R90/6 hop up questions
Discussion in 'Airheads' started by arbalest, Jan 27, 2021.
  1. Beemerguru
    Beemerguru Beemerguru...G/S guy
    Nov 7, 2006
    2,677
    Redwood City, CA
    Did you also replace the needle and atomizer
    #21
  2. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,522
    Windham, Maine
    I have not replaced anything yet. So, I should replace the needle and atomizer? Bike has about 32k miles.
    #22
  3. bmwrench
    bmwrench Long timer Supporter
    Nov 10, 2006
    9,152
    I'd look at ignition timing. Boyers often have slow or short advance, and this can really affect mileage and power. However, one should expect poor mileage with a sidecar rig.
    #23
  4. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,522
    Windham, Maine
    Mileage was lousy before the Boyer was installed. I do expect low fuel mileage from a rig, but it was low before the rig was installed.
    #24
  5. mattcfish
    mattcfish R90X Supporter
    Feb 6, 2008
    843
    Bellingham, WA RAIN or shine
    The R90 heads work great, but you need to either widen the squish band (best solution) or buy the Siebenrock kit with stepped pistons. Bigger valves actually rob power at most of the rpm’s you deal with on a street bike because the velocity of the mixture is reduced and the valves are heavier and have less piston clearance. This increases their tendency to float and do damage. Especially true with a cam.
    #25
    infinityedge and Disston like this.
  6. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,522
    Windham, Maine
    Update. Replaced the jets and jet needles in the carbs. The rig now gets 36 mpg with a 37/11 final drive. Now I am told by my son, who was riding behind me, that the bike is smoking blue smoke. Looks like a top end job is in the works. That said, how deep should I go?
    #26
  7. bmwrench
    Nov 10, 2006
    9,152
    Here's your chance/excuse to go to a bigger bore.
    #27
    Kiwiabbo likes this.
  8. Kiwiabbo
    Kiwiabbo Long timer
    Apr 16, 2014
    1,588
    Taihape New Zealand
    On my chair bike I run 100 cylinders with r80 heads on it. No modifications and I get very good low down power. Runs out of puff a little on the top but you are not doing that on a chair bike. Still have the 33/11 final drive and it sits very nicely at 70mph.
    #28
    spo123 likes this.
  9. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,522
    Windham, Maine
    With a 37/11 final drive, I cruise at 70 at 5500 rpm. I assume that with the R80 heads and R100 cylinders I would still be able to do that? Did you rejet the carbs? To 32mm R100 jets?
    #29
  10. Kiwiabbo
    Kiwiabbo Long timer
    Apr 16, 2014
    1,588
    Taihape New Zealand
    135 main. I’m cruising at about 4000k
    #30
  11. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,522
    Windham, Maine
    I guess that's the difference between 37/11 (3.36:1) and 33/11 (3.0:1). What are you running for wheels/tires on the tug?
    #31
  12. Kiwiabbo
    Kiwiabbo Long timer
    Apr 16, 2014
    1,588
    Taihape New Zealand
    Standard wheels and tyres at the moment but may look at the metzler sidecar tyre for the back when it needs changing
    #32
  13. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,522
    Windham, Maine
    Changed the needles and needle jets. I am quite happy with the mileage I'm getting. With the lower gearing and sidecar attached, I'm getting the same mileage I got without the sidecar and taller gearing.
    #33
