R1150 GSA 2004 Clutch Slave Cylinder replacement- PICs
Discussion in 'GS Boxers' started by acupuncture4u, Jun 7, 2008.
  1. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    6,668
    Charlottesville, VA
    It's arguably good practice with brakes, but clutches go full-stroke all the time so it's not really a concern.
    #61
  2. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    Does anyone know if there's a way to get the pictures back for this thread? That would be very helpful. :thumb
    #62
  3. Ravenslair
    Ravenslair Been here awhile
    Feb 29, 2012
    540
    Placer County, California
    Archive.org does not have them cached. Maybe the OP still has them locally. I would be happy to host them if they do. The OP's Smugmug page is no longer active either. I sent an email and message to the OP to inquire.
    #63
  4. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    I just sent him a PM and offered to host them myself if he still has them. He was last on in June, so hopefully he is still around and has them.
    **fingers crossed**
    #64
  5. Ravenslair
    Feb 29, 2012
    540
    He no longer has them and suggested I contact Smugmug. Looks like they are gone for good at this point.
    #65
  6. Scott_PDX
    Scott_PDX Leisure Engineer
    Oct 18, 2010
    6,939
    Portland...the newer one on the left side.
    Bummer. I could use these pictures.
    #66
  7. sykospain
    sykospain Been here awhile Supporter
    Jul 18, 2014
    153
    south-eastern Med coast of Spain
    Just found your instructions list posted last year on how to replace the slave cylinder.
    This Autumn I'm planning to install a hub spacer on my 2004 Rockster's friction plate - Esmir's sourcing some more at last - and also do the same job on the 2004 GS of my pal Mo in Spain.
    Your slave cylinder instructions will be most welcome when we set-to, but unfortunately the pictures that you posted with the how-to list seem to be not there...they'd be a great help too.
    Regards in anticipation,
    ALAN in s.e. Spain
    #67
  8. KnuckleDown
    KnuckleDown Been here awhile
    Feb 26, 2014
    412
    Far Side of Crazy
    Gents
    I'm a noob to the BMW. Would like to change out the clutch line and clutch slave cylinder on an 01 R1150GS. I have reviewed the slave cylinder directions on the post about doing this on the 04 R1150GS but do not see any guidance on removing the clutch hydraulic line. With the exception of the last post. Any pictures out there of this action?
    #68
  9. Dan Cãta
    Dan Cãta Long timer Supporter
    Jun 5, 2008
    2,285
    Cluj, Romania
    It is pretty straight forward once you get the slave pump out and you also have the tank off the bike.
    Always use new copper washers where needed. Do not even think about reusing the old ones, you will have to work on the bike again. Tighten the screws at correct Nm rating, as in the manual.
    Dan.
    #69
  10. KnuckleDown
    Feb 26, 2014
    412
    Far Side of Crazy
    Dan-
    Thanks, do I have to remove the rear suspenson and fuse box or can I just pull the rear brake and wheel to accomplish this? How do I fish the new clutch line up from the slave cylinder back to the master cylinder?
    #70
  11. NoiZboy
    NoiZboy Dirt to Track and Back Again
    Dec 24, 2012
    600
    Northern, VA
    I just did this on my bike back in July.
    I don't think you HAVE to remove the rear suspension, but I was also doing a spline lube and so removed the suspension anyway to pull the transmission off. I'm sure having the suspension out of the way made the clutch slave easier to access. I think at the very least you'll need to get it off the swingarm and push it back.
    But if you're also changing the line, I suspect you'll have to tilt the rear frame up anyway, at least a little bit, to get the air box sufficiently out of the way to install the new line (see below). You have to release the rear suspension from the swingarm to tilt the frame up, at which point it's just one more bolt to remove it completely and have it out of the way.
    The fuse box doesn't really "remove" with the way the wiring harness is laid out. It's meant to lift up when you tilt the rear frame.
    The clutch line itself runs along the left-hand side of the frame, and then passes across the top of the transmission, just under the air box, to get over to the clutch slave. In order to access the line's pathway from the bars, you need only remove the tank and air intake snorkel. To get the line between the air box and transmission and to torque the banjo bolts at the clutch slave, however, I think you're going to have to disconnect the air box from the frame and throttle bodies and get the frame tilted up at least far enough so that you can move the air box upward. That will make some room to move the line into position and wrench it down properly.
    That said I had the rear frame tilted all the way up and the air box completely out for other reasons, so others will have to confirm whether/to what degree tilting up the frame is strictly necessary.
    #71
  12. KnuckleDown
    Feb 26, 2014
    412
    Far Side of Crazy
    Gents, I have the dreaded slave cylinder issue on the 01 R1150GS I just purchased. I have removed the slave cylinder following the instructions in this post (removing rear wheel, rear shock, gas tank, exhaust and air intake). I'm ready to install the new slave cylinder and hydraulic line have some questions: how do I fish the new hydraulic line between the air box and the transmission; what is the best way to clean the spot where the old slave cylinder was; can the old slave cylinder be rebuilt for a spare; and what is the best technique to modify a weep hole into the new slave cylinder or slave cylinder gasket to prevent this from occurring again in the future - preferably something that doesent let water into the system.
    #72
  13. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,538
    Va
    #73
  14. KnuckleDown
    Feb 26, 2014
    412
    Far Side of Crazy
    Ended up buying a brand new slave cylinder. When I removed the old one there was no felt in there that I could find. From what I read on adv rider, there is supposed to be a felt thing that wraps around the push rod to soak up hydraulic fluid if it leaks. One came with the new slave but I can't see how it fits it there. Any suggestions?
    #74
  15. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,398
    london, England
    Not all clutch pushrods are the same, they changed the design.
    Some have an indent for the felt, some don't. And the felt doesn't stop any of the gearbox oil/clutch fluid if the rear seal leaks.
    And from my experience it's the gearbox oil that is most likely to leak onto the clutch.
    #75
  16. KnuckleDown
    Feb 26, 2014
    412
    Far Side of Crazy
    Steptoe, thanks. Mile looks like the one pictured in earlier in this post. I just talked to the the local shop and they told me to pull the rod and see if it was machined for the felt. I can't seem to get the rod out. Should it easily pull out or do I have to remove the back of the gear box to get it out?
    #76
  17. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,538
    Va
    The slave cyl is the only thing that holds the rod in.Felt will only have a tiny bit of resistance,if any while removing rod.
    #77
  18. AntonLargiader
    Aug 28, 2003
    6,668
    Charlottesville, VA
    Usually the pushrod is very stuck to the clutch spring (in front). You may need to pull on it pretty hard.
    #78
  19. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    I've seen where the clutch rod has a lip worn into it from the ID of the input shaft. I'm talking about the clutch end of the rod, not the slave cylinder end. The lip gets worn into the clutch rod as a result of input shaft bearing failure. If the rod has a lip worn into it, then the lip catches on the ID of the input shaft, and it will need more than a little persuasion to remove the rod.
    <BR>
    #79
  20. legasea
    legasea Ape on wheels
    Dec 16, 2010
    183
    Hanging on in a garden by the sea
    #80
