R1200GSw LC Wethead Final Drive change and Spline Lube Pictorial!
Discussion in 'GS Boxers' started by JimVonBaden, Mar 11, 2016.
  1. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    11,241
    NH
    I just figure I will drop the drive each oil change time since I have to change the FD oil then too anyway.
    #41
  2. Ravedigger
    Ravedigger Been here awhile
    May 14, 2014
    519
    Is the spline lube included in any of the standard services for the GSW? I typically let my dealer handle the scheduled maintenance so I'm wondering if this is something that they would take care of or if it's something I should do on my own. I just had my 48k service completed so if it's something that's not included with any of the services, I'll probably give it a go myself when I get some time.
    #42
  3. filterwrench
    filterwrench Been here awhile
    Apr 26, 2013
    937
    Langley BC CANADA
    I put a rubber plug in the speed sensor hole so not to lose any oil.
    #43
    Candubrain, Bill-66 and kurien like this.
  4. longslowdistance
    longslowdistance Long timer Supporter
    Oct 12, 2010
    1,825
    Virginia
    Here is another "Thanks and Well Done".
    Can we chip in to buy you some metric sockets?
    #44
  5. JimVonBaden
    Feb 11, 2005
    93,697
    Alexandria, VA
    No, they will not have it in the books. If you let the dealer do all your work you will not get a spline lube.
    #45
  6. JimVonBaden
    Feb 11, 2005
    93,697
    Alexandria, VA
    Why not just do it when you change the FD oil? Seems the logical thing to do. Besides, it is 180ml of oil. Not about to break the bank if you just change it.
    #46
    DutchOne likes this.
  7. Ravedigger
    May 14, 2014
    519
    Thanks! Sounds like I should probably dig into it myself. I ride in the rain and do plenty of water crossings.
    #47
  8. Bikerboy108
    Bikerboy108 Pat from Jersey
    Sep 22, 2004
    5,109
    Jersey "Land of the Lane Closure"
    Harbor freight plastic bottles a couple bucks....
    Harbor_freight.jpg oil.jpe
    #48
  9. JimVonBaden
    Feb 11, 2005
    93,697
    Alexandria, VA
    In that case I would suggest you at least do one. At those miles, if you are clean in there, you can skip doing it again for 12-18K miles.
    #49
  10. Ravedigger
    May 14, 2014
    519
    What do I do if it isn't clean in there? Do I need to replace parts or can I just lube it and hope for the best?
    #50
  11. JimVonBaden
    Feb 11, 2005
    93,697
    Alexandria, VA
    It depends on what is going on. The usual issue is rust from water sitting in the area. Clean it up well, and use a corrosion inhibiter. This is important, check the U-joints to see if they are loose or binding, or show signs of rust around the rubber seals. Clean and protect them with a rust coating that is friendly to the rubber seals on the U-joints.
    If you have oil sitting in there, look up the swingarm tube to see if the oil is coming from the transmission. If no oil trail down the swingarm tube it is likely a leak on the FS input shaft. Tiny amounts of oil are usually not a big deal, but you should watch your fluid levels and watch the final drive boot for signs of leaks.
    99% of the time everything is good and you just clean and lube the splines and put it back together.
    #51
  12. The Griz
    The Griz Long timer Supporter
    Nov 26, 2008
    3,905
    Earth
    Can I change the FD oil without opening up the boot and flipping the FD back?
    #52
  13. JimVonBaden
    Feb 11, 2005
    93,697
    Alexandria, VA
    Sure, remove the filler and then the drain. The fluid drops straight out. Put the plug back and fill the install the filler plug.
    #53
    The Griz likes this.
  14. MarkM
    MarkM Been here awhile Supporter
    Mar 23, 2009
    987
    St. Louis
    Maybe add some new gear oil too.
    #54
  15. JimVonBaden
    Feb 11, 2005
    93,697
    Alexandria, VA
    :lol3
    #55
  16. The Griz
    Nov 26, 2008
    3,905
    Earth
    I plan on changing the FD oil each oil change. Why not, right?
    #56
  17. JimVonBaden
    Feb 11, 2005
    93,697
    Alexandria, VA
    No harm in it.
    #57
  18. The Griz
    Nov 26, 2008
    3,905
    Earth
    #58
  19. MarkM
    Mar 23, 2009
    987
    St. Louis
    I change mine at every service since I cross streams now and then. So far always comes out clear--no water. My odometer is somewhere north of 24K miles. That pricey bottle of BMW gear oil lasts a long time at 180 ml per change.
    #59
  20. MarkM
    Mar 23, 2009
    987
    St. Louis
    BMW C-SAF-XO 75W-90
    #60
    The Griz and JimVonBaden like this.
