First, there's no way that will illuminate the dot on your crank pulley, which is the entire purpose of a timing light. 2nd (and more importantly) I like to fuck with shit. If you don't like to fuck with shit, HF (and thus this thread) probably ain't for you.
Because you can?.... you don't have to look at it directly either. It is bright enough to make shadows.
I like to fuck with shit, probably more than you do, but I don't like wasting time. And the static timing light isn't for illuminating the dot on your pulley. Plus the circuit can be used for a lot of other things.
If you take the time to look back to the original post hacking a free light you'll read about using the light as a STATIC timing light. That means not on a running motor/"crank pulley" but rather the moment the points open (the light goes OUT) while slowly turning the points plate with the crank pulley dot lined up with the fire timing mark/engine off.
My friend's press like like totally shattered an alloy water pump housing like a Claymore mine going off, pieces blew all over the shop. So, I don't think that a walnut is much of a challenge.
It would be funny though if a walnut killed it. With the inconsistencies of Chinese manufacturing, one never knows. I am sure it will be fine and give many years of cracking walnuts... oops, pressing bearings.
Sounds like it's basically a visual alarm continuity tester for any non-powered circuits. That 6/12v Circuit Tester is only good for live circuits within it's voltage rating (I suspect anything more than 20v will burn that bulb). I guess if you couldn't use your multimeter/didn't have one/were in an environment where you couldn't hear a faint beep/or were deaf it'd be solid substitute for using a multimeter.
There’s a guy on eBay that sells a plastic knob for the pressure relief valve for $10 https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/273946921951
Maybe. I did use it. I replaced the bars on my KLX and my handguards were all bent up. It works enough to do that. Makes a great vise too. I couldn't find any walnuts.
DIY? Probably took me less that 10 minutes to pull the valve,remove the O-ring and braze a jig knob on that.
The light with the alligator clips is way easier imho. Hands free and you cant miss the bright light during adjustment.
I used my press not twice. Once to straighten my handguards, not a problem for it. My son needed a wheel bearing in his Mazda. Since the hub is too big to fit down through the bed of the press (doh!) and I didn't have any big chucks of steel that could hold the carrier up high enough to press the whole mess out, I had to do it the old fashion way, 2 big bricks, torch and a hammer. It came out with about 5 minutes of hits with a 2 pound hammer. However I did press it back in. Not a problem for the press. I'm calling it a win on install.
i looked but didn’t see any posts here. anybody have one of these https://www.harborfreight.com/2500-psi-24-gpm-4-hp-160cc-pressure-washer-epacarb-62201.html if so, your review please
I have had two of these and i would not recommend it if the current ones are anything like mine were. The motor is fine, its the pump that is the issue. In my opinion its garbage. The first one i bought the pump vibrated itself apart on the first use ~30 min into cleaning my pool patio. I returned it and the second one finished that job but failed in the same spectacular way when i was washing my house. The killer is it only has a 90 day warranty and i was like a week past that when the second one failed. I made a mistake and did not get the extended warranty, I went to the store and called HF customer service to see if something could be done to no avail. I ended up tossing the thing at my town recycle center. After that experience i wanted something reliable and ended up getting a Dewalt 3400PSI (made by Simpson) at home depot at the recommendation of my cousin who uses one professionally in his paint company. It was double the money but i have put a lot of use on that one without a single issue in 3 years. It is a much stouter unit with a rebuildable Simpson pump that is oil lubricated and a Honda motor.
thx. a former coworker started a power washing business a few yrs ago. he told me to just get one on sale. he claims to have as many problems with the high dollar ones as he does the cheap ones. but then the word maintenance isn’t in his dictionary
I suspect you are right on the lack of maint issue. He sounds like a friend of mine that has a use/abuse it till it breaks then complain mentality. He has zero understanding of the concept of maintenance. I feel like this pressure washer is a different thing entirely. The two i had never worked long enough to require any sort of maintenance. For the amount of time i got out of them it cost me ~$5 a minute to use them. My Dewalt on the other hand, change the oil in both the motor and pump annually and put anti corrosion stuff in the pump when im not using it for awhile. Thats all i have done and its been flawless.
Anyone have one of their titanium brand welders? Kind of want to buy a welder eventually. They have good reviews.
