R 1100/1150 GS/RT/RS/R/S throttle body repair kit
Discussion in 'Vendors' started by Dan Cãta, Oct 20, 2010.
  1. sedkek
    sedkek Adventurer
    Sep 30, 2020
    14
    Boston
    @Dan Cãta Is there an easy way to remove the cap from the right TB? I tried hammering it out with a flathead. wont budge. Im about to drill it and pry it out. How do you remove that cap Dan?
  2. Dan Cãta
    Dan Cãta Long timer Supporter
    Jun 5, 2008
    2,345
    Cluj, Romania
    Ask someone to hold the intake for you.
    Using the flat screwdriver in the bike's tool roll, hammer it with small taps from both sides, alternatively. It works every time.
    Dan
  3. sedkek
    sedkek Adventurer
    Sep 30, 2020
    14
    Boston
    @Dan Cãta I got the first bushing out with an m8 with great success. The 2nd one not so much. THe m8 tap stripped. I've been trying to tap a m10x1.25 but it literally wont fit through. How do you do it? Maybe try a screw extractor? I am scared because the edge of the bushing is stripped to 9mm inner diameter. I dont have much left to grab.
  4. Dan Cãta
    Jun 5, 2008
    2,345
    Cluj, Romania
    You can use the m10 tap, the first one in a set of 3, the one with just one line to it. You need tools if you want to do the job.
    Using the tap is the easiest way. I think I also responded on the fb thread :)
    Dan.
  5. sedkek
    sedkek Adventurer
    Sep 30, 2020
    14
    Boston
    Any tips on how to catch the threads with the m10x1.25? It doesn't want to catch the bushing. Can I use a hammer or something?
  6. Dan Cãta
    Jun 5, 2008
    2,345
    Cluj, Romania
    Just screw it in a couple of threads and then hammer it out from the inside...
    Dan.
  7. sedkek
    sedkek Adventurer
    Sep 30, 2020
    14
    Boston
    I think u misunderstand me. I cannot thread the m10 tap in. Is there a trick to it?
  8. Dan Cãta
    Jun 5, 2008
    2,345
    Cluj, Romania
  9. sedkek
    sedkek Adventurer
    Sep 30, 2020
    14
    Boston
    UH AH! So the left one is called a bottoming tap. Ive been trying to use a plug type tap which is the middle one in the picture. So all i need is a bottoming plug m10
  10. Dan Cãta
    Jun 5, 2008
    2,345
    Cluj, Romania
    You'll get it out, soon now :)
    Dan.
  11. pharme
    pharme Been here awhile
    Dec 27, 2006
    652
    Portland
    Hi, I like to know if there's any difference of the rebuild kit between a '95 R1100GS and '03 R1150GS Adv.
  12. Dan Cãta
    Jun 5, 2008
    2,345
    Cluj, Romania
    Yes there is, they use different throttle bodies.
    As a general rule, same part number between bike models, means same part. The two bikes do not use the same parts, so the answer is no.
    Dan.
  13. pharme
    Dec 27, 2006
    652
    Portland
    Thanks Dan.
  14. TripleTigerIII
    TripleTigerIII NW Rider
    Jan 21, 2013
    4
    Seattle WA
    Hi Dan! Do you still sell these throttle body rebuild kits for R1100RS? Lonric62@hotmail.com
    TheInfamousDrBholmes likes this.
  15. TheInfamousDrBholmes
    TheInfamousDrBholmes Long timer
    Mar 19, 2010
    1,925
    Arvilla, WV
  16. Dan Cãta
    Jun 5, 2008
    2,345
    Cluj, Romania
    Sure, will send you an email :)
    Dan.
  17. Zaskar1970
    Zaskar1970 n00b
    Sep 5, 2021
    1
    switzerland
  18. Dan Cãta
    Jun 5, 2008
    2,345
    Cluj, Romania
    Will reply you as well.
    Dan
  19. Makis GR
    Makis GR n00b
    Sep 8, 2021
    1
    GREECE
    Hi Dan.
    I need a throttle body repair kit for BMW R1150GS 2003 L+R.How can i get one or two sets of them?
  20. Dan Cãta
    Jun 5, 2008
    2,345
    Cluj, Romania
    Hi Makis,
    I'll send you a private message regarding details.
    Dan.
