R1200GSA - Welding on frame question
Discussion in 'GS Boxers' started by Homer GSA, Jul 11, 2020.
  1. Homer GSA
    Homer GSA R1200GSA 2008
    Oct 10, 2016
    546
    Howdy
    I want to weld a tab onto the steel lower engine frame bracket but am worried about frying the electrics on the poor thing.
    Have welded on heaps of machinery first disconnecting both battery cables but something tells me I am about to do a Charlie Boorman in Kazakhstan.
    Thoughts from the knowledge base.....
    Cheers
    Homer
  2. Homer GSA01
    Homer GSA01 n00b
    Jan 17, 2017
    9
  3. falcofred
    falcofred aka Beer Scout Supporter
    Nov 30, 2008
    7,967
    Extreme N.E. Tennessee = Motorcycle Nirvana
    Is gas/acetylene welding an optinon?
  4. Fubars
    Fubars What would Scoobydo?
    Aug 20, 2003
    2,215
    Ventuna, CommieFornia
    I disconnect the ECU, and anything else with wires just to be safe. Use a welding blanket (nomex) to keep spatter off the rest of the bike. Aluminum foil works in layers and it'll bend/fold over any surface. Kinda close to the injection system--drain and remove those and the fuel tank as well. You gonna use MIG?
  5. JimVonBaden
    Feb 11, 2005
    91,404
    Alexandria, VA
    The ECU is hard to get to on the Hexhead. But, if you disconnect both sides of the battery and isolate them, then ground very close to the weld spot, you should be fine.
  6. PerazziMx14
    PerazziMx14 Been here awhile
    Oct 9, 2011
    943
    Yes disconnect the battery and I'd suggest TIG welding the tab on. No need dragging granddads old A/C stick machine out of the shed and chucking up a 5/23 rod. TIG is clean with no spatter.
    CROSSBOLT likes this.
  7. Homer GSA01
    Homer GSA01 n00b
    Jan 17, 2017
    9
    Thanks. Sorry should have mentioned I only have MIG....
    JimVonBaden likes this.
  8. JimVonBaden
    Feb 11, 2005
    91,404
    Alexandria, VA
    MIG will be fine.
    #8
  9. mtncrawler
    mtncrawler Long timer Supporter
    May 17, 2003
    1,591
    Fort Collins, CO
    Sounds like you have plenty of experience welding, but I'd do all you can to mock up the joint (similar or same materials, thicknesses, fit up, prep..etc) on some like materials off the bike first and run a test weld (settings, wire type...etc). Doesn't look like an area you'd want to make any mistakes on. I've done this several times when I can't afford "rework" - even replicating weld position so I limited any surprises.
    Sorry if I'm preaching to the choir (probably all stuff you know) - just thought I'd bring it up. :beer
    #9
    Mcgee likes this.
  10. wellcraft
    wellcraft Been here awhile
    Aug 31, 2008
    884
    PA
    I'm curious...what is the purpose of the tab you want to weld onto the frame?
    #10
  11. snofrog
    snofrog Long timer
    Aug 15, 2006
    1,094
    Petersburg Mi 49270
    As a welder that has welded on hundreds of bikes, cars,trucks and mowers. I have never disconnected anything before welding on a vehicle and haven't personally experienced any of the wives tales I have heard of. FWIW
    #11
    Paladin53 likes this.
  12. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    26,213
    Über Alles,California
    Same here, it doesn't matter.
    #12
  13. Homer GSA01
    Homer GSA01 n00b
    Jan 17, 2017
    9
    Well now that you ask.....
    On another thread I have been recording the nightmare that is my total knee replacement and when I am on the GS the angle of my knee is about 2deg off the maximum 125deg of angle i can get.
    So I am looking at making some highway pegs that don’t make me look like I should be wearing a sleeveless leather vest with tassels on it, a Matt black open face helmet and a crazy clown face covering....
    I reckon I can get a couple on each side down in that area. One option is to mount it off a tab on that lower frame piece triangulated up to the crash bar. But removable and unobtrusive.
    Cheers
    #13
    lewisjr1 likes this.
  14. Paladin53
    Paladin53 Been here awhile Supporter
    Nov 16, 2013
    115
    Texas
    As snofrog and larryboy said, I never disconnect the battery on the vehicles I've welded on.
    Do the guys in the muffler shop disconnect the battery when welding on a muffler?
    Connect the ground next to the weld.
    That said, I would be more concerned with changing the temper or ductility of the metal on the frame, setting up a stress point or weak spot.
    In the past I've cut apart and re-welded truck frames and welded hitches to frames.
    But no more. My insurance does not allow.
    I built a trailer for my 2015 GSA. I did not weld to any part of the bike but had parts bolted to the bike that I welded on. Did not disconnect anything.
    Bike is not dead yet.
    I also built a welding bed on a 2012 Dodge 3500. Lots of welding on the bed while on the truck.
    Bolted bed to frame.
    #14
    larryboy likes this.
  15. PerazziMx14
    Oct 9, 2011
    943
    Why care what others think? If traditional highway pegs keep you riding to hell with hat other think!
    As a side note is your front tire on backwards?
    #15
  16. snofrog
    snofrog Long timer
    Aug 15, 2006
    1,094
    Petersburg Mi 49270
    The frame is already a welded assy . If welding was going to compromise the tube it would have happened at the factory.
    #16
  17. larryboy
    Jan 9, 2005
    26,213
    And we'd be talking about this in the KTM section.
    :hide
    #17
    snofrog likes this.
  18. snofrog
    snofrog Long timer
    Aug 15, 2006
    1,094
    Petersburg Mi 49270
    But as long as we are talking about welds 1698F8E5-96AF-4E54-8511-530F58C66EA9.jpeg
    #18
    Homer GSA, Embret, m931a2 and 4 others like this.
  19. bikermd
    bikermd Been here awhile
    May 30, 2014
    188
    very nice weld you can weld anything I want anytime.
    #19
    M33 and snofrog like this.
  20. JimVonBaden
    Feb 11, 2005
    91,404
    Alexandria, VA
    #20
    snofrog likes this.
