    1,462
    PNW
    I think that'll wait for another time. Im going to see how well the bike does with my suspension mods before I stick that much more in for new heads and cams. I defaulted to an expert and was able to get the bolt removed and helicoiled for about $50, really shouldnt have tried to drill it anyway, I suck at tedious tasks like that. I am glad I removed the head myself though, feel like I learned a decent bit about my engine.
    #89
    AK650 and villageidiot like this.
  10. madrider5150
    Oct 15, 2013
    1,462
    PNW
    Im also having the head cleaned up again, bead blasted, guides checked and new seals in, might as well since its removed.
    #90
  11. fast1075
    Dec 28, 2013
    2,007
    Flaw'da
    Glad you got it fixed. A lot of them end up as scrap metal.
    #91
  12. madrider5150
    Oct 15, 2013
    1,462
    PNW
    20190222_174749.jpg 15509008802676534675562837344577.jpg 15509009268255028461367048641402.jpg 15509009268255028461367048641402.jpg
    Got my head back, stud fixed and all cleaned up, installed now. Billet pushrod bases to be installed next
    #92
  13. madrider5150
    Oct 15, 2013
    1,462
    PNW
    I'm not sure if I red loctite that exhaust stud in or not..
    #93
  14. madrider5150
    Oct 15, 2013
    1,462
    PNW
    Then gotta celebrate the little successes 15509013458925734913898718740464.jpg
    #94
    AK650 likes this.
  15. villageidiot
    Apr 29, 2010
    17,282
    Orange County, CA
    I think loc-tite there won’t matter, the heat breaks it down.
    Did anything get done to the valves etc? Or just the stud repair?
    If any valve work, you concerned with the rear head?
    #95
    AK650 and madrider5150 like this.
  16. madrider5150
    Oct 15, 2013
    1,462
    PNW
    Ive only put around 1k miles on since the heads were last cleaned up. I had it bead blasted, seats cleaned up, guides checked and new valve seals put in. That really shouldnt make a difference with that minimal amount of mileage should it? I really dont want to pull the rear head but will have to take the rockerboxes off anyway for the pushrod base.
    #96
  17. villageidiot
    Apr 29, 2010
    17,282
    Orange County, CA
    The only thing I’d be skeptical of, is if the seats weren’t sealing or the guides in the front head checked out bad, if the machine shop gave you a basic clean bill of health, id put it back together and run it.
    #97
    AK650, madrider5150 and smolt like this.
  18. madrider5150
    Oct 15, 2013
    1,462
    PNW
    Yeah they said the guides were good and I had them replace the valve seals as precautionary. I had checked the intake valve previously and it was not leaking but looked like it had from the carbon build up and stains on the valve
    #98
  19. madrider5150
    Oct 15, 2013
    1,462
    PNW
    New billet pushrod base installed and you can see the old one one the left and looking closely you can see where my mechanic put gasket maker down to stop a pushrod seal leak :hmmmmm
    #99
    AK650 likes this.
  20. madrider5150
    Oct 15, 2013
    1,462
    PNW
    Well the photos don't show it too much but the color is graphite- kinda metal flake gun metal gray color. I actually bought this when I thought my rear springs would be blue.. not going for played out murdered out look. Oh well, I'll let it cure then hit it with spraymax 2k, I've had good results with it before.
    johnwesley likes this.
