random road king thoughts
Discussion in 'Road Warriors' started by sshbsn, May 30, 2019.
  1. Kevm
    Kevm Eternal Optimist
    Feb 18, 2018
    5,716
    Medford, NJ
    I don't know about sumping, but since the oil breathers in the heads vent to the AC on stock set-ups, any sudden pressure in the crankcase (including but not limited to a catastrophic failure) could cause oil to be sprayed out the breathers and AC.
  2. rd400racer
    rd400racer Long timer
    May 14, 2013
    5,450
    Louisville, Ky
    But wouldn't that have shown up on my 200 mile ride two days earlier? I checked the oil multiple times after the change last week and it was always perfectly in the middle.
    Traxx likes this.
  3. rd400racer
    May 14, 2013
    5,450
    Louisville, Ky
    The oil definitely came out of the air filter. Did some reading trying to make sense of this. Maybe I did fill it too much but it sure didn't show on the dipstick. The level now is right at the low line. Some people said it can be revving too low around town doesn't create the proper vacuum. Others say make sure your air filter is decent ( mine probably could use a new one). Bike seems OK other than that. Still haven't fired it up (going to do Kev's trick) but hopefully this is just a goofy anomaly. Any other thoughts?
    Pulled the plug, engine turned over fine. Fired her up and she started like normal. Rode to the end of my driveway and it felt like it had no power
    Traxx likes this.
  4. shupe
    shupe Long timer
    Oct 15, 2010
    1,056
    Northeast Tennessee
    Traxx likes this.
  5. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    16,346
    Orange County, CA
    Best i could do.
    I don’t really pay too much attention to fuel mileage/calculations, but the gas certainly lasts longer at speeds sub 70mph, which is where I’ve spent the last couple days, mostly below 70mph.
    Jed Clampett and Traxx like this.
  6. Laconic
    Laconic .
    Sep 28, 2007
    29,397
    NCNC
    RD, hope it turns out to be something simple.
  7. 72 Yamaha RD350
    72 Yamaha RD350 Followed the Wrong God Home Supporter
    Feb 20, 2017
    1,823
    Lake Wobegon
    @villageidiot: I duplicated your mileage this weekend on my MN1000 rally ride. IIRC, after one long blast up the interstate the range at my next fill up was R=204.
    villageidiot and Traxx like this.
  8. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    16,144
    the hills
    Codes? What do the plugs look like? WHen starting does it turn over faster than normal?
    Traxx likes this.
  9. rd400racer
    May 14, 2013
    5,450
    Louisville, Ky
    No clue on the codes. Plugs had a bit of oil on them but weren't soaked. Started about like it typically did, but when I took off I could tell it was seriously lacking power.
    That was with the air filter completely off, and as I was checking all around the air filter I noticed that the two rubber lines that exit from the engine into the air filter were totally shot.
    Traxx likes this.
  10. anotherguy
    Jun 18, 2009
    16,144
    the hills
    1.)Replace the plugs and ride.
    2.)Replace the breather lines if #1 passes.
    Traxx likes this.
  11. rd400racer
    May 14, 2013
    5,450
    Louisville, Ky
    I'll give it a shot. The plugs were almost new and I sprayed them off with some electrical contact cleaner before I put them back in. I just watched a video on Harley breather venting...I had no idea they were so finicky due to that venting. I'll probably go ahead and get some new plugs on the way home and some 9/16 vent tubing while I'm at it.
    Traxx and Chuck Pryce like this.
  12. Laconic
    Laconic .
    Sep 28, 2007
    29,397
    NCNC
    First tank came in at 47 mpg. My old neck tension is back; haven't had that issue in a long time. Thinking about different seat options and upgrades for the shocks. I like the way the front suspension feels, fueling is very good, the motor runs quiet, the brakes work good and there's plenty of grunt. Much improved over my "09 Ultra, which was a decent bike. I had some flashing brake light modules left from my earlier bikes and while they plug in and work, they upset the security system. Have to look for alternatives.
    It was tough, but somebody had to do it today, perfect weather.
    ausfahrt, rauchman, marshrat and 6 others like this.
  13. anotherguy
    Jun 18, 2009
    16,144
    the hills
    If you have the means while the plugs are out checking the cranking pressure wouldn't hurt.
  14. shupe
    shupe Long timer
    Oct 15, 2010
    1,056
    Northeast Tennessee
    Low power indicates sumping, ie oil drag on the flywheels. What happened in the article I linked above happened to me. I changed the tensioner shoes, and when replacing the oil pump, it pinched the o-ring slightly. Mine never spewed oil like yours, but the low power had me baffled until I found that article. New o-ring fixed it. It's not that big a job to check it.
    Not sure of other ways twin-cams can develop a sumping problem, but I suppose there are some, although over-filling is one.
    Traxx, rd400racer and Blakebird like this.
  15. hyena
    hyena Long timer
    Jan 10, 2005
    1,146
    Central Illinois #1 state for corruption
    Somebody else had to do it today, too. Yesterday I drove up to Chicago to pick up my best friend and his daughter at Midway Airport. I hate Chicago. So to get the stink off me today I rode up the Mississippi River for lunch. Opposite side of the state, and Poopy's Biker Bar is about as opposite of Chicago as it gets.
    ausfahrt, rauchman, Traxx and 5 others like this.
  16. 72 Yamaha RD350
    Feb 20, 2017
    1,823
    Lake Wobegon
    @hyena: Gorgeous RK. I was in Savannah in 2019 - must have ridden right past Poopy's without noticing.
    Traxx and hyena like this.
  17. villageidiot
    Apr 29, 2010
    16,346
    Orange County, CA
    not on a RK, but i got home a couple hours ago from a 3 day, 1140 mile lap around much of CA.
    perfect weather 3 days, some HOT 105° moments in certain parts of the state.
    rauchman, MiltonHog, Traxx and 8 others like this.
  18. Oilhed
    Oilhed MarkF Supporter
    Oct 17, 2003
    16,625
    Connecticut
    Not a RK? Close enough!
  19. villageidiot
    Apr 29, 2010
    16,346
    Orange County, CA
    its as bare as an electra glide comes
    Traxx and Kevm like this.
  20. Oilhed
    Oct 17, 2003
    16,625
    Connecticut
    EGS is an honorary RK.
    Our two bikes look like twins.
    Traxx, rider33, Kevm and 1 other person like this.
