R1200GS LC Useful Info for 12,000 Mile Service
Discussion in 'GS Boxers' started by 150flyer, Mar 10, 2017.
  1. 150flyer
    150flyer Been here awhile
    Oct 8, 2016
    121
    Ft. Worth
    I just completed the 12,000 mile service on my 2016 R1200GS LC. Since I do my own maintenance, I decided to compile the part numbers and torque values needed to complete the service so I would have them for the next 12,000 mile service. Hope others who do their own maintenance find some of this helpful.
    R1200GS LC SERVICE PARTS
    11427721779 - Oil Filter
    13727726799 - Air Filter
    12128532942 - Spark Plugs x 2
    07119963340 - Oil Drain Plug Crush Washer
    33117695219 - Final Drive Drain Plug
    O-Ring
    07119963132 - Final Drive Fill Plug Crush Washer
    5W-40 Oil
    Dot 4 LV - Low Viscosity Brake Fluid
    75W-90 Synthetic Final Drive Oil (Gear Oil)
    ENGINE OIL CHANGE
    4 Quarts - 5w-40
    11nm - Oil Filter
    42nm - Oil Drain Plug
    8nm - Bash Plate
    AIR FILTER CHANGE
    8nm - Air Filter Cover
    FINAL DRIVE OIL CHANGE
    20nm - Final Drive Drain Plug
    180ml of 75W-90 Gear Oil
    20nm - Final Drive Fill Plug
    10nm - Fender Brace Bolts
    VALVE CHECK
    .34 - .41 - Exhaust Valves (Bottom)
    .10 - .17 - Intake Valves (Top)
    10nm - Cam Carrier
    30nm - Cam Chain Tensioners
    10nm - Valve Covers
    12nm - Spark Plugs
    8nm - Wire Covers
    BRAKE BLEED
    Dot 4 LV (Low Viscosity) Brake Fluid
    10nm - Front Bleed Valves
    38nm - Front Brake Calipers
    14nm - Rear Bleed Valve
    24nm - Rear Brake Caliper
  2. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
  3. Hammerdown77
    Hammerdown77 Long timer
    Apr 24, 2014
    2,319
    North Alabama
    Does BMW not use Iridium spark plugs???
    I never understood the change sparkplugs every 12k thing on motorcycles (less on other bikes).
  4. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
    No. But if you do not change them, chances are very good you will start to notice a drop in performance.
    RunninRanger and Fullboost like this.
  5. GraniteRider
    GraniteRider GranitRider
    Dec 9, 2016
    81
    Utah
    Is there a good YouTube video for the 12000 mile service? Is there anything different on a service between a 2014 and 2016 model year? I have been told the bikes are the same, save a bit more weight added to the crank counter balance on the 16 model and of course, electronics are just a bit different.
  6. jdub
    jdub Dawg bytes reel gud Supporter
    Jan 7, 2004
    3,817
    S. Central PA
    Here's a thread about iridium plugs on the LC bikes. I have them installed now on mine, and went to 48k change intervals with them on my Hexhead GSA.
    Likely could have gone longer, as BMW specified 100k mile iridium plug change intervals on my 528i.
  7. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
    Mechanically they are the same for services.
  8. Pch123
    Pch123 Bar Crossings
    Dec 19, 2012
    1,477
    East Coast Australia
    Did a 6k miles service yesterday. Easy. Added in diff fluid change and air filter check.
    Thanks Jim for your DVDs. Has always made it easy
    #8
    JimVonBaden likes this.
  9. Kawidad
    Kawidad Long timer
    Jul 9, 2005
    6,406
    Central Coast, Cal
    $$$$$ That's why.
    (Bring More Wallet) :D
    #9
  10. GraniteRider
    Dec 9, 2016
    81
    Utah
    Too true!
    #10
  11. Sailorlite
    Sailorlite Long timer Supporter
    Feb 18, 2006
    1,243
    Seal Beach, CA
    Iridium plugs? If replacing standard spark plugs at 12000 miles, and the BMW warranty is to remain in effect, which iridium plugs are suitable, if any? Thanks.
    #11
  12. Hammerdown77
    Apr 24, 2014
    2,319
    North Alabama
    At least these plugs are easier to change than those on my V-Strom. You can bet that bike got Iridium plugs first time I did it.
    #12
    F16Viper68 and krussell like this.
  13. Kawidad
    Kawidad Long timer
    Jul 9, 2005
    6,406
    Central Coast, Cal
    #13
  14. glitchvdub
    glitchvdub Has been known to fall over.
    Mar 15, 2016
    88
    Salt Lake City
    #14
    EMFL and aleaddict like this.
  15. Masterblaster
    Masterblaster Long timer
    Dec 18, 2010
    1,215
    Conroe Texas
    excellent thread, I am orderig from bike bandit, thanks gents.
    #15
  16. aleaddict
    aleaddict Been here awhile
    Sep 30, 2016
    125
    Boise, ID
    I just finished performing my 6k mile service... checked the valve clearance just to get a baseline value (all within spec).
    I'm curious how often other inmates replace their air filter? Maintenance schedule has it listed at every 20,000 km. It seems like every season (12 months/10-12k miles) would be reasonable without being overkill. Thoughts?
    #16
  17. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
    It depends on riding conditions. If you ride street mostly and no significant dusty conditions, 12K miles is fine, even more. On the other hand, dusty off roading means more frequent changes.
    #17
    RunninRanger likes this.
  18. F16Viper68
    F16Viper68 Trapped in the Sandbox! Supporter
    Oct 14, 2007
    1,035
    Crawfordville, FL
    Thanks for all the information in the thread. Any ideas where to order the BMW parts online? I'm three hours from a dealer so that's really not an option. Max maybe?
    #18
  19. JimVonBaden
    Feb 11, 2005
    90,911
    Alexandria, VA
    Service supplies www.beemerboneyard.com . Parts, www.maxbmw.com .
    #19
  20. glitchvdub
    Mar 15, 2016
    88
    Salt Lake City
    Save yourself some cash, don't buy the BMW branded parts. You can buy the stuff I linked above or buy this kit from Beemerbone yard.
    https://www.beemerboneyard.com/r1200wcmaintkit.html
    But if you have to have the BMW branded, which is Mahle built...
    https://shop.maxbmw.com/fiche/fiche.aspx
    Oil I use, no need to use the BMW branded.
    https://www.amazon.com/gp/aw/d/B00D91Q1DM/ref=ox_sc_act_image_2?smid=ATVPDKIKX0DER&psc=1
    #20
    aleaddict likes this.
