r100gs -91 vibration at 3000-3500 rpm
Discussion in 'Airheads' started by KaaJa, Jun 28, 2016.
  1. KaaJa
    KaaJa Been here awhile
    Apr 11, 2008
    163
    Suomi-Finland-Perkele
    I have very noticeable vibration at 3000-3500 rpm on my gs. It seems to come from engine as it's vibrating at standstill when I rev it to 3000 and on the move when I pull my clutch and keep the revs at 3000. It also starts on engine breaking at 3500 and is at baddest at 3000.
    I've changed wössner 9.5:1 pistons, conrods are balanced and r100r exhaust, its stock otherwise.
    Just checked valve clearance and timing. Timing has something amiss, when I set it at 3500 at Z, then at idle its about middle between OT and S.
    Vibration is feeled strongly through seat and pegs.
    What should I check next? Do I need new beancan?
  2. 190e
    190e Long timer
    Feb 20, 2013
    2,268
    England
    Sounds like the advance mechanism springs are a little weak but you don't need a whole new bean can. Just replace the springs.
    I doubt in any case that an ignition timing error is the source of strong vibration. How is the carb sync ?
  3. Rob Farmer
    Rob Farmer Long timer
    Aug 27, 2002
    7,495
    Vale of Belvoir - Nottinghamshire
    Does it rev out or stop revving under load at around 4k? Worth checking the diaphragms
  4. KaaJa
    Apr 11, 2008
    163
    Carb sync has been checked few thousand km ago and I'm going to check it again tomorrow.
    It revs to redline under load and pulls as it should, I think.
    I'm thinking on switching to Silent Hektik crank ignition, any thoughts on that? Or should I just replace springs on advance mechanism and be happy with that...
  5. 190e
    190e Long timer
    Feb 20, 2013
    2,268
    England
    Crank ignition is a nice thing to have but at a price. And you might spend the money and still have the vibration. If you have it timed right at full advance it's hard to see how the timing is the cause of vibration.
    Bad vibration in a particular rev range is usually a resonant effect so it may be worth checking the engine mount torque settings.
  6. GJUNKY
    GJUNKY Been here awhile
    Jan 28, 2008
    120
    Norcal
    I had a real high buzz vibration at 3k - 4k on my R100GSPD that sync would not adjust out. It turned out to be unequal fuel level in the bowls. I had set the floats to shut off parallel to the casting. When I measured the fuel level it was way off.
    I reset the floats based on measuring the fuel in the bowl and the vibration wen away
    adrenal, Uke and Disston like this.
  7. Disston
    Disston ShadeTreeExpert Supporter
    Aug 31, 2009
    19,057
    Silver Spring, Md
    Doubt it's ignition related. Setting to the Z at high rpm is correct. New springs may help. For the most part they all do that. Probably the best improvement can be had in the carb balance. I like the one about balancing the floats.
  8. One Less Harley
    One Less Harley OH.THAT'S GONNA HURT
    Nov 16, 2006
    6,764
    Bowling Green, Ky
    adjust valves (but In my experience tight valves more likely to effect idle), clean plug since they will be out for valve adj, set idle timing "S" mark and 2,500-3000 at "Z", using a strobe light should point out anything unusual with the ignition, sync carbs at idle and higher RPMs..
    after doing that then it gets more involved.......
    #8
  9. 190e
    190e Long timer
    Feb 20, 2013
    2,268
    England
    I've had the same experience due to floats of unequal weight. Setting floats parallel is a flawed method unless you already know that both floats weigh the same.
    #9
    cjbecker likes this.
  10. KaaJa
    Apr 11, 2008
    163
    -Float levels checked and adjusted, 28mm of fuel in bowl. there was about 0.5mm difference to begin.
    -Timing checked again
    -Carbs sync adjusted, was little off.
    -New caskets between exhaust front pipe and collector, old ones did not tighten enough and were loose.
    -Motor mounting bolts torqued to spec
    -vibe is still there, its worst at engine braking between 3500 and 3000 rpm. Could this be normal? Cruising at 4000-5000 it's absolutely fine. I have to test my buddys stock r100gs and compare.
    #10
  11. Big Bamboo
    Big Bamboo Aircooled & Sunbaked
    Sep 29, 2010
    17,406
    Big Island of Hawaii
    I'd say it's normal to feel some vibration at that low of an rpm. Try keeping the revs closer to 4500-5000 for better engine braking and acceleration, too. Remember; there is an additional 10 HP to be gained between 5-6000rpm...
    #11
  12. Beemerguru
    Beemerguru Beemerguru...G/S guy
    Nov 7, 2006
    2,675
    Redwood City, CA
    You don't happen to have anything knocking in the engine or is it just a vibration? Did this just start or gradually creep up on you? Worse case if do a top end job and replace the rod bearings and check everything part by part. I always balance the pistons rods, and wrist pins on my builds and never have a vibration up or down the range so you have something unusual..maybe
    #12
  13. KaaJa
    Apr 11, 2008
    163
    I don't think its knocking, just vibes. Rod bearings are new. Heads were rebuilt also, new valves and guides. I don't remember it being like this at start, I've driven it about 4000km after the rebuild.
    #13
  14. Peashooter
    Peashooter Older Dog
    Jan 15, 2006
    120
    Milford, Ohio
    My GS was rougher than I thought it should be, and not as smooth as my old one was. Ended up finding the pistons were 2 grams different in weight while doing the top end, and had them balanced. But the biggest improvement was having the entire flywheel, clutch assembly balanced. Now it is pretty damn smooth. Also check your driveshaft. It should feel very smooth when you turn the rear wheel.
    #14
  15. Peashooter
    Jan 15, 2006
    120
    Milford, Ohio
    Do you remember what you set the fuel level at?
    #15
  16. GJUNKY
    Jan 28, 2008
    120
    Norcal
    Another thing to do is a compression test and leak down test to make sure everything is good with the rings and valves.
    #16
  17. KaaJa
    Apr 11, 2008
    163
    Compression and leakdown tests are next thing to do. I'm beginning to think that there is compression difference between cylinders.
    #17
  18. KaaJa
    Apr 11, 2008
    163
    Picture of sparkplugs, right one is looking bad?
    #18
  19. 190e
    190e Long timer
    Feb 20, 2013
    2,268
    England
    Neither plug looks great.
    I think you need to use new plugs to judge the mixture after the carb adjustments.
    #19
  20. KaaJa
    Apr 11, 2008
    163
    compression test results:
    Right:
    Left:
    Didn't get equipment for leakdown test yet.
    #20
