R1150 GSA 2004 Clutch Slave Cylinder replacement- PICs
Discussion in 'GS Boxers' started by acupuncture4u, Jun 7, 2008.
  1. legasea
    legasea Ape on wheels
    Dec 16, 2010
    183
    Hanging on in a garden by the sea
    Have a "pdf" of the original page where the photos would be contextualized. Just can't put it here.
    If there's way, let me know.
    #81
    g r a n t likes this.
  2. tallbaldrider
    tallbaldrider still a n00b Supporter
    Oct 28, 2014
    465
    Northern VA
    #82
  3. tallbaldrider
    Oct 28, 2014
    465
    Northern VA
    Was able to look at the intake valves as well.
    #83
  4. JimVonBaden
    Feb 11, 2005
    90,902
    Alexandria, VA
    When you replaced the last one did you replace the line as well?
    #84
  5. tallbaldrider
    Oct 28, 2014
    465
    Northern VA
    Yes I did Jim. I also made sure to pack the unit full of grease prior to install.
    #85
  6. JimVonBaden
    Feb 11, 2005
    90,902
    Alexandria, VA
    You may have a bad master then. Something is contaminating your slave. Try flushing the master with a pint of fluid before changing the slave again.
    #86
  7. K12Pilot
    K12Pilot Without a Care
    Feb 12, 2009
    351
    The Rotten Apple
    Great thread, I wish I saw this 3 months ago. A couple nice tidbits & tricks in here. I got through it just fine for my first time )))
    #87
    Billy Budd likes this.
  8. sykospain
    sykospain Been here awhile Supporter
    Jul 18, 2014
    153
    south-eastern Med coast of Spain
    Such a great pity that all those fotos taken by acupuncture disappeared into nowhere years ago. In this era of unlimited storage-capacity servers, these various picture-hosting firms have a lot to answer for....
    One question, six years after the start of this amazing thread :-
    ¿ Might it be possible to remove the crossbar that obstructs access to the slave cylinder after removal of the rear wheel, silencer ( muffler ) and shock ?
    The crossbar in the foto seems to be held in place on the gearshift pedal side by the bolt holding the pedal assy in place, and on the opposite brake pedal side by two additional hexes facing forwards in addition to the brake pedal assy attachment bolt.
    Surely if that lot is undone, the bar will withdraw or drop ? I notice it has flats machined into the bar at the left-hand side to facilitate holding it still with an open-end wrench to ease disassembly.
    ¿ Steptoe ?
    #88
    rg sw wa. likes this.
  9. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    6,667
    Charlottesville, VA
    The bar withdraws from the right side, so you have to lift the subframe a bit to allow that. That's not hard, but it's a fair amount of work.
    #89
  10. Dan Cãta
    Dan Cãta Long timer Supporter
    Jun 5, 2008
    2,285
    Cluj, Romania
    As I remember, you can get the cylinder out without removing the gearbox bar, use an L shaped allen key to get the 3 bolts out and the pump should come out under the bar.
    So you just need to remove the rear shock.
    Dan.
    #90
    Loutre and rg sw wa. like this.
  11. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    13,462
    :o)
    that is how I did it. you'll need some patience as one of the three bolts is a pita to get out.
    #91
  12. sykospain
    Jul 18, 2014
    153
    Thanks to Anton, Dan and Loutre.
    Incidentally....
    As the seats are off, ready for this awkward-access job, ¿ maybe undoing the three air-box fixing bolts - one at the back top edge and the two pesky hard-to-get-at ones each side above the motor's barrels - maybe also meaning you have to undo the crankcase fumes vent hose - in order to lift up the air-box a little, would give a bit more clearance on top of the slave ?
    Also, I got told a gem of a tip by Steptoe from his garden shed workshop in south-west London, regarding the awkwardness of getting the slave cylinder out into a more accessible position ready to undo the 2 banjo bolts on top of it.
    He says : - Undo the top nut on the left hand fork.
    ( Remember there are no springs in a Telelever fork tube )
    Slide the tube down a bit so you can pass the clutch's braided hydraulic fluid line INBOARD of the fork tube, towards the frame.
    This then will give you enough slack in the previously-tight fluid line, to make fiddling with the cylinder down below a whole lot easier.
    What a great tip ! Many thanks Steptoe ! ( Neil Harrison, www.gsshop.biz )
    AL in s.e. Spain - now with my newly imported UK Rockster all set for registering into the Spanish number plate system.
    #92
  13. g r a n t
    g r a n t Been here awhile
    Feb 5, 2006
    729
    0,0
    This may be too late but I can email you photos and a PDF of the steps I took a few years ago. PM me your email if you like. G
    #93
