R12GS with ADV tank
Discussion in 'GS Boxers' started by SQD8R, Apr 12, 2006.
  1. SQD8R
    SQD8R Eat squids and be merry
    Jun 16, 2004
    7,484
    The Village: 52.9144° N, -4.09615° E
    So the first big question,
    Will it fit?
    Well it certainly looks like it. I took off my stock tank and decided to @ least line it up tonight to see where we were on this. Bolt holes lined up well. The fuel lines have to be brought 'in' towards the centre of the tank so that they clear the tank but they do not need replacing. The beak needed to come off only for mounting the new tank.
    Snags so far.:huh Only one really. :D
    This little blue fella aka the sucking jet pump, :lol3 has eaten up the majority of my time otherwise it would have been done by now. I was working to a two hour goal until I met this little fella.
    The problem is that on the original tank this part sits this way
    but it now needs to sit this way
    The way the cap lock is situated requires the reverse position for the SJP. It's hard to see but look @ the black on the right and you can see what I'm referring to.
    So I've reversed the hose, easier said than done. The hose has to clear the fuel pump so that it doesn't interfere with the fuel gauge reading. That could be the root of some people's issues.
    now she fits, it's tight but there's give there. Gettting it to sit correctly on the flange is my goal so I want to adjust the hose some more and make sure that the give I've got isn't going to be a break. :eek1
    That's it for now, flu is kicking in and it's nappy time. :lol3
    I should have it done by today and I will then confirm the fit. :wink:
  2. RICHXHELL
    RICHXHELL Scooterist
    Jul 14, 2004
    3,222
    North Somerset, UK
    Nooooooooooo......who in god's name would want to do such an awful thing to such a svelte and lithe beauty. Personally I like 'em thin :evil
    But do keep us posted on progress, won't you :wink:
    How many openings are then on a normal tank, I'm confused :huh
    Any more thoughts about the Desierto fairing. Think you were thinking of one...???
    I liked one pic I saw of it but then not others. Would make a real adv bike tho in terms of size, presence etc and must come out cheaper than buying the adv itself?
  3. raysuf
    raysuf Lost
    Aug 10, 2005
    1,141
    :clap
    That is great news. Not that it will happen anytime soon but atleast it can be done.
  4. LuckyStriker
    LuckyStriker Lottery Loser
    Oct 11, 2004
    194
    Cape Town, South Africa
    This is a great thread - I will follow it with interest.
    I am especially looking forward to seeing an 'after' pic
    get well soon and finish the project!
  5. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,851
    Geebus SQD! You don't waste any time!!! I thought the installation was for next week!! I can see one of your virtues isn't patience! :lol3
    Thanks for the heads up on that pump.. I told ya that thing's a bitch to take out... I'm getting mine installed by the dealer next week..
    That think looks MASSIVE!! It's a tank and a fairing all in one! :thumb
  6. GB
    Aug 16, 2002
    67,851
    So, did we need that flange after all or not? And did we get all the parts that we needed?
  7. Emoto
    Emoto Sure, why not?
    Feb 24, 2004
    21,339
    SE Mass
    "sucking jet pump"??? WTF is that? :huh
  8. GB
    Aug 16, 2002
    67,851
    on the right side "pod" where the fuel lines are, there's a "sucking jet pump" which is connected in some fashion to the main pump on the left side in order to get the fuel that's in the right side lobes... :evil I think the 1150 didn't have this. Another 12GS advantage.
    #8
  9. Arch
    Arch Incurable Gearhead
    Dec 30, 2001
    11,706
    Katy, TX
    Wonder why they didn't just use a crossover tube, like what's on an 1150 Adventure?
    #9
  10. matey peeps
    matey peeps Bead Buddy
    Dec 5, 2003
    3,343
    Cheyenne, Wyo
    Why use a simple, low tech but effective hose when you can have a whiz-bang electronic item! :deal
    #10
  11. hogmolly
    hogmolly Dude
    May 28, 2003
    3,245
    McKinney, TX and San Jose, CA
    Plastic tank?
    #11
  12. rdcyclist
    rdcyclist Long timer
    Sep 28, 2004
    1,247
    SanHo, NorCal
    'Cause it's not a whiz-bang electronic item. The suck pump operates off the fuel return flow. Actually a very simple and elegant solution to getting the fuel from one side of the tank to the other without putting two more fittings and a hose at the worst place for a failure: The bottom of the tank.
    #12
  13. SQD8R
    Jun 16, 2004
    7,484
    Hey...I'm black...we like'em BIG! :lol3
    There are 3 openings on the regular tank too. The difference here is that the right side opening, from the riders perspective, is horizontal, not vertical, on the ADV tank. The right side has the suck fuel pump. More on that later. The left side has the fuel pump. The centre is the filler.
    I'm still on board for the DIII. I'll be cancelling my TT tank order today since this is a go.
    GB,
    Yeah it looks big but honestly it's not bad until you add the trim piece. Then it looks bulbous. Haven't filled it yet so of course it doesn't feel any different.
    We did not need the flange but we do need the ADV suck fuel pump. It is different. After last nights 3 hour battle with the GS suck pump I came up with an interim solution. But when touching base with Frank this morning I checked to see if it was a different part number. It was the one thing that we really needed. Go figure, Murphy's Law and all that. Anyway I've got an interim solution and I've ordered the part for myself. I suggested you would want it as well so Frank will drop you a line.
    Arch, matey peeps, advman, rdcyclist,
    The suck fuel pump is as rdcyclist says, very simple. It's not mechanical/electrical in any way. Although it sounds it. It's basically transferring fuel from one side to the other, a one way valve of sorts. Basically the hose goes around to where the fuel pump is and equalises the fuel. I don't know why this method was chosen over the 1150 method but the price for the new one is minor so not really an issue. It's easy to install and it does not link up to the fuel pump. In fact the line has to stay completely clear of the fuel pump and the float otherwise it may screw up the fuel load reading. This may be the resolution to many of the fuel reading issues.
    It took me about 6 hours to do it but I've never done this before and the suck fuel pump was a 3 hour ordeal, 2 hours fuming while watching Total Recall and staring @ the part @ 2 a.m. :lol3 I could easily do it in 2-3 hours now with confidence.
    The one thing I did do was pull the throttle cable out a bit too much. Frank advised me of the correction, pushing it back in and all is well.
    Off to take some pics of the final solution and get out in the light of day for a quick ride. :clap Back in a few.
    #13
  14. LBZ-GS
    LBZ-GS RIP, Frank.
    Jun 16, 2005
    168
    30 mins from the Blue Ridge Parkway....
    Great news! Glad to see this is working. Can't wait to see the finished product and I appreciate the kind words. Excellent work SQD8R! Frank
    #14
  15. PawnBroker
    PawnBroker Banned
    Jun 18, 2003
    1,808
    The FughetboutIt State
    :lurk
    PB :thumb
    #15
  16. SQD8R
    Jun 16, 2004
    7,484
    The only other issue I can think of is the throttle cable. It looked like this after tank installation
    and should look like this
    Basically it gets pulled during installation. It's on the kick stand side, and as you can see, just left of the VIN.
    During installation I found moving all 6 connections, two quick release, two vent tubes, two electrical clips, to the centre. It's easy to mount them from there and nothing get pinched. I followed RC46's advice about marking the two vent tubes on the right side but when I followed them down they both vented to the street. One is for water around the gas cap the other for excess gas. But the connector still has a 'W' for water despite them ending up in the same place. :huh Maybe I'm missing something, and someone can elaborate on that some more.
    Here's a pic with the side panel just placed on. The mounts are different from the GS so I could not use the faux dzuz fasteners.
    #16
  17. GB
    Aug 16, 2002
    67,851
    SQD:
    I want to order that sucking jet pump, what's the part number..:ear I picked up my ADV tank today.
    #17
  18. SQD8R
    Jun 16, 2004
    7,484
    Now in the light of day
    It's not lop-sided, :huh remember the air funnel is on the left.
    More to come once I get the proper suck pump and a few trim pieces.
    #18
  19. SQD8R
    Jun 16, 2004
    7,484
    no idea, just drop Frank a note, he's already got it lined up for me.
    #19
  20. GB
    Aug 16, 2002
    67,851
    but you were able to make the bike run with the current setup...
    Looks good.. huuuge but good!! :thumb
    #20
