Rally-Raid Products Honda CB500X
Discussion in 'Vendors' started by ktmmitch, Sep 22, 2014.
  1. JMo (& piglet)
    JMo (& piglet) Unicorn breeder
    Apr 1, 2007
    8,902
    California
    Hi Gus - yes, that's right - the first three numbers relate to the spring rate.
    (for info. as I recall, the next three numbers are the free length in mm, TT is 'TracTive' and 44/16 is the week and year of manufacture/wind).
    Jx
    gus1911 likes this.
  2. AFKDX/KLR
    AFKDX/KLR 06KLR650,06DL650,15WR250R,14CB500XRR,02BMWGSA
    Aug 19, 2013
    67
    Savannah ga
    Do you guys have any more of the high fender brackets? If not do you plan to make them in the future? If not can you post the drawing and measurements so we can make our own.
  3. JMo (& piglet)
    Apr 1, 2007
    8,902
    California
    Hi AFKDX/KLR - no, those were only ever prototype parts (which I originally developed, not John and the team at the factory), and the [production] issue has always been that while the US gets a non-ABS model, most of the rest of the world get an ABS bike, which you can't fit a high fender to because of how the [hard] brake line is routed. There is also some specialise hardware required which would mean any production version would have to cost more than some people are likely to want to pay.
    Now the 2019 model has been introduced, the design of the lower triple clamp has also changed so the original bracket I developed doesn't fit on that in the same way either, and the ABS issue would still remain too.
    So my suggestion would be to get a fender (the Polisport SM-line supermoto fender is the most complimentary shape/design I've found) offer it up, and you'll see what needs to be done to fit the two together - a number of other people have done this themselves already, as the position of the fender is pretty obvious if you want it to clear the radiator.
    All that said, there is a reason most 'adventure' bikes have lower fenders - and that is they offer better protection to the front of the engine, better cooling for the full-width radiator [typically fitted to these kinds of bikes] and are less prone to aerodynamic issues at higher speeds. For the very few occasions where you might be riding in really muddy conditions where there is a chance of a low fender gumming up, it is easy enough to remove with a 5mm Allen key on the CB500X.
    Hope that gives you something to consider?
    Jenny x
  4. 32dgrz
    32dgrz Been here awhile
    Jul 7, 2017
    207
    Ankeny Iowa
    My bike was purchased with the kit installed.From what I'm told my kit is a very early one. The exhaust on my bike is kind of a custom set up I'm guessing because it was so early on in the development. I need to correct some of what they did because they utilized a muffler clamp to a piece flex pipe to connect to the existing factory pipe that they cut off. I've seen used header pipes on ebay for 40 bucks shipped and I will probably purchase one of those and get rid of the flex pipe. If it was me I'd buy what Rally Raid offers.
  5. JMo (& piglet)
    Apr 1, 2007
    8,902
    California
    Just to clarify, that exhaust is nothing to do with Scorpion or Rally-Raid, rather something the previous owner must have put together.
    Jx
  6. 32dgrz
    Jul 7, 2017
    207
    Ankeny Iowa
    Yes that was a end user choice and install.
  7. bobwombat
    bobwombat Adventurer
    Mar 22, 2011
    56
    Over Here/USA
    RALLY RAID PARTS?
    Curious to know if USA customers usually buy directly from Rally Raid or perhaps use Giant Loop's connection w/RR to order? Shipping to USA from the UK is rather steep & the GL prices reflect those shipping charges so I'm not sure the advantage of using Giant Loop.
    Would love a 2019 RR bash plate when they're available again but, with shipping, it's almost $350 USD or so; yikes.
    Being in the USA, I now have empathy for others around the world ordering parts based in the USA & having to pay crazy shipping.
    Thoughts from the Forum? Many thx in advance. Bob in AZ/USA
  8. 32dgrz
    Jul 7, 2017
    207
    Ankeny Iowa
    I’ve made a number of purchases from Rally Raid direct. Their customer service is remarkable and I didn’t think the freight was horrible. I found it quite amusing that on the same day I ordered my RR parts I placed an order from one of the large mail order companies. The RR parts beat the USA based company by a day. In my mind there’s no reason to buy their products from anyone else
  9. JMo (& piglet)
    Apr 1, 2007
    8,902
    California
    Hi Bobowombat - Giant Loop have not been a distributor/stockist of RR parts for quite a while now. They can still order you parts as part of a bike build for example, but since they no longer order in bulk there really are no shipping savings to be made, and those costs would have to be passed on to you anyway.
    As 32dgrz has reported, Rally-Raid ship quickly and efficiently worldwide from their UK factory - and yes, while bulky, heavy boxed items like engine guards and wheels have an appreciable cost to ship internationally [as it is based on volumetric weight], if you're ordering a number of other smaller components, RR will always try to reduce your overall shipping cost by combining smaller items in the same packaging as the larger components.
    Hope that clarifies things...
    Jenny x
  10. sscardefield
    sscardefield Adventurer
    Aug 13, 2016
    77
    Scottsdale, AZ
    Hi Johny, what windscreen are you running? It looks to be slightly tinted and larger than the OEM windscreen?
  11. Michona
    Michona Adventurer
    Sep 6, 2018
    13
    Denmark
    Thank you for that refreshing and thoughtful comment.
    This forum is educational in many ways and, at least to my mind, brings people (and bike parts) of all creeds together. Finding the best products seems easy if you have basic search/internet skills, while buying them appears to be the new challenge. Being an EU (Denmark in this case) consumer, I am continuously put down by the fact that a certain product is almost exclusively available from a distant distributor (often the US, obviously). I'll refrain myself from whining about such major sites such as Amazon and Revzilla, but instead, mention that a product such as Darn Tough socks (a blatant recommendation BTW) is, if you want something specific, only available to customers who know the ropes of indirect shipping and are willing to pay up to twice the US retail price :)
    Coming back to the this being a vendor thread on this forum. I would not hesitate to order parts directly from Rally Raid, if you believe this is the part you need (bash plate or otherwise) you would be dealing directly with the people that produce them. Reading this forum, you do not have to have an MBA to understand that neither Rally Raid nor Giant Loop make their profits on distribution or shipping, in fact we have the same problem/solution - RR=EU (Don't mention Brexit) Giant Loop=US (Don't mention Trump).
    RimBenty likes this.
  12. Johnytuono
    Johnytuono Been here awhile
    Aug 17, 2017
    287
    Hi
    It's a Honda OEM tinted screen and is in the 2019 parts catalogue. It's an optical illusion and actually the same size as standard.
  13. ktmmitch
    ktmmitch Long timer
    Sep 29, 2009
    1,648
    uk
    New design of double-ended hexagon bit, 17 & 19mm A/F, to suit both the older pre-2019 and new 2019 front wheel spindles, plus 24mm spanner for rear wheel nut, and we have also re-designed our other 12mm & 19mm spanner, to undo the front axle pinch bolts and hold the rear axle head.
    These are heavy-duty trail tools, and are a neccesity when travelling, no tools are provided in the OEM toolkit for wheel removal.
    [​IMG] [​IMG]
    http://www.rally-raidproducts.co.uk/honda-cb500x-wheel-spanner
  14. Cro59
    Cro59 Been here awhile
    Sep 27, 2015
    821
    Tucson, Arizona
    Are these beefed up from the original? I carry your first go, but they did have a tendency to bend.
  15. ktmmitch
    ktmmitch Long timer
    Sep 29, 2009
    1,648
    uk
    Yes, they are 25% thicker, now 5mm steel plate, but it is always best to undo the axle bolts in the workshop with a larger wrench, or socket, then tighten them with our spanners, as you don't want to wait until you're on the trail to realise the axle bolts are too tight !!
    maxcielle, Cro59 and Rob-Houston like this.
  16. tdela11
    tdela11 Adventurer
    Mar 18, 2019
    19
    Australia
    Hi all,
    I'm looking at getting a Honda cb500x with RR kit for a trip around the USA early next year. I plan on doing the doable parts of the TAT. As I'll be coming from Australia I will be buying the bike in the USA and looking to either buy one with a kit already installed or get one fitted over there.
    If the later, I was looking firstly at who ships in Rally Raid kits and secondly, either a space to work and fit it or ideally get a shop to fit it. I contacted giant loop who used to have RR in stock but they said they don't get it in anymore.
    Therefore I'm looking for any advice on the best way to get RR products for the cb500x in the USA and a place to potentially help me fit it. I'll be buying the bike in Arizona so a place in that state or in a neighbouring one is preferred.
    Cheer,
    Tam
    Oyabun likes this.
  17. danceswithcages
    danceswithcages Been here awhile Supporter
    Mar 17, 2009
    278
    Indiana
    Well, you can buy the kit directly from Rally Raid and it can be shipped directly to you in Arizona.
  18. Oyabun
    Oyabun 親分
    Apr 7, 2016
    719
    Budapest, Hungary
    I remember that I've seen one or more already upgraded bikes for sale on cb500x.com recently. Probably you could contact those sellers too.
  19. Wind_Rider
    Wind_Rider Been here awhile
    Mar 6, 2006
    977
    Idaho
    look in the Gear / Flea Market / Bikes section of this site and just search for CB500X. Also the AZ Craigslist. If you find one already built it will save you some time. In my own workshop with my familiar tools it took me a couple of days and about 4 beers to install the whole kit. If you are a skilled Moto mechanic it could probably be done in one day.
    If you have a few months to shop ahead of your trip you can likely find one ready to go. I sold my RR CB earlier this week and they pop up from time to time in the flea market.
  20. Brokenhorse
    Brokenhorse Adventurer
    Aug 31, 2019
    32
    Mountain west
    tdella11 pm sent
