Ralle-moto mdc damper rebuild
Discussion in 'Dakar champion (950/990)' started by Fierce Beagle, Sep 12, 2019.
  1. Fierce Beagle
    Fierce Beagle Been here awhile
    Mar 20, 2016
    125
    Lake Norden SD
    I have on-again off-again hang up on my steering for the 2010 990R. Most advice points me toward steering head bearings, the bike has 50,000 on it. I have a Ralle-moto mdc damper on it and am more suspicious of that than the bearings because of the way the issue feels. It feels like a dampening effect resisting my steering away from center. Like if you were walking and leaned to take a step and found you weren't able to move your feet for a split second. It feels this way even if I have it turned to setting 1.
    Anybody able to point me to a rebuild kit or information on the damper.
    This winter I will tear one or both of the bearings and damper and rebuild.
    thanks
  2. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,237
    SWEDEN, Norsjö
    Arm from damper binding on pin?
    Caused odd feel on my friends 525.
    Light touch with sandpaper in the slot on the arm and all feels fine after that.
    /Johan
  3. Fierce Beagle
    Mar 20, 2016
    125
    Lake Norden SD
    I’ll check it out and give that a shot, thanks!
  4. GezwindeSpoed
    GezwindeSpoed Long timer
    Jan 15, 2009
    1,027
    The land of the Dutchmen
    Can you take the damper off easely to check if it is the bearings or the demper
    I have never service my Scotts damper in 7 years
  5. Fierce Beagle
    Mar 20, 2016
    125
    Lake Norden SD
    Took off the damper tonight, definitely the culprit. On the lowest setting, moving it by hand is catching.
    Steering bearings feel great with damper removed.
  6. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,091
    NW Sydney, Australia
    Ralley Moto dampers are absolute rubbish, I had 3 fail and 2 replaced and when I stripped the third, I was shocked, its total rubbish.
    Bin it and fit a Scotts.
    I have photos of it disassembled if you wish to see the pathetic design and poor machining.
    Sorry, but they are a thorn in my side!
    Wonkyconk likes this.
  7. LTKernel
    LTKernel jack of all trades... Supporter
    Nov 14, 2013
    413
    Utah
    I have had an RM1 on my 990R for almost five years. I am satisfied with it and I have ridden it plenty through ruts, rocks, and deep sand. It is now leaking, but a couple offs that tweak the steering sharply and those seals are challenged to contain the force of that oil moving quickly. Of course, I probably should have serviced it sooner. I use Scotts on my two smaller bikes.
    You can contact Ralle Moto and ship it back and forth to AU at great expense, or source the o-rings, a screw, and oil yourself and do it. PM me with model if you want instructions and let's keep in touch about sourcing parts. It's going to be a winter project for me soon.
  8. 1coolbanana
    Aug 25, 2009
    6,091
    There are no seals or bearings, its metal to metal and O rings.
    Very piss poor design.
    Dont be surprised if its full of swarf as well.
    I have all the disassembly pictures if anybody requires them.
    #8
  9. LTKernel
    Nov 14, 2013
    413
    Utah
    Who said anything about bearings? An o-ring is a seal.
    #9
  10. 1coolbanana
    Aug 25, 2009
    6,091
    An O ring is designed as a static seal , not for rotating or sliding shafts, its a terrible cheap and nasty way to do it.
    Have a look at a quality unit like a Scotts and you will see how disgraceful the design and build is of the RM units.
    The RM is even worse than that, it uses the O ring AS the bearing and the seal on a single sided unsupported shaft.
    They are a rubbish design, designed by people who have no clue no matter how you look at it.
    #10
  11. Fierce Beagle
    Mar 20, 2016
    125
    Lake Norden SD
    Here are pics of my damper model. Looking for rebuild data.
    #11
  12. 1coolbanana
    Aug 25, 2009
    6,091
    Its a very simple unit.
    Theres nothing much to replace except O rings and the oil.
    Just carefully take apart, it will all be pretty obvious when you disassemble and youve got it in bits.
    Just be careful with the lid O ring.
    #12
  13. Cafeducati
    Cafeducati Stuffing my face with that 990 Steak
    Oct 10, 2011
    91
    Pacific NW
    Plz send me the rebuild data and pics if able.
    I have the same unit and mine does not have any issues,... yet.
    But in the case that it does, I would like to have to option to rebuild it.
    Please and Thank You
    #13
