RADE/GARAGE kits and accesorries for Husqvarna 701
Discussion in 'Vendors' started by RADE/GARAGE, Sep 4, 2018.
  1. Toejamii
    Toejamii Still Learning
    Jul 31, 2015
    711
    Brisbane
    Recently purchased the new shader fir the front tower be a good idea to buy 5 mm longer screws to fit same makes life a lot easier to get the rubber nuts to bite
    I used a dremel to cut the tower worked well
    #81
  2. warechris
    warechris n00b
    Aug 19, 2015
    2
    Portland
    Just ordered my fairing kit today. Super excited to get it!
    #82
  3. Toejamii
    Jul 31, 2015
    711
    Brisbane
    I'm posting this to show anyone how to fix an issue with tearing mudflaps on the 701 , use a heat gun to put a permanent bend into the mudflap as the rade garage fuel connector on the tank pushes the flap forward into the tyre . couple this with an aggressive knobby and you get damage IMG_3680.JPG IMG_3681.JPG IMG_3682.JPG
    #83
    Woundflatout, KiwiPewe and AliveDK like this.
  4. new2adv
    new2adv Converting gas into wheelies since 1974
    Nov 5, 2018
    993
    Great White North
    #84
  5. RADE/GARAGE
    RADE/GARAGE Been here awhile
    Aug 24, 2018
    125
    Seattle
    #85
  6. new2adv
    Nov 5, 2018
    993
    Great White North
    Thank you Rade. Order has been placed. Looking forward to installing them, and the aux tank as well!
    #86
  7. new2adv
    Nov 5, 2018
    993
    Great White North
    OK I now realize that my previous post might be confusing... I'm not planning to install the aux tank on a 790. I have a Husqvarna 701 now, and I will install the footpegs and tank on this bike. But I do plan on upgrading to one of the bigger KTM adventure bikes in the future, so it's good to know that the footpegs can be used on the 790.
    #87
  8. Poanos KTM990
    Poanos KTM990 n00b
    Apr 12, 2019
    2
    Athens Greece
    Hello everybody,
    I have the aux gas tank for 990 (not the one of picture, i 've ordered it summer of 2018). Unfortunately the hose bulb (see picture) broke cause of my fault. The rest piece is still on the tank. Is there any way to replace it? I wonder if i could put some quick release solution. Thank you in advanced for your comments. tank.jpg
    #88
  9. RADE/GARAGE
    Aug 24, 2018
    125
    Seattle
    #89
  10. zoink
    zoink Been here awhile
    Mar 8, 2012
    267
    SW VA
    I am interested in the rear rack for the husqvarna 701 enduro. There's no underside shots that I can find of the rack. Are these two bolts in this picture used to mount a rear support/bumper type object
    like in this image of the perun rear rack
    Also do you have a weight figure for the complete rack setup? Thanks.
    #90
  11. RADE/GARAGE
    Aug 24, 2018
    125
    Seattle
    Hi,
    a/ no we dont have such "bumper", because we have bents on the sides and reinforcement via the welding in the corners
    b/ our rack is from aluminium so both parts are less 1KG
    Regards
    Rade
    #91
  12. new2adv
    Nov 5, 2018
    993
    Great White North
    I installed the auxiliary fuel tank last night, as per the instructions on the website. Tried to start the bike this morning, it won't start. D'oh!
    I have about 3-4 litres of fuel in the OEM fuel tank. No fuel in the auxiliary tank. The petcock is closed.
    I can hear the fuel pump prime when I turn the key on.
    Before I tear this apart - any ideas on what I should check? Any common issues with this installation? Thanks in advance.
    #92
  13. Tijuana_Taxi
    Tijuana_Taxi Been here awhile Supporter
    Jun 20, 2009
    955
    Boise,Idaho
    Make sure the stock quick release fuel line connector is fully snapped together.
    #93
    KiwiPewe likes this.
  14. new2adv
    Nov 5, 2018
    993
    Great White North
    Yup, thanks, that's a good idea. I checked it - pulled it apart, put it back together, it's definitely connected. Stupid thing still won't start.
    Pulled the pump out of the tank, it whirs and spins when I turn the key just like I thought it was.
    There's a bunch of plumbing inside the tank - two fuel lines, wires to power the pump, a screen on the pump intake and a filter downstream from the pump. I'm learning lots here... but I just want this thing to run!
    I guess I'll have to go back to basics - spark, air, fuel...
    #94
  15. new2adv
    Nov 5, 2018
    993
    Great White North
    So, I checked the fuel connector again and damn if it wasn't quite connected! It went together but it didn't "click". Once I got the two pieces solidly clicked together, the motor started no problem. Thanks again for the tip.
    #95
    GalacticGS, KiwiPewe and Tijuana_Taxi like this.
  16. DirtJack
    DirtJack Adventurer Supporter
    Aug 12, 2007
    3,326
    395 miles South East of Orla, Texas
    Always use a bit of lube on the male portion of the connector (including the O ring). It will make the next use of the connector much easier.
    #96
  17. RADE/GARAGE
    Aug 24, 2018
    125
    Seattle
    This is the most common issue - we have seen few people pulling their bikes a part only to find they only need to "fully" insert the quick connect...
    #97
  18. new2adv
    Nov 5, 2018
    993
    Great White North
    Overall I’m happy with the aux fuel tank. I did notice that fuel was leaking out of the vent on the cap. I used some safety wire to secure the vent tube to the cap and that seemed to stop the leak.
    #98
  19. Rusty99
    Rusty99 Adventurer
    Mar 2, 2019
    30
    UK
    Hi I am also having an issue with the vent tube falling off, lost one somewhere in Scotland ! Have put another tube on but as said before the nipple is so small that the pipe just comes loose after awhile.
    I like the metal cap, but don't really want to start gluing pipes on as petrol will eventually dissolve it. Is there another cap metal preferably that will fit the Rade tank.
    #99
  20. Toejamii
    Jul 31, 2015
    711
    Brisbane
    Get rid of the metal cap and get a small KTM plastic one solves problem of vent tube and also the metal cap thread was so sharp it was cutting into the plastic tank every time you take it off and put it back on.
