R1250 GS/GSA Handguards ?
Discussion in 'GS Boxers' started by Motorman, Sep 17, 2019.
  1. Motorman
    Motorman Been here awhile
    Jan 27, 2004
    566
    Coupeville, WA
    Howdy Inmates
    So, what did you do with your hand guards ?
    Leave them stock ?
    Changed them for more wind/weather protection ?
    Changed them for more off road durability (if you drop the bike-will they survive? Or not ?
    Changed them cause you didn’t like the color (my GSA HP come with white hand guards-perhaps good for visibility & match parts of the HP but a true bug magnet-won’t be white long)?
    If you changed or added to them-what did you change them to (brand/model) and how do you like them ?
    Thanks in advance for all your comments and suggestions.
  2. Covert
    Covert Been here awhile
    Aug 17, 2019
    225
    Los Angeles
    Fosters, Dale402 and ckindt like this.
  3. Dwit
    Dwit Adventurer
    Sep 12, 2018
    46
    Northern Utah
    I’ve been lusting after the mam ones. They are super cool for hot and cold weather. Plus if anything is strong enough to survive a hit from on of these heavy weights, it’s this. That said there expensive and if you ever have to replace one there’s no Cheap fix.
    gadgettr1 and Covert like this.
  4. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    6,857
    Zer0-Zer0-Zer0-Zer0
    That depends on your intended usage. I don't do off-roading other occasional grave/fire roads so I kept OE with extensions for better weather protection as I do ride in the inclement weather.
    If you do tons of off-roading, you may want to explore getting Barkbusters either entire set or just the al frame and then reuse your OE guards around them... One or more of inmates have done later...
    :thumb
    Covert likes this.
  5. JimVonBaden
    Feb 11, 2005
    91,377
    Alexandria, VA
    I first did this:
    Then this:
    But eventually I will do this:
    I added these for a friend:
    Chris183 and Covert like this.
  6. igi2003
    igi2003 Been here awhile
    Dec 30, 2012
    106
    Northern NJ
    Added cheap Chinese transparent pieces. Not bad.
    NorthIdaho800gsa and Covert like this.
  7. Boxerbreath
    Boxerbreath 2017.5 GS Black Storm
    Feb 7, 2018
    3,885
    Lost Angels County
    Really the stock ones are just fine unless you plan on crashing around.
    The MAM guards are burly and heavy duty.
    I just got the EBay extra coverage plastics for winter. (Second ones that Jim used).
    Good enough for SoCal winters.
    JimVonBaden likes this.
  8. ckindt
    ckindt Been here awhile Super Supporter
    May 9, 2008
    450
    Omaha, NE
    Fixed.
    #8
    Covert likes this.
  9. Dale402
    Dale402 The holder of what's unused Supporter
    Sep 24, 2015
    165
    So Ill
    I have the MAM guards. My other choice is the Barkbuster with the VPS plastics for their adjustability. But the MAM guards look good and are exceptionally flexible.
    #9
  10. Fosters
    Fosters Loner
    Nov 6, 2010
    434
    florida
    Machine art Moto...the only way to fly
    #10
    gadgettr1 and Motorman like this.
  11. OriginalTeamchaos
    OriginalTeamchaos Adventurer
    Aug 1, 2017
    29
    Midwest
    I use MAM ADVance Guard on my GSA and I like them for their adjustability and style. I had Bark Busters on my previous GS.
    #11
  12. nwcycle
    nwcycle Long timer
    Feb 26, 2009
    1,467
    Northern Illinois
    IMG_7936.jpg Had to make something quick, a used set off my desert racing bike, Maier , worked great... will most likely buy a new set and do the same at only $45.00 ;)
    drill a few holes with 3 zip ties
    #12
    AdamChandler and Dale402 like this.
  13. Motorman
    Jan 27, 2004
    566
    Coupeville, WA
    Looks like it’s going to be MAM.
    Thanks for your comments.
    #13
    JimVonBaden and ckindt like this.
  14. Motorman
    Jan 27, 2004
    566
    Coupeville, WA
    Went to order a set and they’ out of stock !
    #14
  15. Covert
    Aug 17, 2019
    225
    Los Angeles
    #15
  16. Motorman
    Jan 27, 2004
    566
    Coupeville, WA
    Out of stock ! Again !
    #16
  17. Chris183
    Chris183 Adventurer
    Aug 18, 2018
    33
    On the road
    Anyone crash tested the MAM handguards yet?
    #17
  18. Covert
    Aug 17, 2019
    225
    Los Angeles
    #18
  19. bigjohnsd
    bigjohnsd '14 BMW R1200 GS Adv Supporter
    Jun 1, 2014
    537
    Spearfish, SD
    No crash but a garage "event", the plastic portion didn't make it through the drywall, MAM sells replacement plastic quite reasonably. DAMHIK
    #19
    Chris183 likes this.
  20. deep6blue
    deep6blue Been here awhile
    Sep 25, 2015
    203
    USA
    I went a little different route. On previous bikes I've made my own handguard extensions. I use Kydex, which is a plastic with a low melting point. It's typically used for gun holsters and such. But I make all kinds of stuff with it. You can heat it with a hairdryer or heatgun, shape it, and let it cool. My work is not museum or re-seller quality, but its functional and I made it. That makes me happy.
    I just did this with the OEM handguard on the 1250. I used a piece of kydex cut to about 4.5" x 6". Simply heat the kydex until it is just pliable (not like a wet noodle), then place it against the handguard and hold for a short time. If you don't like the shape, heat again and reshape. These pieces were reused from a previous handguard. They are attached using double siding automotive tape. This is the same stuff used for car trim.
    For this go version, I noticed the wind was coming off the handguard extension directly at my shoulders. So i used a small cardboard tube to shape it a bit. Now the wind is directed just away from my arm. That little curve made a ton of difference.
    I've used these homemade versions for over 30k miles in the Pacific Northwest. Through all 4 seasons and on long high speed runs on the interstates. No issues at all.
    Admittedly, once the Barkbusters arrive, I'll switch to the Storm covers. but in the interim, these are really great. And depending on the Barkbuster Storm cover effectiveness, I may reshape and add these to them.
    A couple pictures:
    #20
