R1150RT Gas Mileage, What Matters?
Discussion in 'Road Warriors' started by roger 04 rt, May 8, 2012.
  1. roger 04 rt
    roger 04 rt Long timer
    Nov 9, 2011
    3,436
    Massachusetts
  2. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,290
    The woods and mountains of Alabama
    Nice work.
    What if you adjust the system to a slightly leaner AFR ( Am I correct, 14.7:1 is ideal?), would that improve your mileage without sacrificing engine longevity?
    What about lower viscosity engine oil, reducing parasitic losses, are these improvements that would make sense without sacrificing reliability?
  3. def
    Feb 28, 2004
    14,290
    Roger,
    Given the price of motor fuel, I'm thinking of converting the boxer to a 2-stroke. Would there be any mileage gains therefrom?
  4. twinsig
    twinsig Been here awhile
    Feb 23, 2012
    544
    Middle Alabama
    Whew! today i could use a methane intake-port on the seat! :kboom
  5. twinsig
    Feb 23, 2012
    544
    Middle Alabama
    Seriously, as for fuel mileage Im going to just ride. I have the TBs built & sync done, bike running very nice although its a bit boggy accelerating under load from low rpms, 1st/2nd/3rd mainly & up to 3500 or so. Almost feels like slight fuel starvation on acceleration. Sort-of-like old muscle cars i used to fool with and had holley carbs with wrong pump cam/wrong pump-shot (gas) for "that" engine. Stumbled until tuned correctly.
    Its not real bad, and is less pronounced after the temp is up. Also, i can stop for a meal about 30min and the bog gets a little worse after a quick cool-down, then improves shortly after.
    Thoughts?...... Fuel injectors dirty?........Valves not exact?
    Maybe I can get better educated in Huntsville this month(chicken rally).
  6. twinsig
    Feb 23, 2012
    544
    Middle Alabama
    yep, have done short runs around the block in the nude (the bike) after tweeking, eng cold, scalded dog, bike is stock w/pink.
  7. 4wheeldog
    4wheeldog Long timer
    Apr 11, 2003
    44,100
    7200' NM
    Now you are just getting mean.
  8. def
    Feb 28, 2004
    14,290
    Sorry.
    There was a company that designed direct injected 2-stroke systems that were emissions compliant. It appeared that our 2-stroke outboard engine technology might be salvaged.
    I guess they didn't get any Obama money and so abandoned the design.
    Too bad...I like two strokes.
    #8
  9. roger 04 rt
    Nov 9, 2011
    3,436
    Massachusetts
    I was hoping that someone with more experience than me had access to the BSFC curves for one of the Oilheads. It would tell us a lot about the engine.
    #9
  10. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
    #10
