R1200GS Adventure Tank Install, v2
Discussion in 'GS Boxers' started by Lobby, Nov 2, 2009.
  1. Lobby
    Lobby Viel Spass, Vato!
    Nov 30, 2003
    30,194
    San Antonio, Tx
    I recently performed the Adventure tank swap on my 2005 R1200GS. There's many wonderful descriptions of how to do this, particularly SQD8R's super thread and Hall of Wisdom submission.
    SQD8R's R12GS with Adv Tank
    Rob's GSA Tank on a GS
    Gros Buck's thread.
    NewEnglander's thread.
    I notice that this topic doesn't come up very much anymore. Perhaps because R1200GS Adventures are fairly common nowadays, and folks who want the large tank just buy the Adventure instead of the GS. But I'm starting to see more and more Adventure tanks, at very good prices too, on eBay and Craigslist. So I thought I'd tweak SQD8R's instructions a bit and fill in a few gaps so ya'll don't have to read through a bunch of threads to find the specific answer you're looking for.
    Here's my starting point. A 2005 R1200GS, with a Russell DayLong seat, standard BMW crash guards (not the GSA versions), and GSA panniers.
    And here's the finished bike.
    Let's get started.
    First the revised Parts List. SQD8R's list is wonderful, but a few part numbers have been superceded, a couple are incorrect (BMW's fault), and I've added a few that were missing.
    Fuel tank ring wrench -<s>161021</s> 83300493639 superceded
    Fuel tank - 16-11-7-676-458
    Side Panel - 46-63-7-694-967
    Side Panel - 46-63-7-694-968
    BMW decal (2) - 51-14-2-291-869
    Bracket – 46-63-7-673-255
    Bracket – 46-63-7-673-256
    Adventure right side cover – 46-63-7-699-717
    Adventure Sucking Pump – 16-11-7-694-106<o:p></o:p>
    Bolt (2) – 06-32-7-651-211
    Gasket – 16-11-7-677-883
    Fuel Filler Gasket - 16-11-7-654-903
    O-Ring - 16-141-183-543
    Screw M5X1 (2) – 06-32-7-651-212
    Screw M5X2 – 06-32-7-657-966
    Rubber Mount (2) – 16-11-7-694-114
    Nut (3) – 46-63-7-658-638
    Note:Bracketed numbers indicate a quantity greater than one (1)
    Additions to Parts List
    Screw - (2) 07-11-990-04-901 (M8x40 countersunk screws for front tank mounts)
    Washer - 16-11-230-9560 (for one of those countersunk screws)
    Body Nut (2) - 61-1313-72-033 (to replace one pair of the Dzus fasteners)
    Screw (2) - 06-327-657-966 (to replace one pair of Dzus fasteners)
    You'll also need some Oetiker clamps for the fuel lines. BMW part numbers are included, but you can get them from McMaster-Carr much cheaper. (or use some other fuel clamps)
    14mm Clamps (2) - 16-121-176-918 for fuel lines
    12mm Clamps (4) - 16-141-183-085 for vent hoses
    Deletions from Parts List
    Screw (2) – <s>07-11-9-905-650</s> The BMW Parts Fiche lists these screws (M8x95) for the front tank mounts, but it's wrong. These are too long.
    Rubber (2) – <s>46-63-7-700-744</s> These are the cushions to prevent the side panels from rubbing on the tank. I can't figure out where to put these. So I didn't. YMMV. :D
    OK. Let's get started. A few pics of the parts we bought and some prices (list. You can get them cheaper.)
    The ring wrench. $82
    The o-ring for the sucking pump. $1.97
    The gasket for top fuel cap (fuel filler). $9.02
    Fuel pump (or perhaps sucking pump) assembly gasket. $6.78
    Side panel brackets. The right is $10.50; left is $7.94 I suppose there's a reason, but I :dunno
    Here's the wrong bolts for the front of the tank. M8, but 95 cm long. Compared to the equivalent bolt for the R12GS.
    Told ya they were too long. :deal
    The correct one:
    The front tank rubber mounting bushing. 2 @ $4.27 Compared to the equivalent one on the R12GS
    The Oetiker fuel line clamps. About $1.50 each from BMW. 25 for $10 from McMaster-Carr. :deal
    Some replacement fuel hose
    Two $%&#@^*** BMW Roundels for the tanks, at $25.18. Oh, these are larger than the ones on the GS side panels, so you can't (practically speaking) reuse them. BMW is sneaky, in addition to greedy. :deal
    The sucking pump (the one for the GSA tank is on top). About $125 :eek1
    The tanks.
    Getting started on the existing tank removal.
    Pic of the "virgin" GS bike.
    I removed the side panels.
    Drained gas from tank, while tank was on the bike.
    Unplugged vent lines and gas return.
    Unplugged electrical connections and fuel pump discharge to throttle bodies.
    I removed tank (and beak)
    With the GS tank (the small one) resting in a plastic container, I started removing the major connections to the tank (gas cap and flange rings).
    In retrospect, I should have left the tank on the bike until I'd removed the gas cap and the fuel pump. Having the tank bolted to the bike give you more leverage when you're removing the gas cap and flange rings. But no matter; proceeding the way I did was ok.
    I removed the fuel pump assembly first. I placed the flange ring removal tool on the ring. It's sorta obvious how it works. You can see how the slots on the tool fit the protrusions on the ring.
    Ring comes off.
    I had to pry the fuel pump assembly off its flange.
    And I pulled the fuel pump assembly out of the tank.
    You can see the gasket hanging in the above pic. This gasket is replaced during reinstallation.
    Removal of the fuel pump assembly can be done independently of removing the gas cap and sucking pump assembly. This is not the case during re-installation; ya gotta go in a certain order; more on this later.
    Next I removed the gas cap.
    And took off the top tank cover. Blue on my bike.
    Then I removed the gas cap internals.
    I used some white tie wraps to make sure I could re-tie the hoses to the correct nipples (what's the correct term?) :scratch
    To remove the Oetiker clamps on those lines, I used a dremel tool to grind them off. Nippers could also have been used to just cut them off.
    I then started on the sucking pump flange assembly. I removed the flange ring, same as on the fuel pump. Then pulled off the assembly.
    Those two hoses off to the right are the same hoses that connected to the fuel cap assembly. One of those hoses has the white tie-wrap attached to it.
    In the above pic, I had already disconnected the sucking pump from the white assembly. Here's a closeup.
    After pulling out the sucking pump, I reconnected it to the assembly, so you could have a pic of it. You can sorta see how it connects, even though the o-ring is showing.
    You can see the sucking pumps for the GSA (top) and the GS (bottom) in the following pic. The GSA pump needs that longer white tubing so it can be placed at the bottom of the right lobe of the tank, to "suck" the fuel into the left lobe, where gas feeds the actual fuel pump to the engine.
    At this point, the GS tank is empty of everything except some minor traces of gasoline. I tipped the tank over and tried to collect as much of the gas into a gas can.
    I then started installing the tank components into the GSA tank. In retrospect, I performed this out of order. I should have started attaching the empty tank onto the bike, checking to make sure I had all the appropriate connectors. Besides, once on the bike, I would have had more leverage to screw on the flange rings (fuel pump, and sucking pump).
    But I didn't. :baldy Onward through the fog. :pynd :D
    1st I installed the fuel pump. After I had it good and tight, I had to take it off. :lol3 There's no way to sure the sucking pump is installed correctly if the fuel pump is in the way. Not only does it block your view, but it interferes with the placement of the sucking pump discharge lines. :baldy :D
    Then I installed the gas cap assembly. I shouldn't have. I needed to install the sucking pump itself first. I left the gas cap assembly in place while I adjusted the sucking pump hoses into position.
    :whew
    :D
    You all following me? :ear
    The correct sequence is:
    - install sucking pump and position it (and its discharge tubing) in the right place in the tank (both right and left lobes)
    - connect sucking pump to the sucking pump assembly and screw assembly into its flange
    - connect gas cap assembly vent tubing to sucking pump
    - install fuel pump assembly and screw it into its flange
    I didn't do it that way, but it ended up ok, after I'd redone it a few times. :D
    After positioning the sucking pump in the tank, I placed the gas cap assembly and routed the gas vent lines through the tank so I could connect them to the sucking pump assemble. Here's a pic showing the hoses sticking out. This is ready for the sucking pump assembly.
    Here's the sucking pump and the vent tubing connected to the assembly. Note I the fuel clamps I used. What can I say? I didn't have the correct Oetiker clamps, so I used what I had. Remember, do as I say, not as I do. :deal :D
    Here's more proof that I didn't have the correct Oetiker clamps. And I was out of small fuel clamps. So I improvised. These vent hoses do not hold any pressure, so I used wire to clamp them on. Oh, the gasket shown is a new one.
    The cap assembly didn't want to stay centered over the bolt holes. So I cut the heads off M5x40 bolts, and screwed them in to the threaded assemblies. I was then able to align the gas tank cover and fuel cap without any trouble over the bolt holes.
    :bmwrider
    Here's the installed fuel pump assembly.
    And here's the sucking pump assembly. A problem arose, though. Notice the fuel return hose isn't long enough to reach the quick disconnect. You can see me trying to stretch it, but it won't reach.
    I added a short length of fuel hose to make it reach. With the correct Oetiker clamps. :clap
    Next came in installation of all the tank brackets. This was a bigger PITA than I expected. The nearest BMW dealer is 40 miles away. If I was missing a part, and they didn't have it in stock, a 2 or 3 day delay was a surety. :cry
    First, some of the brackets on the bike needed to come off. This one, and its partner on the other side came off.
    Here's a bottom view of the standard GS tank. I ended up needing both of the rear clamps off that tank.
    I had to remove a piece off the clamp in the 2nd photo. Don't worry, it'll be obvious when you try to attach the side panels. The piece with the Dzus bracket needed to come off.
    I had some spare M8x40 bolts lying around, so I used them to temporarily hold the front tank bushings in place. Note the long (and wrong) bolt discussed previously.
    Front brackets were installed on both sides. These hold the side panels.
    An extra countersunk washer is needed for one of the 4 tank bolts (take your pick, as they're all interchangeable). Here's where I added it. Without the washer, the bolt would probably not have held the tank in place.
    Installing the side panels ended up being a bit more complicated than I expected. The Dzus fastener on the front of the aluminum side panel would not work with the GSA side panel. Here's a pic.
    So I had to go back to the BMW dealership and order the correct bolts and nuts to hold it in place. They're included in the above parts list.
    The good news is once they're installed, no more Dzus fasteners to come loose. :clap
    Installing of the BMW roundels is easy. Stupidly expensive, but easy. You don't need an explanation. Trust me.
    If I had been in a worse mood, I might have sent these damn $25 roundels back, and used some SOLAS reflecting tape instead. :deal Jeez, BMW. Could you possibly screw us any harder?
    I forgot to mention that placing the GSA tank on the frame is a bit more difficult than the GS tank. I needed to take the air intake "snorkel" off, else the tank wouldn't go on. I similarly had to remove the snorkel to take the tank off. The snorkel can be installed with the GSA tank in place. This isn't that difficult.
    You need to watch out for leaks.
    DAMHIK.
    :baldy
    I found it after I'd filled up the tank with gas. :baldy
    It was coming from the sucking pump assembly. It was a good one, too.
    I drained some of the gas out of the tank, and removed the assembly. I coated the gasket with some motor oil (Mobil 1 20W-50 V-Twin oil - gosh I hope this doesn't start another oil thread), and retightened the flange ring. :thumb No more leaks. I've since coated the fuel pump gasket with oil, similarly.
    That's pretty much it. Here's a few pics of the finished installation.
    If I had to the another install right now, assuming I had all the correct parts, it would probably take me 3 hours to complete. This install took probably about 10 hours of actual wrenching time, including fixing leaks and removing parts that I installed in the wrong sequence.
    It's no doubt a more complicated install than the equivalent GSA tank onto an 1150GS (which I also did). Not to mention that the 1200GS install requires more expensive parts to complete. I guess that's progress. Or BMW designing for increased financial returns.
    Whatever. :rolleyes
    I filled the tank with 2 gallons of premium gas from a gas can in the garage, then drove 2 miles to a gas station, where I added just about 8 gallons. Seems that I have over 9.5 gallons of capacity in my system. Wow. :ricky
    :wave
  2. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,205
    Nice work Lobby! This one should be added to the HOW, and it's the definitive how to!! :clap Now keep that bike more than a year, ok? :lol3
  3. Gummee!
    Gummee! That's MR. Toothless
    May 13, 2004
    36,579
    NoVA for now...
    Welcome to the 400+ mi range* club!
    First day I owned my GS-Adv, I rode from ABQ to the southern CO border. Filled up 'just cause.'
    Rode to Cheyenne, WY and filled up again. With a loop around the 470, just cause I thought I needed to go home.
    :eek1
    M
    *ridden 'conservatively' :D
  4. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    5,491
    NW Sydney, Australia
    Excellent job :thumb
    Has anybody done this on an 08 + GS?
  5. EggChaser
    EggChaser Been here awhile
    Aug 31, 2008
    536
    Hamsphire/Surrey Borders
    Was kind of wondering this myself as the '08 panels, tank and front subframe are not the same as the earlier years, can it be done with OEM parts?
  6. GB
    Aug 16, 2002
    67,205
    08 and newer will need 08 tank and parts, but it's the same job essentially. the tank and plastics have been cosmetically modified but the rest is the same.
  7. Lobby
    Nov 30, 2003
    30,194
    San Antonio, Tx
    As GB says, it's pretty much the same job.
    I'd suggest working on the tank brackets, tabs, and screws / bolts first. You'll have to look at the BMW parts fiche for the 08 GSA to see what parts you'll need.
    Having your dealer close by so you can get the mounting hardware would be handy.
    If you do this for the 08, pls take pics and documents the differences. I regularly see 08 GSA tanks in our Flea Market and on the Interweb.
  8. kktos
    kktos on a bright side of life
    Aug 22, 2005
    2,368
    in front of Mare Nostrum
    Lobby, this is Excellent work !!! Thank you very much for the pictures !
    indeed :D check my sig.
    Lobby, I'm hearing opposite info about the 08 gsa tank mounted on a pre 08 GS.
    Some told me it's doable, others not.
    I'm in contact with a guy who's interested by my tank but he has a pre 08 GS.
    And I'm unable to tell him if it will be possible or not :cry
    Any idea and/or explanation could be great !
    Thx,
    /thierry
    #8
  9. Mac
    Mac Long timer
    Mar 18, 2006
    2,239
    Colorado Springs
    Great writeup, Lobby!
    One suggestion. People can save the $82 for the ring wrench. I've removed my rings a few times, just using a straight edge piece of metal, like a 1/8" x 2" x 8" bit of scrap steel.
    #9
  10. Lobby
    Nov 30, 2003
    30,194
    San Antonio, Tx
    2 ways to answer this question:
    - check the parts fiches (Max, Hammersly, A&S, etc) to see if part numbers match for the tanks. If they do, then the tanks are interchangeable.
    - if the part numbers don't match, then you'll just have to try it. I've seen others (BMW motorcycle dealers) post here on Adv that the 08 tank doesn't fit on the pre 08 bikes. I'd tend to believe him, but I dunno for sure.
    #10
  11. Lobby
    Nov 30, 2003
    30,194
    San Antonio, Tx
    I think you can remove the the ring that way, but I'd worry about reinstalling them. To fix the leak I mentioned in my writeup, I needed to torque the flange to the exact figure SQD8R recommended in his report. I don't think I could have done that without the ring wrench.
    Of course you could be lucky and not have leaks. :D
    #11
  12. WeazyBuddha
    WeazyBuddha Carbon-Based Humanoid Supporter
    Mar 18, 2008
    7,472
    RGV Texas
    Does this impact the OBC/related display readings for fuel? Anything to tweak there?
    #12
  13. Lobby
    Nov 30, 2003
    30,194
    San Antonio, Tx
    Actually, yes. My fuel gauge wouldn't read at all at first. See this thread for a description (and more pics) of the issue and how I troubleshot it.
    Eventually, I unplugged the positive battery terminal overnight. This reset the computer, and apparently fixed the fuel gauge.
    This was an Edisonian (trial and error) fix. I was at wit's end and out of ideas. I just thought to try this, and it appeared to work. I have found no literature anywhere telling me to do this.
    Of course, I'm no expert.
    #13
  14. Mac
    Mac Long timer
    Mar 18, 2006
    2,239
    Colorado Springs
    You're right, it's hard to torque to a precise figure with a hunk of scrap steel. But you're just compressing a rubber ring, and you have to get it to precisely "just about the right amount" of torque. :evil
    I haven't had any leaks with my method, but not spending the money for such a specialized tool is an option if you can survive knowing the torque isn't exactly to spec.
    #14
  15. jwd98056
    jwd98056 Been here awhile
    Dec 23, 2006
    111
    Renton, WA
    I had the same problem after I converted my '05. A description of how it seemed to resolve itself can be found HERE. My gauge still doesn't work as well as it did before the conversion. After a fill up It initially goes into low fuel warning somewhere around the 200 mile mark. After a variable period of time on a continuous ride it will then come out of the low fuel warning mode. It may do this several times before it gets to the real low fuel warning condition. I don't totally rely on it. I set one of my trip odometers to zero at each fill up and use it as a sanity check. Some of this can be explained by fuel sloshing around in the tank or the terrain I am riding on. But it also does it riding down the super slab in fairly tame terrain so there is still a weird factor involved :scratch.
    One additional issue I had to deal with was relocating my Touratech Hella Micro DE fog/driving lights. I fabricated some simple brackets from steel bar stock to move them forward 2.75 inches. I still needed to cut some notches in the GSA tank "fairing" to accommodate the extension brackets. A picture of the final configuration can be seen HERE. It is the last picture on the page. Click on the picture to get a larger image.
    #15
  16. Lobby
    Nov 30, 2003
    30,194
    San Antonio, Tx
    I thought a bit more info might be of interest. I've gone through 2 fuel tank fill ups, and all is working fine.
    The first fillup occurred after 265 miles. I don't remember how much fuel I added, but the reserve light had not come on.
    The second was 312 miles. The reserve light came on at 310 miles (I needed 2 miles to find a gas station)
    Notice the reserve gauge is showing 40 miles till empty.
    Gas I added (calculates out to 42 mpg)
    Key point: disconnecting the positive battery terminal and leaving it off overnight seems to have reset the computer's interpretation of the fuel tank gauge. Maybe this fuel gauge isn't as accurate as that from a stock GS Adventure, but this level of accuracy is much better than I ever expected.
    #16
  17. mike54
    mike54 You don't get me
    Mar 13, 2004
    14,896
    Are you getting gas at Pilot's? :scratch.
    :lol3
    Good write up lobby. I don't have a 1200 but I've bookmarked this 'cuz you never know. :thumb
    #17
  18. 1coolbanana
    Aug 25, 2009
    5,491
    Wow...........your fuel is cheap :eek1
    That fill would cost me more than $40 :cry
    #18
  19. Lobby
    Nov 30, 2003
    30,194
    San Antonio, Tx
    :shog
    See the sacrifices I make in the interest of science?
    :wave
    #19
  20. Pcfly
    Pcfly Dude?! Seriously??
    Nov 30, 2008
    1,859
    North of the Columbia River
    Has anyone done this conversion on an 08 or newer bike? I'm asking more in regards to the knowing if the fuel calculator on the newer bikes works properly or will it cause errors or errand fuel readings?
    #20
