1. Livestream NOW at 9pm EST / 6M PST! Any Questions for Marc?
    Baldy + Alta CEO & Co-Founder Marc Fenigstein YouTube Live Chat here
    Dismiss Notice
RADE/GARAGE kits and accesorries for KTM 1090/1190 Adventure
Discussion in 'Vendors' started by RADE/GARAGE, Nov 23, 2018.
  1. davevh
    davevh At the dirt
    Nov 1, 2006
    237
    Texas
    Have about 400 miles on this now. Lights are a significant improvement, even quite a bit better than the 1290 LED's. Taken it up to 90 and for my height, 6'3" there is a lot less buffeting than stock and pretty much just clean air to my helmet. I have not noticed flex on the windshield, though that is not something I looked out for. The way it is mounted and with the curvature of the design I cannot imagine it distorting much.
    If you reference the photos you can see that the windshield is mounted at 6 points so yeah, pretty rigid.
    Attached is a recent trip to Arkansas, 0 issues.
    Hope that helps!
    #41
    runehogh likes this.
  2. 2LTwhlrider
    2LTwhlrider Been here awhile
    Oct 14, 2016
    137
    Nor CA
    I just started looking at the Rade kit and found this thread and am curious now that several inmates have had a few months with their kits, what thoughts you have? My biggest concerns are wind buffeting (I wear a visor on my helmet and am 6'2 with a tall seat so about the height of a 6'3 rider) and improving the lighting. Rather than new LED bulbs and a new aftermarket windscreen, the Rade solution may bundle everything in one kit. @daveh noted how well his worked and I'm near his height so interested in the other experiences and if over time things are still working out well.
    Also do the lights work as well than LED replacement bulb options out there - or perhaps better?
    Lastly, is there any issue with the windscreen "glowing" at night from the lights?
    It sounds like Rade has been open to the installation input provided so mainly concerned about functionality and how things are holding up. Thx
    #42
    ScooterNoMore likes this.
  3. STLR
    STLR Been here awhile
    Jan 21, 2017
    403
    SoIL
    Steve,
    Unfortunately I no longer have the bike, but I did put it through its paces when I did. My only concern with any windshield/fairing like this is quick parts availability as I am hard on my off road bikes. I had no concerns with the light pattern/throw and never tried a replacement LED so cannot comment on that difference. There is a slight glow due to bleeding over, but the Rade crew did a decent job of isolating the light housing and cover. I did not experience unsettling buffeting but I am also shorter than you at 5'10" (even though it's more dependent on torso length). I have sold bikes due to buffeting alone that I could not get corrected.
    Overall I was very pleased and wish you the best!
    #43
    Hopey likes this.
  4. 2LTwhlrider
    Oct 14, 2016
    137
    Nor CA
    Wes, great feedback and you touched on good points. Hopefully, MRA will continue to supply Rade with replacements.
    Thanks much
    #44
    STLR likes this.
  5. Fastindian
    Fastindian n00b
    Mar 1, 2017
    1
    I'll add my 2 cents to this.
    I purchased the kit and the delivery was quick. But...
    As previous guys, the instructions are bad. The video skips over important details and the pdf skips over others. I had to jumps back and forth between the 2.
    Why do you put 2 types of seals in the package, which do we use?
    I am left with hardware as well, why?
    A few holes did not align properly and when you pay 600 euros it's a disgrace to be honest.
    The products looks great and I have yet to test the screen and the lights properly but really RADE get you act together and offers a product/service that matches your prices.
    #45
  6. RADE/GARAGE
    RADE/GARAGE Been here awhile
    Aug 24, 2018
    106
    Seattle
    Hi,
    I am sorry for inconvenience, on the other hand this is not standard feedback we get from customers buying 1090 RR kit.
    We have already improved the instructions based on customers feedback and they approved it as good now - I just want to say WE DO CARE about the cutomer service!
    Now to help you with installation. Please what you see as miss-leading in our instructions?
    Also please send me pictures what is not agligned? I am sure we will sort it out.
    The best if you send me email to rade@radegarage.com
    Thanks Rade
    #46
  7. 2LTwhlrider
    Oct 14, 2016
    137
    Nor CA
    Just completed the install of the RR kit and here are some of my experiences and feedback to add to the discussion:
    -Communication with Rade was quick and easy. He was very responsive to my many questions before and after the purchase.
    - I too had a few extra nuts and 2 types of seal tape. Extra bolts/nuts are always appreciated and I sent Rade a PM about the tape and he provided the insight needed to complete the install with the correct sealing tape.
    -Found that installing the distance spacers by hand then screwing one of the supplied bolts into the end, I was able to tighten it and then just back out the bolt while holding onto the spacer worked fine.
    -Adjusted the lights before installing the mask or windscreen but found the supplied LSK headlight instructions provided incorrect measurements. The LSK installation guide lists "A" (ground to center of headlight at 10 m -~33ft) to be 0.15m, which is about 6" with my math. That does not sound correct.
    -Aligning the headlight cover, headlight mask, and windscreen were a bit of a challenge as many have commented. Parts did not line up like a KTM powerparts accessory but I kept the these items loose until all the threads were started in their respective nuts, then tightened.
    -Final alignment issues for me were: The headlight cover sits about 3mm closer to the right (nearer the to the right inside of the rr windshield when looking at the bike). The top/outer edges of the orange decal does not align with the outer cut line of the upper part of the headlight cover (mine was a couple mm's narrow on both sides in the upper section). The top light does not sit concentric in the carbon headlight mask, although the bottom light is centered fine. Lastly the headlight cover bolt holes are too narrow and force the upper part to bow away from the carbon mask. I doubled the sealing tape in this area to get a seal and hopefully keep water out. I suppose I could do some tweaking with the dremel tool, but these alignment comments are not really noticeable unless inspecting for fit and finish detail. Pics are available if anyone would find helpful.
    -After my first brief ride I found the wind protection to be a huge improvement over the stock windscreen (which was one of the main reasons for the purchase). I'm 6'2" and ride with a tall seat and found good protection from about the shoulders down and air coming at my helmet but it seems to be clean air and not turbulent like the stock screen.
    - The other main reason for the purchase were to improve the lights, and do they work! Very pleased and would be glad to post pics if anyone is interested.
    - Finally, I think the kit looks great and that's always a good thing.
    Overall very happy with the purchase and am glad Rade and his company provide innovative kits like this.
    #47
    ScooterNoMore and Sxywrxy like this.
  8. Sxywrxy
    Sxywrxy Adventurer
    Dec 10, 2018
    54
    Nevada
    Pls post pics of fit and finish (details)
    #48
  9. 2LTwhlrider
    Oct 14, 2016
    137
    Nor CA
    The bottom light fits perfect, the top is not centered with the mask. ...left and right gaps
    #49
  10. 2LTwhlrider
    Oct 14, 2016
    137
    Nor CA
    A little hard to see the layers of material in the photo, but the two layers of sealing tape are noted in orange and is only doubled up in the area in the photo to fill the gap. The green arrows are the to the headlight cover.
    Again, overall very happy with the product since most of this could be worked out with some time using the dremel and elongating some holes.
    #50
  11. Bardockion
    Bardockion Adventurer
    Jun 11, 2019
    15
    Netherlands
    I saw these headlights a while ago and fell inlove straight away. So on a thundery evening, with a lot of rakija (balkan booze) i ordered them.
    This morning i installed the headlights, but i had a few small problems during the installation.
    It all started with the black long screw spacers, i had no grip on them.
    So i made some grip using ductape (pic 1). After i got them snug and killed my hand i removed the ductape and cleaned the tape residue with rakija (don't worry, i still drank it).
    After getting a bit tipsy i misaligned the sticker a smidge and drank a bit more rakjia. After putting everything together it looks awesome (pic 2).
    I am very happy with this purchase and with the rakjia, cheers.
      File size:
      716.4 KB
      105
      File size:
      319.7 KB
      101
    #51
    CaseyB likes this.
  12. RADE/GARAGE
    Aug 24, 2018
    106
    Seattle
    Hi, thanks for your short installation report! :-)
    I know, but the spacers are fine just finger tight, because they are secured by the windscreen...
    I will think of adding a bottle of rakja to every kit for more smooth installation :-)
    cheers
    Rade
    #52
  13. DeeGee
    DeeGee I'm a Yorkshireman thanoz
    Jan 2, 2008
    1,915
    Up North In The UK!
    Hi guys I’ve just finished installing the very same screen. There’s a post earlier regarding the long black rubber seal asking where it fits? the sponge grey one in Rades instructions goes under the light screen, but there’s no clear instruction as to where the long black rubber strip fits and nobody has answered the Q.
    can anyone tell me where it goes please?
    Cheers
    #53
  14. Skilmose
    Skilmose n00b
    Mar 25, 2020
    1
    Denmark
    just about to invest :-) it looks awsome and one can never have too much light,
    but can you tell wether it is road legal in Denmark?
    #54
  15. RADE/GARAGE
    Aug 24, 2018
    106
    Seattle
    Hi it should be road legal in Denmark/EU, because:
    a/ the LED headlights are road legal in Europe an you will get copy of the certificates
    b/ we have MRA TUV paper for the windshield
    cheers
    Rade
    #55
  16. davevh
    davevh At the dirt
    Nov 1, 2006
    237
    Texas
    I would say contact Rade directly, not sure how much this thread is monitored.
    #56
  17. RADE/GARAGE
    Aug 24, 2018
    106
    Seattle
    Cheers
    Hi, there are two mesh... on kind of gray from MRA... this one keep as spare and rather use the one supplied by us - black one and stick it on the headlights cover from the backs side... and from the front it is hidden behind the orange sticker.
    Rade
    #57
  18. Electorn
    Electorn Adventurer
    Jan 12, 2019
    25
    UK
    Hello all, I have just installed the kit on my 1090 but I have a DRL warning on the bike and the lights alternate between the upper and lower lamp illuminating. I guess I have connected something incorrectly. Anyone else have this and fixed it?
    #58
  19. 2LTwhlrider
    Oct 14, 2016
    137
    Nor CA
    It's been awhile... but if I believe there is a DRL setting in the menu settings that you configure to off mode.
    #59
  20. Sxywrxy
    Sxywrxy Adventurer
    Dec 10, 2018
    54
    Nevada
    Finally installed my RR kit from Rade Garage.
    +1
    #60
