R80GS Basic clutch adjustment question
Discussion in 'Airheads' started by Kokopelli, Apr 13, 2009.
  1. Kokopelli
    Kokopelli Yeah, right!
    May 2, 2003
    5,106
    Rolleston
    I am now absolutely stumped by this. If I set the measurement 'C' on the diagram to the required 200mm +-1mm I do not get any clutch action, even with the set screw ('4') wound right in. Only at about 190 mm does the clutch work.
    Checked the diaphragm spring against a good one and it's fine. Anyway, the clutch had not been slipping. Tried a completely different clutch, same story. Other than getting quite quick at whipping out the clutch (third time), I've made no progress.
    How can you lose 10mm there? Has the inside of the nylon piston collapsed?
    Should I just ignore it and get on with it?
  2. Sergeant Joe
    Sergeant Joe Sitrep=Snafu
    Mar 8, 2009
    244
    Tasmania,Australia
    I had to play with the adjuster up on the h/bar leaver as well , its fiddley stuff :tough :baldy .
  3. Kokopelli
    May 2, 2003
    5,106
    Rolleston
    I can set it to the 200mm alright, but then it won't disengage the clutch.
  4. Joerg
    Joerg Long timer
    Jul 10, 2001
    1,360
    St-George, Switzerland
    Did you proceed precisely according to the rider's manual, i.e. adjust the cluth using both the screws at the handlebar, and the screw/bolt at the back of the gearbox?
    Are you sure the clutch cable is not stuck somewhere (=hull sitting on an edge, etc.) ?
  5. Kokopelli
    May 2, 2003
    5,106
    Rolleston
    Yep, It's in properly and I followed the manual. I even used a new clutch cable, it does the the same as the old one, which was still good by the way.
  6. Joerg
    Joerg Long timer
    Jul 10, 2001
    1,360
    But what did you do before? I mean, the clutch must have worked at some point in time ... ? :lol2
  7. Kokopelli
    May 2, 2003
    5,106
    Rolleston
    Good point, it did work. However, I never checked what setting it was on before taking it apart. I had the transmission off to fix a seal. Then decided to check the clutch. Which led to the decision to recondition it. The clutch worked well for 1000km and then the plates stuck together.
    When I had first assembled it after reinstalling the reconditioned clutch I had to wind out the handlebar adjuster pretty much all the way to get the 200mm. After separating the clutch plates again and setting the cable up, I arrived at the current situation.
    I then borrowed a second hand clutch with minimal wear and installed it today, to see if the original clutch resurfacing was to blame. Looks like that wasn't the problem either.
    I don't understand the importance of the 200mm set up. If 190mm will make the clutch work,can I run it like it is now?
    Thanks for your input.
  8. jtwind
    jtwind Wisconsin Airhead
    Nov 19, 2004
    3,477
    Madison WI
    I've found that if all parts are right you can play around with the settings to get it to the bmw spec settings. Sometimes you have to move the adjuster on the tranny in or out to allow you to get the barrel adjuster on the lever in the ballpark and vice versa. Why is it important to get it where BMW suggests? Beats me and possibly it isn't. I've always assumed it was due to leverage, clutch pull effort etc.
    #8
  9. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    11,111
    Shoreline, WA
    silly question, did you put the throw-put bearing and push rod back in?
    The manual does say to adjust to the 200mm using the handlebar adjustment and then make the fine adjustment using the trans back bolt...
    Is the handlebar adjuster threaded all the way out?
    #9
  10. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    6,487
    Charlottesville, VA
    Just for those who aren't familiar, the handlebar adjuster changes the 201mm. So once that's correct, the hand adjuster is out of the loop. The question is why you can't get proper clutch action with the arm adjuster.
    If the lever is in the right place, and isn't bent, the problem has to be in the TO bearing, pushrod or clutch. If you can only get clutch action with less than 201, then either the lever is bent or something inside is too short.
    Do you have the old-type TOB with the separate parts, or the new one-piece one? Pix on my website: http://www.largiader.com/articles/throwout/
    If something inside is too short, it'll probably keep getting shorter.
    #10
  11. Dolly Sod
    Dolly Sod I want to do right, but not right now
    Aug 18, 2003
    18,873
    Richmond, Va
    It sounds like you're not adjusting #3 & #4 in your diagram correctly. Once you get the 200mm you should be adjusting #3 & #4.
    #11
  12. Bill Harris
    Bill Harris Confirmed Curmudgeon
    Sep 20, 2008
    9,871
    backwoods Alabama
    You installed a reconditioned clutch-- what did you do to recondition it? There is a somewhat similar problem being discussed over at Boxerworks after a Southland reconditioned clutch was used:
    http://www.boxerworks.com/phorum/read.php?f=1&i=255039&t=255039
    We still haven't figured this one out.
    Years ago, before the 200+1mm spec was used, the adjustemnt was to set the clutch actuating arm to a right-angle to the clutch pushrod. What sort of angle does the clutch arm amke at the 200mm or the 190 mm setting?
    #12
  13. Kokopelli
    May 2, 2003
    5,106
    Rolleston
    Thanks for all the responses.
    All the parts are present and accounted for and in the correct order. The lever is not bent. The diaphragm spring is in correctly. The clutch cable has been adjusted as per manual. Once set to 200mm you adjust the free play with the screw adjuster. At 200mm (adjusted at the handlebars) this adjuster does nothing, even wound in all the way.
    I will now substitute the new style assembly with an older version. I suspect the plastic piston with the built in throughout bearing is to blame, even though there is no obvious fault.
    #13
  14. Kokopelli
    May 2, 2003
    5,106
    Rolleston
    The reconditioned clutch was not the problem, it since been replaced with a standard clutch. The lever is at less than a right angel, it's missing those 10mm. Considering the length of the lever, that's probably only about 2-3 mm at the pressure point. I am almost certain that the problem is with the piston.
    #14
  15. Mista Vern
    Mista Vern Knows All - Tells Some.
    Dec 1, 2005
    23,575
    McMinnville, Oregon
    Hail Mary pass here, but are you sure your old TOB didn't go south and thus lead to the push rod being worn shorter? Stupidly long shot, but what the heck, there are only so many possible variables, eh?
    #15
  16. Kokopelli
    May 2, 2003
    5,106
    Rolleston
    The newer style plastic (nylon, I think) piston has a pretty standard looking bearing, I just remembered that I have pictures :-). The bearing seems fine. The only problem I see is on the other side. Maybe that metal insert got pushed in or is worn out.
    #16
  17. Solo Lobo
    Mar 16, 2004
    11,111
    Shoreline, WA
    For reference...
    #17
  18. Solo Lobo
    Mar 16, 2004
    11,111
    Shoreline, WA
    #18
  19. Wirespokes
    Wirespokes Beemerholics Anonymous
    Jul 26, 2002
    9,632
    Jackson's Bottom Oregon
    I'm not sure I completely follow you on this.
    Are you saying that when the arm is adjusted at 200mm, the clutch lever comes all the way back to the grip without releasing the clutch? And that's with the adjuster at the control all the way out?
    I took care of a 100/7 this last weekend with a similar sort of problem. I'm used to setting the arm parallel to the tranny back cover at half stroke, doing that with the adjuster at the trans. Then adjust the hand lever for a few mm of free play. In this case the adjuster was most of the way out to achieve this, which seemed pretty weird. This is a low mile bike (abt 20K) and looked it. The only solution I can come up with is that the cable housing should be longer, or perhaps make the cable shorter.
    Other than that it worked great.
    BTW, don't get fixated on that 200mm setting - the thing to remember is that for ease of pull, the best leverage is achieved when the arm is parallel to the trans at mid pull.
    #19
  20. Kokopelli
    May 2, 2003
    5,106
    Rolleston
    I am going to install the old style component's as shown on Anton's picture. This should eliminate everything but the user and the clutch cable as being faulty.
    With the lever at at 90 degrees, or parallel to the housing I have my 200 mm. Unfortunately at this stage, even with the screw wound right in I have no pressure against the piston. This tells me that something is shorter than it should be. I think the cable can be ruled out, because I can achieve the 200mm and the 90 degree angle. So the problem is that the adjustment screw can't reach the piston. The screw is standard, as a matter of fact I am even using a different lever at the moment.
    This really rules out all the parts, apart from the piston and possibly the clutch rod itself. There is no wear visible on the clutch rod that might affect the length. The hole in the diaphragm spring is not enlarged.
    It will come down to the piston, clutch rod, or me being a complete idiot. If this thread goes all quiet soon, you'll know which.:lol3
    Again, all input is most appreciated.
    #20
