Hi, we should have some stock next week, but we have to do the pictures and manual first to build the landing page. So it still could take 2-3 weeks to see it on our website.
I have the Cycra center mount handguards on my 701. Is there enough clearance so the handguards and the mounts will not contact the fairing when the bars are turned?
HI RADE I have already purchased and received my box of goodies from you but have yet to fit it to the bike ( tank kit and fairing kit ) I also have purchased the scotts steering damper BRP sub mount , does the damper fit with your kit ? 701
Yes it does. Have seen pictures of that combo. You might have to dremel/cut ablittle piece out of the carbon lock/tankfiller cover. Picture is not mine. Was also looking if this would fit together.
good choice of skid plate. mine just arrived this morning. ideal place to keep the tools and at the same time provide protection. the quality and built are 5 stars.
No, it will not fit, however we have the 690 storage box in stock! They are so new we don't have them on the web yet. If you order 701 and put into the notes that you need it for 690, we will ship you the correct one.
Hi Max, not at this moment, however we do value our customers and recently had a customer appreciation event. If you ask around you will find we thrive to provide kits and parts that are upgradable so when we improve and innovate you don't have to replace the whole kit. We spent a lot of time thinking about that and a lot of work goes into that philosophy. We hope you become one of the happy customers and can benefit from the future "specials"....
Hi, we have tested few ideas ("paper prototypes") and now we are in stage of 3D modelling. So we go according to the plan and Feb is realistic. Rade
On page 14 of the auxiliary fuel installation guide, there's this instruction: "Summary of this step: 2 × 4 mm holes must be drilled into the black plastic fuel pump cover. One directly behind where the banjo bolt goes on the aluminum spacer." I understand the purpose of the first hole but not the second. What does it do?
Hi Rade , I did contact you via Pm but i think it would benefit others who have purchased your kit to know that I drilled a 6mm hole in the fuel pump housing opposite the outflow and the flow rate was very low to drain the RADE tank into the main tank. I subsequently drilled a 8.5mm hole and it drains much quicker And i like to thank you for your prompt service , good products too
Hi Rade, On the 701 fairing kit, how does it work with turn signals? In some customer pictures I see stock turn signals, in some of yours I see tiny little signals that aren't stock, and in other pictures there are no turn signals at all. If I order a fairing, will it have integrated turn signals, will I reuse mine, and do I have to drill my own holes for the turn signals?
There are no holes in the sidepanels. You can drill holes and add the stock signals. Rade does supply a set of the small signals. I guess thats what you saw in pictures. The choice is yours what you want to use.
HI Rogier , can you please tell me what type / model is the tail bag you are using on your bike in the photo above ?
