R1200GS Handlebar Alternatives?
Discussion in 'GS Boxers' started by Ken H., Aug 25, 2008.
  1. Ken H.
    Ken H. Been here awhile
    Aug 30, 2005
    216
    What aftermarket handlebars are available for the standard GS (’05 – ’07) that anybody knows of? I’d like something that is a bit narrower.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p> </o:p>
    Suggestions?
    Cheers!
  2. VonHelm
    VonHelm corona ring
    Oct 12, 2007
    6,043
    Grapevine, TX
    I'd like to know as well.
  3. zin
    zin n00b
    Sep 1, 2007
    6
    San Francisco Bay Area
    I switched to some Renthal Fat Bars - KTM bend with a set of advendture workshop 35mm risers. Much more comfortable than the stock bars. I had the bars cut down an inch on each side - could have maybe taken another 1/2 inch of on each side and still retained the hand guards. But would have to measure to be sure.
  4. ealdous
    ealdous Adventurer Supporter
    Sep 10, 2007
    16
    Protapers will fit with out to much work, You will have to use some type of risers. Do a search here for protaper on this site. I can email you my set up if you like.
  5. lightfighter
    lightfighter where does this go?
    Dec 23, 2007
    2,304
    Sierra Vista AZ.
    pictures?
  6. ealdous
    Sep 10, 2007
    16
    Here is some pictures of the Pastnana Protapers with ILIUM works riser on my 07 GSA. The bars on marked on the ends so you know where to cut if you want to shorten them. Both the brake and clutch line and throttle cable fit just like with the stock bars. Kcodegt posted some pictures of his Protapers with the BMW aux Lightswitch. His post is where I got my info to put them on mine. You will need a 12x1.50 mm heilcoil kit for the bar ends, I also drilled and taped mine on the left bar for the heated grip. All fit fine and is a lot better than the stock bars.
    m931a2 likes this.
  7. alexisan
    alexisan Been here awhile
    Nov 25, 2010
    190
    I am planning to change as well but don't want to use raisers. How about clearance to the windshield? Would you think the gap would be enough in full lock??
  8. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    THOSE LOOK SICK. i have a rpoblem i ordered the wrong bars for my 06,(28mm) i got the 2014 instead (32mm) is there a way,riser or adapter to ho from 26 to 32?i just dont really want to spend more money,, iany help appreciated
    #8
  9. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    ^ it's probably going to be cheaper to return wrong ones and get the right ones...
    #9
  10. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,707
    DC metro
    Having risers machined to fit the 32mm bars is the easy part, though hardly free unless you own the milling machine. Coming up with all new hand controls is going to be the heavy lift.
    It will be a great deal easier to simply buy the proper diameter bar.
    Either way, post pics once you've completed the upgrade.
    #10
  11. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    #11
  12. luca9277
    luca9277 Been here awhile
    Feb 25, 2012
    329
    Singapore
    I wanted a black one for my GS, I’ve got one for about 45US from AliExpress..
    Perfect fit.
    Only difference this is about 1 inch shorter on each end
    #12
  13. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    Got that one ,but its 31,5mm and my o6 uses 28mm
    #13
