R1200GSw LC Wethead Final Drive change and Spline Lube Pictorial!
Discussion in 'GS Boxers' started by JimVonBaden, Mar 11, 2016.
  1. JimVonBaden
    Feb 11, 2005
    96,267
    Alexandria, VA
    Unless it is out of warranty.
    Then again, if the driveshaft fails you will need a new final drive too. Plus the rust is likely invading the U-joints so they will fail early too.
  2. Shawnee Bill
    Shawnee Bill Long timer Supporter
    Feb 25, 2006
    5,734
    Oklahoma
    Nope, the drive shaft and U-joints looked brand new. No hint of rust or any wear. Very clean inside there except for the splines themselves. The front splines had grease and were fine.
    I am not saying not to lube those splines, they were designed to slide so should. I know some of the pictures posted in this thread look pretty bad but mine didn't look like that. So because of having seen those in the future I will check mine regularly.
    eri likes this.
  3. Mr Pou
    Mr Pou Been here awhile Supporter
    Nov 14, 2018
    638
    Southeast TN
    So, revisited a year or so later, the splines are much drier than I would have imagined. Almost as if all of the vehicle in the moly paste has dried out.
    I believe this will continue to be a yearly MX item.
    E589C465-54F2-4D59-9818-E597C0E9859F.jpeg FAFAE8E6-950A-4128-94FD-CDA9BDDAC812.jpeg
    JimVonBaden and Pendog like this.
  4. m931a2
    m931a2 Long timer Supporter
    Oct 2, 2014
    1,238
    Austin, Texas
    What did you use? That doesn’t look like a molly grease that is recommended. Anything in a pinch but grease will not dry out and will stay put more
  5. Mr Pou
    Nov 14, 2018
    638
    Southeast TN
  6. Dannno
    Dannno 200 Miles before breakfast Supporter
    Aug 18, 2018
    449
    Southern California
    That’s exactly what I use as well.
  7. pistole
    pistole Long timer
    Jan 11, 2013
    2,729
    earth
    the splines above look great.
    Dannno likes this.
  8. Mr Pou
    Nov 14, 2018
    638
    Southeast TN
    especially considering how they looked first time around. Still, I’ll feel better doing this yearly.
    Emoto likes this.
  9. ADVNoob
    ADVNoob Adventurer
    Jul 20, 2021
    33
    Is it too early to check the splines at 2000 km ? No off road yet, no riding in rain, and washed the bike two times so far.
    I was thinking to check and relube in spring next year, but I could do it until the winter starts also.
  10. eri
    eri Long timer
    Jan 5, 2018
    2,428
    ak,nz
    if you've got the time, skills, grease, (final drive oil?) why not
    some years (17-19?) seem more susceptible to low grease issues than others
    presumably your bike is very, very new?, if so it's likely 90?% unnecessary to check now
    but if your bike isn't very new but only has 2,000km it would be very wise to have a look see
    ymmv
    Callisto224 likes this.
  11. ADVNoob
    ADVNoob Adventurer
    Jul 20, 2021
    33
    My GSA is 2 weeks old. I will not change the final drive oil as it was changed at 1000km (600 miles) service, I will plug the speed sensor hole.
  12. eri
    eri Long timer
    Jan 5, 2018
    2,428
    ak,nz
    imho?
    pulling apart a 2 week old bike that is still under warranty is just asking for trouble
    by all means have a look a month? before the warranty expires
  13. ADVNoob
    ADVNoob Adventurer
    Jul 20, 2021
    33
    I though the purpose of this job is to avoid the rust and seizure of the splines to the final drive. I read about cases where rust was present after 4-5k miles.
    I also have 5 years of warranty, I don't think I am willing to wait that long :)
  14. Mikaela
    Mikaela Adventurer
    Nov 25, 2017
    36
    Cheshire UK
    My 1200 gsa was really rusted up at 12months. I lube all my final drives early since finding that back in 2016 as precautionary maintenance.
    deadflagblues and JimVonBaden like this.
  15. Colkel
    Colkel n00b
    Feb 20, 2009
    2
    I recently bought a 2018 GSA with 6k miles on it. I will be dropping the final drive over the winter just as a precaution
  16. Mr Pou
    Nov 14, 2018
    638
    Southeast TN
    I’d lube the splines no later than the 6k service.
  17. Callisto224
    Callisto224 Long timer Supporter
    Jan 5, 2010
    8,222
    Smyrna, GA
    Certainly won't hurt anything to drop the FD and check the splines.
    When you do, take pics and post them here. It will be interesting to see how much lube the factory is using on new FD's.
  18. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    18,347
    Zer0-Zer0-Zer0-Zer0
    I don't see why wait for spring time if you can do it now - ymmv...
  19. ADVNoob
    ADVNoob Adventurer
    Jul 20, 2021
    33
    So, I did mine, and to be honest not much lube on the splines... 2021 GS Adv, 2500 km, 3 week old bike.
    What I noticed, is a little tear in the rubber boot along with black rubber pieces/scrapes inside the boot. I might have caused the tear, I tried for a bit to pull the entire boot out in order to clean it properly, but I gave up at some point. Thing is, the area is thinner than the rest of the boot, when pinched between fingers, so not entirely sure it was my fault. Anyone seen something similar before?
    I put some staburags inside the boot along the tear hoping to seal somewhat the gap, but I guess I have to change the boot...
    deadflagblues and Callisto224 like this.
  20. Mr Pou
    Nov 14, 2018
    638
    Southeast TN
    Very dry in there, you'll be glad you did this now. And yes, sadly, you should replace that boot.
