Rally-Raid Products Honda CB500X
Discussion in 'Vendors' started by ktmmitch, Sep 22, 2014.
  1. Med.Jeeves
    Med.Jeeves Adventurer Supporter
    Jul 15, 2019
    13
    Carolinas
    @JMo (& piglet) and @Oyabun Thank you for the (super fast!!) replies! I'll tear the forks down again when the fork gaiters I ordered get in (from the UK) and replace the 10W with 5W (and to double/triple check the innards are correct). Going to keep riding it until then, because more riding is always better than less riding.
    I think my CB might have enough UK sourced parts on it soon to be registered as a citizen there. Or at least dual citizenship.
    Oyabun likes this.
  2. Oyabun
    Oyabun 親分
    Apr 7, 2016
    665
    Budapest, Hungary
    Mine also polished out last time, but will be under size next time so planned to do the same thing - making a sleeve from a properly sized stainless tube, press it together and set the final diameter.
  3. 32dgrz
    32dgrz Been here awhile
    Jul 7, 2017
    134
    Ankeny Iowa
    Just got my forks back from my friend the Suspension Guy. I handed him the pdf off of the rally raid website that says 10 wt. so that’s not correct? I’ve been happier
  4. markinthailand
    markinthailand Long timer
    May 12, 2014
    1,080
    Chiang Mai, Northern Thailand
    That would be great--both the bearing part numbers and the KTM part number. I think I've located a set here in Thailand, but not sure it will fit. I need the outside and inside measurements of the bearing. 27 mm outside is proving hard to find, depending on the inside dimensions.
  5. 32dgrz
    Jul 7, 2017
    134
    Ankeny Iowa
    Here’s the seal the numbers are pretty good to read on the seal thanks iPhone 11 A06AB0DA-5223-414B-AE0F-280DFF965EE7.jpeg 485BB758-3725-49FD-9446-87A7C01DA4C4.jpeg C2592BAF-F316-4891-9BDE-807692D2081A.jpeg 132CE3C5-897F-485B-8F0F-32D0DC734D9E.jpeg C510E06F-5681-439A-99C0-071BC4B0A926.png
    Manray likes this.
  6. 32dgrz
    Jul 7, 2017
    134
    Ankeny Iowa
    Here’s the bearing. I think the part number above is correct
    I used the all balls to measure and get mine from bearing house and gave the all balls back to the friend that loaned them to me. Wasn’t sure of the origin of those so I bought top name bearings. Not sure it makes a difference
    BAC5940A-E304-4F96-8C9A-C1F5ACA525E8.jpeg BC81188D-EFB3-4EF3-BC57-FB8D11BCF129.jpeg 37084931-578F-4E33-AB61-3CED17BC872F.jpeg EC9812FD-9B1A-46E4-8A3E-57DF9B8D8203.jpeg
    Manray likes this.
  7. JMo (& piglet)
    JMo (& piglet) Unicorn breeder
    Apr 1, 2007
    8,699
    California
    Like I said above, that is a mistake - it always used to be 5w, and it still should be.
    Jx
  8. JMo (& piglet)
    Apr 1, 2007
    8,699
    California
    Mark - to clarify, the KTM axle diameter is actually 26mm (the nut is 27mm) - I just measured one, and it uses a pair of thin spacers than bring the I/D (inner diameter) of the bearing out to 30mm - as per 32dgrz's photo above.
    As I say, any KTM dealer should have a front wheel bearing and seal kit in stock (I presume they sell KTM enduro bikes in Thailand?) and/or a dealer that sells MX/enduro parts, such as All-Balls should have a suitable pattern kit.
    Hope that sorts it for you...
    Jx
    manx16 likes this.
  9. markinthailand
    May 12, 2014
    1,080
    Thanks for this! Super helpful!
  10. markinthailand
    May 12, 2014
    1,080
    Thanks! That and the photos help a lot.
    The DID sell KTMs here, but the dealer went under last year, and it is all in a bit of a mess. I found a person on a KTM group on FB who has a set and has sent them to me. I'll check them when I get them.
    While we're at it, what about the rear wheel bearings?
    JMo (& piglet) likes this.
  11. 32dgrz
    Jul 7, 2017
    134
    Ankeny Iowa
    Honda for the rear
    Don't forget the oring
    I can take pics of those if needed
  12. JMo (& piglet)
    Apr 1, 2007
    8,699
    California
    The Rear wheel-bearings have always been the same size as the OEM Honda ones, as are the 2nd generation RR front hubs too - it was just that first year production that use the oversize KTM pattern front hub.
    Jx
    markinthailand likes this.
  13. markinthailand
    May 12, 2014
    1,080
    Great! Thanks.
  14. dirtytroll
    dirtytroll Adventurer
    Mar 9, 2019
    91
    Haugesund, Norway
    My wishlist to Santa Claus (Rally Raid Productions): Footpeg lowering kit to suit the RR-footpegs and my bike (2019 model). Has to be strong enough for off road.
    pegote, bmah, danceswithcages and 2 others like this.
  15. 32dgrz
    Jul 7, 2017
    134
    Ankeny Iowa
    So 10 wt out 5 wt in forks rebuilt.
    My friend, who is a suspension specialist did the work said the oil smelled like..something crawled in them forks and died,fermented, made a new life form, and died again.....
    I’m sharing some pictures of what we found
    Rod slider bearings (top) coating completely worn off. Piston (bottom) bearings not bad.
    Wiper seals cracked.
    LED winkers here and ready for install. Stay tuned.
    Currently waiting on fork boots from UK
    B026A72E-F5FF-4A6E-A3F0-BE5AE8AA4DDA.jpeg 09AD783F-59C2-48FD-AF7A-CD3704BA94B5.jpeg 5CDC3359-9839-438B-BF1F-7791ECBCE381.jpeg 70451389-5C71-4977-8902-0D2A60054FEF.jpeg
    Manray likes this.
  16. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    2,831
    Lost in the Sahara
    I saw 1 year old CB500X that had cracks on the dust seals, I was surprised to see how poor quality they were
  17. maxcielle
    maxcielle Been here awhile
    Mar 7, 2015
    197
    LX
    And I wish for a folding gear and brake lever.
    Tangor, pegote, dirtytroll and 3 others like this.
  18. Tangor
    Tangor Adventurer Supporter
    May 11, 2019
    13
    Mountain Home, Arkansas
    Just wanted to thank this great community and especially Jenny for the great discussion, material and wealth of information on the RR kit. Just finished up installing the L2 kit on the lightly used '16 I bought several months ago (<1500 miles). Waiting on the tubeless wheels and rear rack to make it over the pond. This has been a very fun project (except for those #$%# security bolts). Can't wait to get her out on the dirt tracks in our area.
    Xchemie, maxcielle and 32dgrz like this.
  19. Manray
    Manray Killing Time
    Jun 24, 2011
    429
    North America
    I hope you went the easy route with the security bolts by using a Torx bit. Any case, you're gonna love the CB with the spoke wheels.
  20. Tangor
    May 11, 2019
    13
    Heh, I wasn't that smart until I cut a notch with a chisel and they backed out. I found a new limit to my patience (the hard way).
