R90/6 cylinder over bore
Discussion in 'Airheads' started by arbalest, Oct 11, 2021.
  1. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,517
    Windham, Maine
    Can R90/6 cylinders be bored to 94mm (R100 bore)?
  2. bmwrench
    bmwrench Long timer Supporter
    Nov 10, 2006
    9,141
    Maybe, but the liner would be quite thin. What year is the engine?
  3. Beemerguru
    Beemerguru Beemerguru...G/S guy
    Nov 7, 2006
    2,675
    Redwood City, CA
    You'll end up with the same experience as the 1050 kit sold at an independant BMW fab shop back in the '80s and '90s.
    Great for racing but ovaled out within a few thousand miles of touring..thin walls and heat don't mix for long.
    Cogswell and SmittyBlackstone like this.
  4. Disston
    Disston ShadeTreeExpert Supporter
    Aug 31, 2009
    19,056
    Silver Spring, Md
    Not advised. You would end up paying for something that is not useable most times. Even if it works the liner will be so thin it may wear thru in a hundred miles or so.
    If you want bigger bores buy the kit or find some R100 cylinders with pistons that fit or can be made to fit. Used parts are a squeeze these days so smart money is on the kit.
    SmittyBlackstone likes this.
  5. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,517
    Windham, Maine
    76
  6. Disston
    Aug 31, 2009
    19,056
    Silver Spring, Md
    A 76 engine has the large bore case and is an easy swap to late model nicklesil cylinders and Pistons.
    bmwrench likes this.
  7. bmwrench
    Nov 10, 2006
    9,141
  8. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,517
    Windham, Maine
    #8
  9. bmwrench
    Nov 10, 2006
    9,141
    The piston pictured is for '81 on R100. I have them for a variety of Airheads.
    #9
