R1100gs hi beam won’t go off
Discussion in 'GS Boxers' started by Yellow Dog, Apr 23, 2019.
  1. Yellow Dog
    Yellow Dog Wanderer Supporter
    Dec 4, 2015
    203
    Milton-freewater, OR
    On my great new 1996 r1100gs, the high beam began to stay on no matter the switch position today on the commute. It’s got PIAA lights tied to the high beam...they switch on and off fine. In the high beam switch position the light works as expected. When I switch to low beam then both filaments are lit and the high beam indicator on the dash stays on too. Does anybody have ideas about what’s going on?
  2. miker325
    miker325 Been here awhile
    Sep 9, 2015
    729
    Sonoma County, CA
    Do your PIAA lights go on automatically when the headlight is switched to high beam and off when the headlight is switched back to low beam, or do you have to activate and deactivate the PIAA lights with a separate switch? IF automatic, do they still go off when you switch the headlight to low beam, even though the high beam stays on?
  3. szurszewski
    szurszewski Long timer
    May 26, 2010
    2,491
    Olympia, WA
    This sounds like a common oilhead switch problem. The left switch cluster gets grimy inside and will do this. You can take it apart and clean it if it’s not too bad, but eventually the heat from the added resistance will melt things - then you need to replace.
    Google oilhead stuck on high beam
    Tenacious B and Yellow Dog like this.
  4. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    29,698
    The Berkeley of Arkansas
    Cleaning the switch might
    Help
    All of the current the head light draws goes thru some small bronze contacts inside that switch
    Changing it out to a relay power feed with the oem switch as a trigger is a good low buck solution
    gonzomup likes this.
  5. Yellow Dog
    Dec 4, 2015
    203
    They’ve got a switch, but go off automatically when I switch to low. I’ll check if they still do.
  6. Yellow Dog
    Dec 4, 2015
    203
    Great! Is there a write up how to do that?
  7. Yellow Dog
    Dec 4, 2015
    203
    So I checked and I can turn the PIAA’s on and off at their switch but they stay on regardless of headlight switch position
  8. miker325
    Sep 9, 2015
    729
    Sonoma County, CA
    Then I’d bet it’s the switch. Shouldn’t be hard to take a part and clean up.
    #8
    Yellow Dog likes this.
  9. mouthfulloflake
    Aug 21, 2008
    29,698
    I can try to give some guidance there YellowDog.
    Give me a nights rest, and let me try and put something coherent together for you brother.
    #9
  10. Yellow Dog
    Dec 4, 2015
    203
    Thanks man...sleep tight
    #10
  11. clange95
    clange95 Adventurer
    Sep 19, 2017
    69
    Gainesville, FL
    Word of warning...be careful taking the switch apart. I was slightly distracted by a pair of Mormon missionaries whilst disassembling the switch and it blew a zillion tiny springs and screws all over my driveway. I couldn't find all of them, so I had to order a whole replacement assembly off of eBay that cost me an arm and a leg.
    #11
  12. pictish ratter
    pictish ratter Been here awhile
    Nov 10, 2012
    200
    Ayr , Scotland
    My R1100GS done that but it was the low setting that stopped working had to jam a piece of cable tie into the switch on the high setting so I had lights n till I got another switch ..the contacts had worn n melted a bit of the plastic switch,bought 2nd hand switch n it's been fine
    #12
  13. nobbylon
    nobbylon Been here awhile
    Aug 13, 2012
    874
    I suspect they are similar internals to the K bikes of early years. Here’s how I fixed one of my K100’s that had burnt out the contact.
    I used a brass screw and made a new contact with a dremel and small drills. Pushed the contact into place and added a little jb weld to keep it tight but in reality if you use the correct diameter screw it’s not needed.
    #13
    norton73 and JimVonBaden like this.
  14. nobbylon
    Aug 13, 2012
    874
    Ps take the switch apart in a large plastic bag as there are springs and ball bearing in there.
    #14
  15. nobbylon
    Aug 13, 2012
    874
  16. Mugwest
    Mugwest .
    Oct 18, 2005
    16,084
    3rd Ring of Buzztopia
    :nod
    BTDT x 2. After the 2nd time (requiring a $brand new$ switch from MAX), i said "Never again!" and did it how the factory should have done it:
    :nod You can certainly homebrew it, but the best $60 you can spend gets you Jim's better-than-factory masterpiece:
    H4 Single Headlight Weatherproof Relay Kit (4th kit down): https://easternbeaver.com/Main/Wiring_Kits/H4_Kits/h4_kits.html
    Bulletproof, install-and-forget perfection on my rig for 5 or 6 years now.
    #16
    gonzomup and mouthfulloflake like this.
  17. Yellow Dog
    Dec 4, 2015
    203
    #17
  18. Yellow Dog
    Dec 4, 2015
    203
    Will do! I think I’m going to go take it apart right now.
    #18
  19. Yellow Dog
    Dec 4, 2015
    203
    #19
  20. Yellow Dog
    Dec 4, 2015
    203
    That’s a solid plan...with the EME switch and the relay I’m looking at 200 and change. I like it.
    #20
