R1200GS : Slow leak -Replacement of tire or a patch ?
Discussion in 'GS Boxers' started by Begoud, Oct 4, 2010.
  1. Begoud
    Begoud Adventurer
    Feb 14, 2006
    15
    Montréal
    Hi everyone,
    I have a slow leak on my rear Tourance (almost new - 1000 miles). It leaks at a rate of 10 psi (from 42 to 32) in 12 hours. I haven't had a flat in 25 years. Should the tire be replace (security) or can it be repared ? :dunno
  2. (none)
    (none) poser
    Jan 25, 2007
    2,804
    Gville, SC
    Do you know if it has a hole in it? Check the valve stem first just to make sure it isn't the problem. Not uncommon for the little insert to loosen if they took it out when they changed your tire.
  3. Mudcat
    Mudcat Unregistered
    Jul 22, 2004
    4,472
    Bay Area
    You repair the tire, probably a nail or screw in it. If so, I would just put a plug in as long as the hole is not in a sidewall.
  4. bobbybob
    bobbybob Long timer
    Sep 5, 2008
    2,049
    Morganton, NC
    If theres a puncture, you can patch it but DON'T "just put a plug in it". You need to patch it from the inside using a "patch plug". These are available from NAPA parts. It consists of a round flat patch with an integral plug enclosed in a metal sheath which enables you to press the plug thru the tire wall from the inside while seating the flat patch at the same time. You use "universal cement" and the patch becomes one with the inner surface. The plug and patch are all one piece so the plug can't suddenly "blow out" thru the hole, the way a sticky string patch you insert from the outside. And they WILL do that!! Don't cut any corners--do it right.
    But find the leak first--maybe the bead didn't seat correctly. Use a spray watter bottle with soapy water and look for bubbles.
  5. Mudcat
    Mudcat Unregistered
    Jul 22, 2004
    4,472
    Bay Area
    That is not right it's just hard to do
    Anyway, I just plug them. It gernerally works great and if it doesn't it's no big deal.
    My rule is, I will plug them twice. If that doesn't fix it, I will use a patch but not a patch plug. And this is something I never had to do.
    I believe JimVonBaden has a tutorial on pluging on his web site. It’s easy
  6. Lank
    Lank Been here awhile
    May 7, 2009
    173
    Northern MN and Southern AZ
    I would put that sucker in water and find out where, could be a bead leak, a little goober in there can cause that easily.
  7. bykemike
    bykemike "ready to navigate" Supporter
    Apr 30, 2006
    1,356
    St. Augustine FL
    +1 on "just plugging it" Plugs are quick and very, very durable. I have ridden a number of tires their full life with multiple plugs in them. Never seen one even come close to blowing out.
    Mike
  8. hojo in sc
    hojo in sc Long timer
    Oct 4, 2007
    1,232
    I would remove the tire and put in a better seal/patch, the ones used to repair from the inside that has a worm and a patch combo. Sorry, I don't have the link here on this computer.
    #8
  9. bobbybob
    bobbybob Long timer
    Sep 5, 2008
    2,049
    Morganton, NC
    Thats great that you have never seen one blow out. But I have. And the tire deflated very quickly as if it had a large hole in it. And I had another slowly squeezing out. So take your chances on 2 wheels. Or don't. :wave
    #9
  10. hojo in sc
    Oct 4, 2007
    1,232
    #10
  11. Lensgrinder
    Lensgrinder Long timer
    Aug 8, 2007
    1,533
    San Marcos, California
    On a car or truck, repairing the tire is ok as long as it's not on the side wall, but not on a motorcycle. Plugs and patches are a temporary fix until you can get somewhere safe to replace the tire. My wife picked up a nail in one of her tires which had only about 1500 miles on it. I replaced it because being safe is worth the money.
    just my .02
    #11
  12. LaurelPerryOnLand
    LaurelPerryOnLand Long timer
    Jun 9, 2009
    3,482
    Denver, CO
    I picked up a nice self-tapping screw (3/4") in my rear tire this past weekend.
    No problem...I've got an inflator and a plugger...oh yeah...I left them with the rest of my tools on the bench and failed to put them back in the bike when I was done working on another project.
    Well...d'oh.
    Tourances had about 8,000 miles on them and local trailer sales dealer saved the day by actually having a 'plug'. Made it back home but decided to replace with new tires. Decided it wasn't worth it to try to get the last couple thousand miles out of them.
    Woody mounted them and I'm good for another 10,000+.
    Also installing a Doran Tire Pressure Monitor.
    #12
  13. JimVonBaden
    Feb 11, 2005
    96,322
    Alexandria, VA
    :nod
    http://www.jimvonbaden.com/Tire_Plugging.html
    Jim :brow
    #13
