"Quiet Flow". Hah!
Discussion in 'The Garage' started by Jonex, Nov 8, 2010.
  1. Jonex
    Jonex Long timer
    Mar 20, 2006
    1,357
    Redmond, Washington
    Just installed a Napa Quiet Flow muffler on my Cherokee. What a joke. It's louder than the rusted out split seamed thing I removed. Is there such a thing as a quiet aftermarket muffler?
  2. s0crates82
    s0crates82 n00b
    Apr 10, 2010
    1
    not really. OEM is as quiet as it gets. you could always hit a junkyard and grab a couple old mufflers off other vehicles and string 'em together. that'd turn down the volume real quick.
  3. ttpete
    ttpete Rectum Non Bustibus
    May 13, 2009
    7,734
    Dearborn, MI
    I just replaced a cat back system on my Ford van. Got it from the local dealer. OEM is stainless, aftermarket is aluminized steel, and I KNOW it won't last ten years, like the original did.
  4. MotorradMike
    MotorradMike MIL-TFD-41
    Aug 17, 2008
    1,416
    Mallorytown Ontario
    Sonex:
    I think you got mismarketed at.
    There are many quiet after market exhaust parts.
    Maybe the 'Flow' should've been a tipoff.
    ttpete:
    You could've bought the OEM part. I'm sure you did some math. Hope it works out.
    I quit doing exhaust work for a while but now my kids have cars and no money so 'I'm back'!
  5. dougfromindy
    dougfromindy I smell premix
    Aug 15, 2008
    3,961
    Indpls, IN Lexington, MI
    It never hurts to call the stealership. Sure you might get a laugh but I have found complete exhaust systems for my Ford truck for under $150 and it went on easy, pull two bolts, new flange gasket and very sweet..it had the hangers welded on as original, job was cake and good for another 100k miles so sometimes you get lucky on oem.
  6. dougfromindy
    Aug 15, 2008
    3,961
    PS- I had repacked my KTM 550 can and stuck the sticker on it "SILENT SPORT" well it sure was as bike was only heard from 2 miles vs 3.5 miles away.
  7. Jonex
    Jonex Long timer
    Mar 20, 2006
    1,357
    Redmond, Washington
    You got that right. Napa claims that their Quiet Flow line provides OEM-like sound levels. What a crock. The chick at the counter even said it would have more baffles than the cheapy ones, hence the big price tag.
    Live and learn I guess.
  8. MODNROD
    MODNROD Pawn of Petty Tyrants
    Feb 20, 2009
    3,060
    single lane highways
    In the past when I needed something quiet, I've used the Walker triple-pass mufflers to good effect. Normally the biggest, longest one I can fit in the space available. They work OK.
    #8
  9. big-t
    big-t Been here awhile
    Oct 11, 2004
    548
    left corner of VA
    Cherokees are usually on the border between loud and quiet,doesn't take much to cross that border. The correct "direct fit" from any good after market Mfg should be very close to the original sound level.
    Check out the application (should be on the net) to see if they sold you the correct muffler.You would be surprised how many mufflers are interchangeable size wise,but the flow and sound characteristics are really bad when used on a different vehicle. Sometimes the part folks get creative....:huh
    Has the converter ever been changed or gutted ? Universal ones are only 1/2 the length of the originals and will make it a lot louder,as will an empty one.
    Check to see if the system is touching the frame anywhere.I see many laying on the crossmember,which seems to amplify the sound.
    Any engine mods ?? They can cause problems.
    Lotsa issues that can cause excessive noise
    Good luck !
    #9
  10. bisbonian
    bisbonian Long timer
    Nov 8, 2007
    1,780
    Tucson, AZ
    If you put it on backwards it's a loudener.:deal
    #10
  11. Inane Cathode
    Inane Cathode Cheated Anion
    Jan 7, 2008
    4,608
    Arvada, CO
    Why didnt you just buy a good used muffler from a salvage yard? It'd be cheaper, work better, and fit better.
    #11
  12. ttpete
    May 13, 2009
    7,734
    Dearborn, MI
    That's what I DID do. It's a one piece system, and I'm keeping the truck until the wheels fall off. I let the dealer hang it because I was getting a new drag link at the same time. After working in the automotive field for 40 years, I'm done. The dealer gets to fix my vehicles from now on.
    #12
  13. concours
    concours WFO for 50 years
    Dec 2, 2008
    9,696
    USA
    This.
    #13
  14. MotorradMike
    Aug 17, 2008
    1,416
    Mallorytown Ontario
    This is the first thing you've posted that I don't agree with.
    Some things, you don't get at a junkyard.
    Shoelaces
    Brake pads
    Mufflers
    Just to name 3. :D
    #14
  15. concours
    Dec 2, 2008
    9,696
    USA
    Bring it back. Get the OEM type system from them.
    #15
