Rade Garage Pannier racks
Discussion in 'Parallel World (790/890)' started by Toddv, Nov 7, 2019.
  1. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
  2. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    5,941
    Ontario .. Superior
    I wish they had created a narrow, but symmetrical, design so we could mount a tool tube on the left side.
    No-Fret and Toddv like this.
  3. Stockhaus
    Stockhaus n00b
    Jul 21, 2017
    1
    Sweden, BorĂ¥s
    I have ordered and waiting for delivery. But I have not received an estimated delivery time yet...
    Toddv likes this.
  4. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    They look like the best option out there to me really, was just wondering if anyone had tried them out yet since they aren't cheap or easy to send back if there's an issue. I have the Kriega side bags and they are all setup for them also.
  5. hcd
    hcd Adventurer
    Nov 8, 2019
    51
    30161
    I have them. Very solid, the holes all align properly, no need to stress the tubes to make things line up.
    I had to take the Akrapovic off to deal with that bolt on the right, the reach of the bolt put it into the pipe, other than that the install was easy enough, all the holes aligned with the bike, no stressing of the tubes to get things lined up. Just attach loosely at all points then tightened it up.
    I do have one problem, I got Kriega OS 32 panniers because the racks have tabs welded on to hold the panniers. No matter how much I curse, I can't get one of the buckles through without removing the plastic panel. The buckle hits the panel and it just won't go through at that angle. So it looks like I am either going to have to mangle the plastic or remove it every time I put them on and take them off. I don't know whats going to happen when I fall on them, since there is no cross bar on the racks and there will be no "cage".
    Toddv and Stockhaus like this.
  6. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    Hmm, I see. So you cant feed the buckle through with the bottom first so there would be more room between the rack and the plastics? I'll have the same setup so hopefully there's a solution.
  7. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,678
    Cremona, Italy
    Bend the tab outwards a bit?
  8. hcd
    hcd Adventurer
    Nov 8, 2019
    51
    30161
    I ordered the Kriega rack platform for that side to see if that gives enough clearance, probably have to cut that tab off if it does.
    #8
  9. svneko
    svneko What?
    Dec 12, 2011
    174
    Be interested to hear how they stand up to a fall. Without the bar going behind the tire connecting them like many racks have, I wonder if they will bend or break at the connection point upon impact in a fall.
    #9
  10. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    I ordered mine a few weeks ago and have Emailed a couple days ago to get an idea when they will be shipping but have not heard anything back.
    #10
  11. hcd
    hcd Adventurer
    Nov 8, 2019
    51
    30161
    This is my inelegant and expensive fix to get the top buckle through on Kriega panniers, the Kriega platform is supposed to be unneeded because they welded tabs on there specifically for those panniers. The platform won't work using the recommended positions for the clamps so I stuck the clamps wherever I could get them to line up and leave enough space for that buckle, it's only one buckle that has an issue.
    I know, it looks like enough space to just take it through the welded tab, but there isn't. It just barely gets through on the platform, it would be no fun putting on a loaded pannier. I'll probably cut that welded tab off or put some spacers on the clamp to move the platform out a little more. There's probably a simple solution to this, which is why it escapes me.
    Using the welded tabs for the bottom
    #11
  12. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    I ran into the same issue on the left side. I was able to pop that panel off, install the bag then pop it back on fairly easy. There are two pegs that pop outwards at the front of the panel then it slides forward to unhook at the rear. It takes a little finagling to get it back on but it's not a pain once you've done it once or twice.
    #12
  13. MN rider
    MN rider Adventurer
    Mar 1, 2018
    89
    MN
    Been looking into these aswell. What's the width of the racks when mounted on the bike?
    #13
  14. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    19.5" or 50 cm.
    #14
    floalex likes this.
  15. MN rider
    MN rider Adventurer
    Mar 1, 2018
    89
    MN
    I ordered a set, but the price for shipping needs to be looked at. They want $114 USD. I've ordered sets of crash bars in the past from heed in Poland and was charged $50. I think it will be hard for them to compete with these racks at over $400 USD total.
    #15
  16. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    Yea, it was a bitter pill but they fit the bill so... It was either that or Fab up the ones I wanted. I actually have more space than needed with these on the right side, I guess because the Wings exhaust I installed it's the bike tighter. They could be close to an inch slimmer.
    #16
  17. MN rider
    MN rider Adventurer
    Mar 1, 2018
    89
    MN
    I agree, they look like the best option aswell. The stainless is nice, and that you do not have to keep the factory rear pegs, which I always remove. The only other set on the market that is somewhat similar is the ones from Andy Strapz. R/G ships fast, i had a tracking number within 10 hours of placing the order.
    #17
  18. slink
    slink Been here awhile
    Feb 19, 2015
    250
    Estes Park, CO
    Any experience with these racks in a fall or dirt nap and the lack of a cross bar connecting the racks?
    #18
  19. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    They seem pretty solid. the one on the right side would be the week point due to the tubing going around the muffler but they did a good job of triangulating the mounting points.
    #19
  20. KTM214
    KTM214 Adventurer
    May 25, 2018
    21
    76023
    Have anyone tried the Rocky Mountain "Tusk" luggage racks on the KTM 790 Adventure yet? I had them before on the Africa Twin and there are very solid, but I would like to know how they fit on the KTM 790 ADV and also measurements since I have the Rade Garage rally exhaust. I will appreciate your feedback. Thanks!
    #20
