R1200GS 07 start issues
Discussion in 'GS Boxers' started by ck-cbass, May 26, 2019.
Tags:
  1. ck-cbass
    ck-cbass Cbass
    Mar 2, 2012
    20
    Smyrna,TN
    Battery voltages:
    Bike off: 12.5V
    During start: 9.9V
    Engine idle (1500rpm) : 14.56V
    I ride a little off-road - and the bike barely want to start. Cranks once or twice and I might get lucky it starts.
    I leave it for 10-15 min and it starts.
    Got a brand new battery and still have this behavior.
    Bike got 30k miles.
    Any ideas what’s wrong here ?
    Starter issues ?
  2. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,518
    DC metro
    Mileage of bike? Starter itself isn't out of question?
  3. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,943
    Villa Maria Sanitarium, Claremont, CA. USA
    Depends on the symptoms. Does it crank and not start or does it not crank strong?
  4. JimVonBaden
    Feb 11, 2005
    91,020
    Alexandria, VA
    9.9 v on load is borderline. But, pull the starter and see if it is all gunked up. Often a clean and lube fixes it.
    Callisto224 and ck-cbass like this.
  5. Chaostrophy
    Chaostrophy Been here awhile
    Oct 24, 2017
    548
    US
    Or a bad ground? What's the voltage on cranking?
  6. JimVonBaden
    Feb 11, 2005
    91,020
    Alexandria, VA
    Not likely a ground.
  7. ck-cbass
    ck-cbass Cbass
    Mar 2, 2012
    20
    Smyrna,TN
    @Chaostrophy
    It’s 9.9V during cranking.
    It does not crank strong and often only have 1 or 2 plus and then dies.
    Fully charged it starts every time.
  8. ck-cbass
    ck-cbass Cbass
    Mar 2, 2012
    20
    Smyrna,TN
    Ok - I will look at this. I will update you. I’m out of town next week but will get to it afterwards.
    #8
  9. JimVonBaden
    Feb 11, 2005
    91,020
    Alexandria, VA
    Sounds like a failing battery since it only tries a couple of times.
    #9
  10. ck-cbass
    ck-cbass Cbass
    Mar 2, 2012
    20
    Smyrna,TN
    I have a brand new battery on, but it could still be bad.
    #10
  11. lewisjr1
    Sep 26, 2008
    5,518
    DC metro
    I'd pull that battery and have it load tested. Alternatively, swap in another, known to be good, battery.
    Keeping an eye on dynamic charging voltage isn't a bad idea, either, but probably overkill.
    Also, any accessories wired into this battery?
    #11
  12. ck-cbass
    ck-cbass Cbass
    Mar 2, 2012
    20
    Smyrna,TN
    30k miles (lots of off-road)
    #12
  13. ck-cbass
    ck-cbass Cbass
    Mar 2, 2012
    20
    Smyrna,TN
    Hey guys,
    Late return for me on this topic.
    I ordered a new starter from EME and the bike is doing great now. I still want to run test on a full day ride, but already feel like it’s happy to start again. IMG_8373.jpg IMG_8374.jpg
    I’ll update when I get back from vaca on the test ride.
    #13
    JimVonBaden likes this.
