Rally Navigator - Create Rally Roadbooks with Google Earth and GPS
Discussion in 'Racing' started by RenoMoto, Dec 29, 2012.
  1. RenoMoto
    RenoMoto Rally Navigator Supporter
    Jul 6, 2007
    465
    Sitting at My Computer
    wrk2surf likes this.
  2. wrk2surf
    wrk2surf on the gas or brakes
    Dec 16, 2007
    9,083
    THE exact center of California/Bass lake/Yosemite
    You cant.
  3. DAX_PL
    DAX_PL n00b
    Mar 20, 2021
    2
    Poland
    Hi there, have a little problem with an Rally Roadbook Reader.
    I installed this app on Android phone, login with same account as created on Rally Navigator web page.
    Successfully open a roadbook created by Rally Navigator.
    Today I tested it in the field, and app 3 times just reset itself.
    By reset I mean:
    - zero odometer
    - roadbook scrolled to the top
    First time it was at the begining of the track, I simply set the odometer to right number and scroll roadbook to required line
    Second time I've done the same but distance was longer so it took three times more time
    Third time it happened I was about 70km from the begining, I gave up :(
    So there are the questions:
    1. Is that common behavior of the app on Android phone ?
    2. Is there another way of increase km on odometer than press&hold upper section of it?
  4. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,604
    Thousand Oaks, CA
    Hi,
    I've been playing with the Track Tools and have figured out how split and join tracks. I've been able to add a track to the end of the original track without issues, but how do I add as segment before the start of the main track, essentially creating a new start point. The software does not seem to allow this.
  5. pierrejaune
    pierrejaune superannuated
    Apr 3, 2015
    182
    where buffalo roam
    You can't add to the beginning. Add the original track to the end of the new track.
    Looks like you and I are doing the same thing today.:-)
    rides2little likes this.
  6. Yellow Pig
    Oct 28, 2004
    9,604
    Thousand Oaks, CA
    Not so simple.
    This is what I'm trying / would like to do.
    I would like to split the original track at the back dot, then add a few km for a different start location and then connect the old finish to the new start.
    The new finish is easily done.
    Splitting the track, fusing the old start and finish together, then inserting a new start segment not so much.
    ...and I would like to keep the segment between the start and the split, without having to redo the tulips.......I know...lofty desires!
  7. Yellow Pig
    Oct 28, 2004
    9,604
    Thousand Oaks, CA
    Also, let's say your route is a loop with the same start stop point. Is there a way to link the start/stop so it's a continuous route and then split the loop in a different spot and make that the new start/ stop?
  8. pierrejaune
    Apr 3, 2015
    182
    where buffalo roam
    re: your before and after sketch, please draw the finished track showing the original start and finish as well as the new start and finish so I can better understand. Thanks.
    PJ
  9. pierrejaune
    Apr 3, 2015
    182
    where buffalo roam
    Yes, first you must split the track, then put it back together the new way.
    start with the new beginning then add each section at the end until you get to the new end. But still can't join the beginning and the end.
    PJ
  10. Yellow Pig
    Oct 28, 2004
    9,604
    Thousand Oaks, CA
    Yup, that's what I'm doing, it's just a lot of busy work and time consuming, but it gets it done.
  11. DaveRMS
    DaveRMS Long timer
    Jul 20, 2005
    1,480
    Mossyrock, WA
    IIRC, only "Pro Rally" subscribers can do that (event organizers). You set that up at the folder level inside "My Routes". For more than that, perhaps just append a page to the beginning of the PDF using your favorite PDF software.
  12. DaveRMS
    DaveRMS Long timer
    Jul 20, 2005
    1,480
    Mossyrock, WA
    Hi Dan. New version (out soon) will have some easier track tools.
