I've got my twin air filter installed but it's pressing up against the ecu cable. Any concerns with this? I'm worried that is going to wear through the foam.
I’m installing the F4 tower on my 2019 HSQV 701 right now but I can’t find the manual. Just the one for the F3. Is there a manual for the F4? //Johan
Yes, but in a different form. Based on all of the questions we are getting we decided to switch to videos. Here is the detailed, step by step guide for RADE/GARAGE F4 rally kit install:
Yes I watched it but the mount is not really the same.. but the video is still good Is the bar raiser supposed to be included for 2019 701?
Has anyone installed a Trail Tech Vapor (or any other model) on their R/G tower in place of the stock speedo? If so, can you provide pics and any installation info specific to the tower and the Trail Tech unit?
Todd did his install (not on the tower) and described int he 701 thread - I assume just use 12mm clamps for our crossbar and hook it up - https://advrider.com/f/threads/husqvarna-701-super-moto-and-enduro.1086621/page-1607#post-39632862 EDIT: Looking at his pictures it looks like the Vapor uses standard AMPS mount (same as GPS) - in that case just buy our GPS mount and you are all set (Verify with Trailtech first!)
Thanks but I was hoping to find out if the trail tech dash will clear the lights and bar, and also if it uses the same mounting holes as the stock dash. I need to keep my AMPS mount for my GPS.
Definite NO on the stock mounting holes. The clearance is very likely OK, but you need to look at the Vapor's height spec and verify.
Just picked up a 701 with Rade Garage rally tower (F4 fairing). It's a fantastic set-up!!!! Going to add a Garmin XT to the tower. I see the part with Rage Garage to mount the Garmin, but I don't see the XT listed. Do I also need to pick up the Garmin Zumo XT mount bracket that Revzilla lists to hold the XT? https://www.revzilla.com/motorcycle/garmin-zumo-xt-mount-bracket?sku_id=10004592 Thanks, John
