Rally 1200 Sportster! formerly The GO-SPORT adventure!
Discussion in 'Some Assembly Required' started by tobiism, May 26, 2016.
  1. tobiism
    tobiism Long timer Supporter
    Jun 28, 2011
    1,999
    Chandler AZ
    AK650, villageidiot and JagLite like this.
  2. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    16,806
    Orange County, CA
  3. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    2,472
    Alaska
    villageidiot likes this.
  4. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    9,882
    Anchorage Alaska
    What are you going to build the rear subframe/seat/fuel tank out of?
    I don't have a spool gun to weld aluminum so I will have to use steel for my V-Strom project similar design.
    My plan is thin steel sheet over square tubes then coated inside with Caswell Sealer to (hopefully) keep the tank sealed when/if I dent it badly on rocks from a tip-over.
    AK650 likes this.
  5. tobiism
    Jun 28, 2011
    1,999
    Chandler AZ
    That's pretty much exactly how I plan on doing mine! LOL I even have the caswell at home
    AK650 and JagLite like this.
  6. JagLite
    Jun 17, 2010
    9,882
    Anchorage Alaska
    Hah! :beer
    I have the sealer also, but after reading in Steve's thread that Caswell has a shelf life and I thought I would be building it a couple years ago... :fpalm
    AK650 and tobiism like this.
  7. tobiism
    Jun 28, 2011
    1,999
    Chandler AZ
    More like Car-dookie. Mine won't be anywhere near as nice as a carducci
    AK650, JagLite, Webman and 1 other person like this.
  8. villageidiot
    Apr 29, 2010
    16,806
    Orange County, CA
    I’ve ogled the carducci bike a few times at the local progressive show. It’s insanity.
  9. AK650
    Jun 26, 2013
    2,472
    Alaska
  10. tobiism
    Jun 28, 2011
    1,999
    Chandler AZ
    Yeah the JD squared Bender is one of my favorite tools for sure. The Bendicator certainly helps LOL
    AK650, JagLite and Webman like this.
  11. tobiism
    Jun 28, 2011
    1,999
    Chandler AZ
    Received this shit show of a package from a seller in Canada. 20210429_184740.jpg 20210429_184712.jpg 20210429_184652.jpg 20210429_184640.jpg
    Unbelievably the 520 KTM forks were not damaged. The PDS shock and forks were dropped off to Futureshoxs in Phx to get rebuilt and revalved for trail riding.
    Fun tidbit, the KTM forks are a direct bolt in for the sportster neck.
  12. nostep
    nostep Been here awhile
    Dec 1, 2019
    245
    San Diego
    Glad they made it relatively unscathed. I just received a 530 front end from a seller here on Friday. A Sportster is next on the project list for me too. Looking forward to seeing how yours continues.
    Also, from your mock-up pic, it looks like you're going with a single offset WP shock on the left side.
    That exact thing was suggested to me recently when I was discussing this. Our concern was making the swingarm resistant enough to twist without making it weigh a ton.
    The big benefit in my mind would be the reasonable price and tuneability of the WP shock, but also it would clear the way for a tucked in high supertrapp or two on the right side. I really like the looks, but the right side shock is in the way.
    What swingarm and hub are you using?
    AK650, Webman and JagLite like this.
  13. tobiism
    Jun 28, 2011
    1,999
    Chandler AZ
    Yes, mounting it on the left. I am going to redo the swing arm as a trellis Style. I'll use Harley adjusters that have already been bored out 20 mm. That way I can use a rear wheel with 20mm axle. Probably a Warp 9 RMZ250 non cush 18" with 2.5" rim.
  14. nostep
    Dec 1, 2019
    245
    San Diego
    Very cool. Are you going to put the bracing on the top or bottom of the arm?
    Rectangular tubing or round because you have that sweet bender?
    I was planning on leaving the stock subframe and oil tank, so I'll probably have clearance issues to work out with the upper mounting.
    I'm starting to look for aluminum swingarm swaps, but that would probably be for version 2 of the rear.
    AK650, Webman and tobiism like this.
  15. tobiism
    Jun 28, 2011
    1,999
    Chandler AZ
    Sorry for the delay. I'll be bracing underneath with round tubing. Probably build the oil tank into the backbone and neck.
    JagLite, AK650 and nostep like this.
  16. nostep
    Dec 1, 2019
    245
    San Diego
    That's gonna be sweet. I'll be watching and learning.
    I'm hunting for one right now, but I'm hesitating because the Covid tax is in full effect out here. I really should finish the DRZ all the way before I get one, but I keep looking because I might miss the right sporty at the right price.
    JagLite, AK650, Webman and 1 other person like this.
  17. JagLite
    Jun 17, 2010
    9,882
    Anchorage Alaska
    Yep, you have to look everywhere, every day, and have cash on hand to get the super deals.
    Even then there is no guaranty, but you won't find one if you don't look. :beer
    tobiism, Webman and AK650 like this.
