R1150 GSA 2004 Clutch Slave Cylinder replacement- PICs
Discussion in 'GS Boxers' started by acupuncture4u, Jun 7, 2008.
  1. johnjen
    johnjen Now, even more NOW!…
    Nov 28, 2001
    17,020
    Great write up. If the acupuncture4u is OK with this, I'll add this to the HoW after this thread gets quiet.
    JJ
    #21
  2. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
    Not 100%, if it happens again after a total flush, then very likely. Also make sure the line to the slave isn't badly rusted.
    Jim :brow
    #22
  3. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    6,668
    Charlottesville, VA
    Yes. If it's merely dark but not cloudy you could change the fluid and see how it goes, but if it looks muddy you need to replace the slave cylinder. It's a closed system and that mud only comes from one place.
    #23
  4. hogmolly
    hogmolly Dude
    May 28, 2003
    3,245
    McKinney, TX and San Jose, CA
    On a R1200GS class bike, the clutch reservoir holds a dark mineral oil. Dark is normal. On the R1150GS class bike, the clutch uses Dot4 which should be clear.
    #24
  5. acupuncture4u
    acupuncture4u Freedom by knobbies
    Sep 4, 2003
    1,375
    Denver, Colorado
    If it's quiet enough your welcome to add this to the How to section.
    Dustin
    #25
  6. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
    Unfortunately that is not always true. Mine, and many that I am familiar with are a clear fluid.
    Jim :brow
    #26
  7. hogmolly
    hogmolly Dude
    May 28, 2003
    3,245
    I didn't know that. Interesting.
    #27
  8. attila_66
    attila_66 Been here awhile
    Jan 3, 2009
    185
    Izmir, Turkey
    Hello,
    Did anyone tried to repair the old slave cylinder??
    #28
  9. Mr Head
    Mr Head Adventure Hippie Supporter
    Sep 21, 2003
    15,514
    San Clemente, CA
    Very nice write up.
    My slave was replaced at 97,000 miles but the clutch pull has been getting stiffer here of late, so I'm thinking this is that bearing beginning to go tits up.
    Your write up bouys my resolve to attack this sooner rather than out there somewhere on the road...:rofl
    I bought a bleeder nipple to replace that stupid fitting BMW use when they build the bike. That makes bleeding the clutch a one-man operation. My local dealer had the part in-stock.
    #29
  10. strikingviking
    strikingviking Long timer
    Sep 5, 2002
    2,968
    Mazatlán
    I have a similar problem with clutch line fluid disappearing with no sign of external leakage. It appears best to replace the slave unit just to be safe. Since the clutch is not yet slipping and there has not been a significant loss of fluid, while replacing the slave unit, would it be possible to spray brake cleaner onto the clutches and then drill a weep hole for draining whatever has accumulated?
    Glen
    #30
  11. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>
    There's a felt 'collar' on the push rod, p/n 23 21 1 230 440. As well as an amount of empty area between the push rod OD and the input shaft ID. Since there hasn't been much fluid loss, it may have collected around the push rod and collected in the felt. Maybe you can clean the fluid out with cotton batting and rifle cleaning tools, or cotton balls and a coat hanger. Either way, the clutch friction surface isn't in the centrifugal 'sling path' from the end of the input shaft. And another caveat, hydraulic fluid on organic friction components makes them grabbier. At least that's what happened to every drum brake with a blown slave cylinder I've driven. The wheel locks right up.
    - Jim
    <BR>
    #31
  12. strikingviking
    Sep 5, 2002
    2,968
    Mazatlán
    So what causes the clutch to start slipping then? According to posters here and on other threads, brake fluid seeping past worn slave units eventually made their clutches fail.
    #32
  13. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>
    Sorry for the late reply. I thought I already had.
    Clutches can be operated wet, or dry. In lubricating oil, or hydraulic fluid. There are different clutch friction materials, but all can used wet or dry.
    'Modern' materials are sometimes used for clutch friction surfaces. Carbon fiber, Kevlar, etc. But clutches have been operated wet, and dry, long before material science was born. The new materials can also be used wet or dry. Some work a little better dry, others a little better wet.
    Uneven oil distribution can cause uneven clutch wear. Say just a spot or two of a clutch surface gets wet, while the remaining surface stays dry. That area will become a 'high spot'. If a clutch becomes partially wet, the solution is to fully wet it.
    <BR>
    #33
  14. strikingviking
    Sep 5, 2002
    2,968
    Mazatlán
    Thanks again. I just now returned from Mexico and have the part in hand for replacement. Trouble is though, the clutch has started slipping and I sure don't want to have to replace that. I'll try the above cleanup as suggested, install a new slave cylinder and see what happens. Maybe that fluid will boil of the plates and all will be well? Or are they permanently shot? The bike only has 39,000 miles of on-road riding so there shouldn't be much wear.
    #34
  15. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    Added this to the GSpot FAQ, Section 3.
    [TaSK]
    #35
  16. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>
    'Install the slave cylinder and see what happens' seems like the only available path at this point. Without removing the gearbox that is.
    A wet clutch runs in some type of operating fluid. The operating fluid which can be motor oil, ATF, etc., soaks into the clutch and swells the fibers a tiny bit, this is normal. But if you started with a dry disk, and only wet a portion of the friction surface, that makes a high spot. The small high spots carry more of the load.
    I guess if I were stranded in BFE (literally), and had tools but no clutch disk, I'd pull the clutch disk and soak it in clutch fluid. But hey, your the daring adventurer, in that situation I may just wet my pants.
    Here's some wishful thinking. Maybe detritus from the worn out seal packs in behind the slave cylinder piston? Or... The slave cylinder has a throw out bearing built into it, maybe bits and pieces from a nerfed throw out bearing get under the clutch rod cup and won't let the clutch rod retract fully. It's a guess, but it's a hopeful guess.
    <BR>
    #36
  17. maalstroom
    maalstroom Ferret Legger
    Dec 22, 2006
    458
    Laguna Madre
    Recently a friend with an R1150R had his slave cylinder replaced by Hank (formerly of Rhinewest). That is exactly what Hank does in most situations, not the brake cleaner, but the weep hole.
    NEECKB
    #37
  18. strikingviking
    Sep 5, 2002
    2,968
    Mazatlán
    Thanks--two questions:
    1. Where exactly to drill the weep hole?
    2. If draining the excess fluid will the residue boil off while intentionally "riding the clutch?" I have accidentally contaminate brake pads before and then just got on a long steep hill to overheat them and bingo, all fluid boiled off.
    #38
  19. firefighter217
    firefighter217 Beerventurer
    Jul 25, 2008
    141
    Sparkling Couch By the Sea, Corpus Christi, TX
    After reading this thread... It was worth every penny Hank took from me!:bow
    The weep hole is a great idea to prevent further damage (as Hank described as Clutch slippage, Striking V.)... according to Hank that little piece of felt will only buy a little time, but once the slippage is present the problem is a bit more complex. Hopefully your seals aren't toast!
    #39
  20. firefighter217
    Jul 25, 2008
    141
    Call Hank for the exact drill location:
    http://www.motohank.com/BMW%20MC%20Service.html
    I hear he makes "house calls" to Mexico! :lol3
    #40
