R1200 Wethead Battery Change for Dummies (pictorial)
Discussion in 'GS Boxers' started by JimVonBaden, Jun 7, 2019.
  1. RidewithAB
    RidewithAB Just Ride! Supporter
    Dec 14, 2013
    418
    Dallas, TX
    Thats what I thought, a good flush in the morning will equalize the weight difference between the AMG and Lithium battery.
    Jim thanks for the detailed instructions.
    #21
    Peltsi and JimVonBaden like this.
  2. Emoto
    Emoto Sure, why not?
    Feb 24, 2004
    21,346
    SE Mass
    Nice pictorial! :thumb
    #22
    JimVonBaden likes this.
  3. wumhenry
    wumhenry Adventurer
    Jan 12, 2018
    92
    Virginia USA
    Yes, thanks for the pictorial. I was wrong; the GS battery is mounted the same as the GSA's.
    #23
    bigjohnsd and JimVonBaden like this.
  4. MotoPhilip
    MotoPhilip n00b
    May 27, 2015
    3
    North Jersey
    #24
  5. MotoPhilip
    MotoPhilip n00b
    May 27, 2015
    3
    North Jersey
    Thank you for the detailed tutorial Jim.
    Today, I stuffed an Odyssey PC535 into my ‘15 GS.
    It wasn’t too bad. I removed the foam base and cut the fins out only where the plastic holding plate is fitted. Otherwise, everything else went back into place.
    I use the Odyssey OMAX Ultimizer 6A to maintain my batteries.
    Cheers!
    #25
  6. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
    Very good to know. I like the Odyssey. Did you take any photos of the trimming?
    #26
    reg26 likes this.
  7. Boxerbreath
    Boxerbreath 2017.5 GS Black Storm
    Feb 7, 2018
    3,766
    Lost Angels County
    Thanks for this JVB.
    #27
    reg26 and JimVonBaden like this.
  8. MotoPhilip
    MotoPhilip n00b
    May 27, 2015
    3
    North Jersey
    Unfortunately, I didn’t.
    #28
  9. KW Guy
    KW Guy Adventurer
    Feb 3, 2016
    22
    Aurora, Colorado
    I just swapped out my battery using this great post. I installed a Deka ETX14, as I have had good luck with them in other bikes. But sure enough, the upper frame grommet for the battery cover was missing when I pulled the cover. Is there anywhere to get these, other than BMW? Thanks.
    #29
  10. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
    They are fairly standard, but I can't say where they can be obtained.
    #30
  11. miker325
    miker325 Long timer
    Sep 9, 2015
    1,013
    Sonoma County, CA
    Try looking at any parts store or automotive repair shop that works with electronics and/or re-wiring, especially a hot rod or custom auto fabrication shop. Look for a similarly sized grommet that would be used to shield wiring going through something like a firewall penetration. Bring the battery cover with you so you can confirm the inner diameter will fit over the piece that goes into the grommet. Then, a rough outer diameter measurement of the mounting tab should be enough to get you where you need to go.
    #31
  12. i386
    i386 Yes, I know it's supposed to rain today.
    Sep 14, 2012
    393
    Georgia
    Im a little late to the party, but I bought mine from Max BMW (parts fische)
    #32
  13. JR356
    JR356 Long timer
    May 4, 2005
    6,973
    Way Northwest
    Good choice on the Deka:thumb,mine is going on two years with zero issues and continues to start the GSA a lot better than the original stock(small)battery ever did.
    JR356
    #33
