R1200GS "Headlight Out" warning staying on even though the bulb works
Discussion in 'GS Boxers' started by J-Dash, Jan 3, 2007.
  1. J-Dash
    J-Dash Been here awhile
    Nov 28, 2002
    506
    Georgetown, TX
    I replaced the stock headlight bulb at 10000 miles and that PIAA burned out in less than 2400 miles later. So for $ reasons I put a Stanley H7 in there because I figured I'm not going to be serving my bike high end headlights if it just chews them and spits them out all the time.
    So the other day here at work it rained pretty hard for about 2 hours. My 05 R12GS just sits outside everyday and it was in this storm. Anyways I go outside to crank the cranky bastard to go get lunch and the headlight warning light is on. Sure enough I have no light out front. After I get back from lunch I have to work for another 3 hours. When I go outside to leave work I crank the bike up, I forgot about the burnt out dim bulb, and notice that my headlight is now working. So I think...wtf?? However, the headlight warning light stays on, and has for the past week. My headlight is working though...what's causing this?
  2. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,910
    The bulb and arrow forward symbol comes on for the high beam, and the low beam and the turn signals, but not the parking lamp. Once you replace the bulb, you must start the bike for the fault to clear itself. If it remains on, there's something odd going on. Check to make sure the spring holding the bulb in place is nice and tight too and the bulb harness is on all the way in.
  3. PegasoPat
    PegasoPat General Smart Ass
    Nov 18, 2005
    336
    Sarasota Fl.
    My 06 GS does something similar. I get the lamp signal and sure enough the high beam is out, but by pressing on the plug to the back of the headlight assembly the light comes on. I clear the fault signal when I restart. I have tried fixing the plug before and it worked for a bout four months but the wire seems to work loose and I start over. The dealer says he will fix it when it really breaks. The headlight always works when I take it in for service and the stored code is cleared from the system. They see a working headlight and assume it was out and then replaced and just ignore the code.
  4. Crilly
    Crilly Long timer Super Supporter
    Dec 12, 2005
    1,171
    Wi
    :D I had the same problem on my K1200R. I think a high resistance connection was my problem. Cleaned the connections, no problem.
  5. NJ Moto
    NJ Moto Glory Bound
    Aug 27, 2005
    11,217
    Bergen County, NJ
    A little dielectric bulb grease is a good idea too.
  6. J-Dash
    Nov 28, 2002
    506
    Georgetown, TX
    Great advise so far guys and I appreciate it!
  7. teomannaskali
    teomannaskali Long timer
    Mar 8, 2011
    1,185
    Plaka 34
    Do any of you know what wattages or amps the ZFE is looking for in each of the bulbs?
    Low beams
    High Beams
    Turn Signals
    Tail light
    Stop light
    Thanks in advance,
    Teoman
  8. zoomdude57
    zoomdude57 Been here awhile
    Mar 14, 2004
    719
    Seattle, WA.
    There is a small driving lamp as well to check. Scratched my head for days until I saw the small bulb which is positioned in the lower right of the lens if you are looking at the front of the bike.
    #8
  9. Plane Dr
    Plane Dr Long timer
    Sep 29, 2005
    1,221
    North TX Metromess
    I'm in there with the parking light. Same description. Not thinking I order the cheater kit for my HID (even though the light was still on, duh). Then after mention of the parking light changed it with a bulb from my tool box. Bulb cost pennies. Cheater kit not so much........:rofl
    #9
  10. England-Kev
    England-Kev Long timer
    Feb 5, 2007
    4,652
    England. Somewhere on the Canal.
    Ok then, I know this is an old thread but I am lost!
    My 06 GS1200 shows a rear light fault on the dash, but the rear light is working fine, as is the stop light. But my low beam light is not working, although there is nothing wrong with the lamp itself???
    Any ideas
    #10
  11. jdub
    jdub Dawg bytes reel gud Supporter
    Jan 7, 2004
    3,806
    S. Central PA
    On my '07GSA I got a rear lamp failure, but saw that both the stop light and tail light were still working. Read the manual and found that when one of those filaments fails, the crafty computer via the CANbus sends lower voltage to the remaining filament to act as the tail light and when you apply the brake that same filament gets full voltage so it is brighter and acts as the brake light.
    So, be sure and inspect the bulb itself to see if either filament is burned out.
    #11
    ultane, lewisjr1 and DRONE like this.
  12. England-Kev
    Feb 5, 2007
    4,652
    Thank you, I shall have a look
    #12
  13. England-Kev
    Feb 5, 2007
    4,652
    Following the above advice, I bought a new stop/tail lamp today, and sure enough as stated by jdub, the old lamp was working with one filament burned out, so new bulb fitted, rear light all back up and functioning as it should, the yellow warning signal on the dash was gone, and the big surprise, my low beam headlight was again back up and running, so all fixed.
    #13
    jdub likes this.
