Pushrod seal leak...
Discussion in 'Dakar champion (950/990)' started by tobys, Sep 24, 2009.
  1. tobys
    tobys OCD Hobbiest
    May 11, 2008
    321
    Redmond, WA
    Is this a common leak? Is it as easy as removing the pushrod, removing the seal, and installing the new one?
    I thought my clutch slave had gone, because that is so common. Bought the Evoluzione, and then oops! It's actually engine oil, from around the pushrod.
    Seals are cheap, just making sure I check in first. Thanks!
  2. Speedzter
    Speedzter Been here awhile
    Jan 5, 2004
    736
    Vic' Australia
    I've had the same leak.
    The seal can be tricky to fit square on without the factory tool, so I made up my own seal driver.
    You need to remove the clutch pushrod from the clutch basket side.
  3. el' hefe
    el' hefe Been here awhile
    Dec 5, 2008
    313
    Seattle, Wa
  4. cjracer
    cjracer AWD please!!
    Sep 26, 2005
    4,050
    Mukwonago, WI
    Mine started leaking at about 40,000. I used a hooked spring puller to get the seal out. I used a socket to push the seal in. Fixed and leak free now.
  5. Terlingua
    Terlingua Terlingua
    Oct 1, 2005
    252
    Port lavaca Texas
    Mine started leaking after I drilled the oil jet out to 1mm. {Witch I got form the up grade reports} I replace it and it leaked too. I had to lead the jet back up and re drill it to .05 mm to make it stop leaking. But I have all so stiffed my oil pump spring to for a little more oil psi. Help keep the cam chain form rattling as much.
    BCK
  6. tobys
    tobys OCD Hobbiest
    May 11, 2008
    321
    Redmond, WA
    I thought about it - but my old pushrod hasn't given me any grief. Is it really worth the $40?
    Thanks!!
  7. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,483
    West of the West, Oregon
    Yes. Replace it. My 'three piece' steel-alum-steel came apart. The one piece all steel will give more room for oil to travel to the clutch. Also, it won't rub inside the shaft and generate alum dust to be fed onto the clutch plates.
    Get a new seal while you are at it.
  8. Scandinavian
    Scandinavian Adventurer
    Nov 12, 2007
    25
    Finland
    I have had the same issue, too. It happened just after the slave cylinder leak, about 30 000 km on odo.
    #8
  9. tobys
    tobys OCD Hobbiest
    May 11, 2008
    321
    Redmond, WA
    Installed the new seal today, a bit tricky getting the old one out, and I didn't wait for a new pushrod, but it could be that a previous owner replaced it. It was one peice.
    Anyway, seal looks like it's working fine, and I'm glad I got a look at the clutch too. The plates look ok, and it's an easy job if I ever need to replace them.
    #9
  10. tobys
    tobys OCD Hobbiest
    May 11, 2008
    321
    Redmond, WA
    took a 30 minute ride, and it looks like a small drip is back. what a pain. I'm using Mobil1 15w50, shouldn't be any thinner than the expensive stuff, right?
    #10
  11. Zuber
    Sep 28, 2004
    6,483
    Apparently, this is a tough fix. I'm heading out to the shop right now to attempt it again.
    Edit - took it apart, again. Pulled off the CS sprocket. Pulled off the slave cyl. Cleaned it really, really good with brake clean. Started it up and the clutch push rod seal was leaking around the OUTSIDE of the seal! WTF? I looked at it under a stong light and the seal was in crooked about 15 deg. There is also a slight cut-out on this seal bore toward the front of the bike, it was leaking from there.
    Cut a length of 5/8 steel tubing and squared it up. This will slip over the end of the push rod. Then drove the seal in square. Now it doesn't leak. I originally drove the seal in with a deep socket and couldn't quite see that it wasn't square. This piece of tubing worked much better. 3/4 dia tubing may fit it better.
    So the moral is: after you install this seal and the push rod. Start it up and let it run for a while to check it out for leaks. Buy two seals, one to practice on and one to get right.
    #11
  12. emerson.biguns
    emerson.biguns All idiot, no savant
    Apr 17, 2007
    11,840
    The Old Pueblo
    I need to do this fix as well on my new (to me) 05.5 950A.
    Can someone confirm that I'm replacing seal:
    SHAFT SEAL RING 9X18X06 B-NBR
    0760091862
    Also, a build date of 04/2005 would not require the updated push rod, correct?
    Thanks,
    John
    #12
  13. tobys
    tobys OCD Hobbiest
    May 11, 2008
    321
    Redmond, WA
    That's what I ordered. 32 0760 091862 WELLENDICHTRING 9X18X06 B-NBR SHAFT SEAL RING 9X1 8X06 B-NBR
    #13
  14. Raggie
    Raggie n00b
    Feb 12, 2011
    1
    Cape Town, South Africa
    I have tried repairing this persisrant leak for a while now and still without success, have replaced pushrod , seal and even used the special tool to drive the seal home properly, also have used a little sealant on the outside of the seal before inserting it, this oil leak is a real pain in the ass to fix... There is also a needle roller bearing behind this seal and was wondering if this could cause the seal to leak if the roller bearing was worn . Anybody got any ideas I can try to fix it?
    #14
