Quezo Blanca - pardon my Spanglish
Discussion in 'Airheads' started by greentreephrog, Jun 16, 2019.
  1. greentreephrog
    greentreephrog Been here awhile
    Aug 29, 2012
    184
    Laguna, Philippines
    The R80g/s - and I presume some other models - has a ring made of some mysterious white substance on each stanchion immediately below the bottom fork brace. It is used to provide a base for the top clamp fixing the gaiters to the stanchion, but deteriorates at an alarming rate, turning to unusable mush. Thus my calling it 'white cheese', for it may as well be made of that!
    I thought of turning some similar items from delrin, a much more stable and rigid material. The idea being to turn the delrin to the same dimensions as a new white ring but with a diametrical gap the allow for compression on to the stanchion.
    Has anyone tried this modification? If so, any comment on what to do or avoid. These things drive me crazy!
  2. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    6,051
    pictures would help.
  3. greentreephrog
    Aug 29, 2012
    184
    Laguna, Philippines
    Oh hell! I though everyone would know what these things were - seems to me like one of BMWs more notable 'misses'. But I suppose delrin wasnt around in 1983.
    I'll see what I can dig up tomorrow morning. I tried to post the Motobins image of BMW part 31 42 1 241 669, but don't know if it will work. If it does, thank you to Motobins! Screenshot_20190616-222344_Firefox.jpg
  4. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    10,977
    Shoreline, WA
    Those are what the gaitors secure to and hold the breather tubes that run through the lower triple clamp. My ‘81 G/S’a Originals are still in great shape.
    I also just put a new pair sources from Motobins in my RS to convert it to gaitors
  5. Morro
    Morro like a ship in the night
    Nov 7, 2008
    487
    Coastal NSW
    Just replace the gaiters with the ones that have the air breather hole/locator already built into the gaiter no need for the white plastic. Examples in pic from Motorworks
  6. Warin
    Warin Retired
    Aug 30, 2012
    8,293
    The G/S ones have each breather through a rubber tube into the headlight bucket - so they might breath less dust/water. So the plastic ring mates with a rolled tube into the lower triple tee, the upper part of this rolled pin gets the rubber tube (ontop of the lower triple tee) and that then goes through a hole into the headlight bucket. IIRC.
    Now if they had just taken the same care with the carby breathers... :baldy Not to mention the gearbox and rear drive... for those that use a G/S, use as in 'off road'.
