R1200GS Rear Brake Reservoir
Discussion in 'GS Boxers' started by John F, Sep 15, 2019.
  1. John F
    John F Been here awhile
    Oct 21, 2015
    454
    South Windsor, CT
    Anybody else have this break? The mass of the reservoir and fluid is pretty much cantilevered off the mount and the hose. I figure that while riding some of the extremely rough rocky trails I was on in Quebec a couple weeks ago, I probably hit the natural frequency of this cantilevered mass more than once, and had it wagging around real good until it broke near the mounting bolt.
    Lucky a buddy had some zip ties, and he rigged some extra support (the mount isn’t cracked all the way through - but it’s close). I figure when I get the replacement part installed, I’ll add the zip ties to keep it from wagging around in the rough stuff.
  2. Motorius
    Motorius Road trippin' Supporter
    Dec 7, 2016
    6,631
    Seattle & Phoenix
    Like everything else, there is an aftermarket metal guard sold for those.
    Only ride street but bought one as that looked pretty exposed to me. Hasn’t broken yet.
  3. JimVonBaden
    Feb 11, 2005
    90,955
    Alexandria, VA
    That is the first I have seen break. If it was loose the vibration could break it. None of the "protectors" would have helped that unless it was from an impact.
  4. Dan Cãta
    Dan Cãta Long timer Supporter
    Jun 5, 2008
    2,285
    Cluj, Romania
    @JimVonBaden perhaps the upper tabs would keep it from moving/vibrating. I bet the manufacturer did not think of this, but it definitely helps.
    Dan.
  5. JimVonBaden
    Feb 11, 2005
    90,955
    Alexandria, VA
    Possibly. But, to be fair, I have never before seen one of these break that wan't impacted by something.
  6. John F
    Oct 21, 2015
    454
    South Windsor, CT
    Mine was definitely not impacted by anything.
  7. JimVonBaden
    Feb 11, 2005
    90,955
    Alexandria, VA
    Was the bolt loose? Must have been VERY rough stuff.
  8. Pch123
    Pch123 Bar Crossings
    Dec 19, 2012
    1,478
    East Coast Australia
    When was the last time the rear brake was bleed and who did it? My guess is that was when it was cracked and then vibration completed the job.
    #8
    MrVvrroomm, AZgman and Motorius like this.
  9. JimVonBaden
    Feb 11, 2005
    90,955
    Alexandria, VA
    :nod could be. That cap is often very tight.
    #9
  10. John F
    Oct 21, 2015
    454
    South Windsor, CT
    All maintenance to date (41000 miles) has been done by the BMW shop where I bought it new. Cracking during maintenance is a definite possibility. But I’d like to think the shop would be more careful than that. Maybe not.
    #10
  11. Boxerbreath
    Boxerbreath 2017.5 GS Black Storm
    Feb 7, 2018
    3,773
    Lost Angels County
    Who makes that cover Jim?
    #11
  12. JimVonBaden
    Feb 11, 2005
    90,955
    Alexandria, VA
    Virtually everyone. I got mine from Kildala, an inmate here. You can find him in Vendors. If you pay more than $20, you are overpaying. AliExpress has them for like $5.99.
    #12
  13. ERrider
    ERrider n00b Supporter
    Jul 25, 2016
    7
    Estacada, OR
    Just found mine in the same condition, top arm broken, no impact. Where did you get your replacement reservoir?
    #13
  14. John F
    Oct 21, 2015
    454
    South Windsor, CT
    I ordered it at the parts counter at my local Max BMW. $37. When I installed it I added zip ties to hopefully keep it from wagging around in the future.
    #14
    Boxerbreath, Hogges and Clayshooter08 like this.
  15. Clayshooter08
    Clayshooter08 Ridin Da Beast!!!! Supporter
    Dec 1, 2019
    24
    Asheville, NC Area
    Dang it!!! Now I have to go home and check mine!!!!
    #15
  16. ERrider
    Jul 25, 2016
    7
    Estacada, OR
    Guess I’ll be doing the same! Order in for part and a guard as well.
    #16
  17. rtb
    rtb Adventurer
    Jun 14, 2010
    46
    Charlotte, NC
    Another one. 2015 with ~50k miles. Have no idea if anything hit it. IMG_3132.JPG
    #17
  18. Boxerbreath
    Feb 7, 2018
    3,773
    Lost Angels County
    Probably made of nylon that gets brittle after time. There’s a lot of heat coming up in the right side too.
    #18
  19. Truett08
    Truett08 Adventurer Supporter
    Dec 12, 2019
    73
    Western North Carolina
    The 2015 GSA I picked up this weekend with 36k miles has this same issue, I plan to fix it then install some kinda protection for it once NC lifts some restrictions. From what I can tell, the PO did some pretty serious off-road riding so I assume it was either impacted or vibrations eventually got to it.
    #19
