You need one of these... https://www.harborfreight.com/front-wheel-bearing-adapters-63728.html I worked my ass off for hours trying to replace the wheel bearing on my son's Jetta, to no avail. Bought this set (or one very similar) for $60 and had it pressed out and the new one installed in about 30 minutes.
The anti corrosion stuff really helps the pump. I use it every once in a while on my Yamaha Pressure washer that has a Cat pump. The pump will start to act funny. I put that solution in and it works great again.
Have it. They won't remove certain bearings due to the hub not coming out, like my kid's Mazda. Works like a champ putting them in but if you have the knuckle off, the press is much easier.
Yes, recently bought one, posted about it here: https://advrider.com/f/threads/rate...ool-experiences.752036/page-203#post-38455776 and here: https://advrider.com/f/threads/rate...ool-experiences.752036/page-203#post-38456779
Can anyone tell me if the air compressor rated to 150 psi will actually put out that much pressure? I need to be able to inflate my truck tires to 110. I have a 26 gallon HF compressor that won't quite do it. I don't remember what it was rated, and when I bought it I didn't need that much pressure. TIA
I picked up one of the glue-type dent pullers a month or so ago for about $16. I wanted to pull the dent on my Nighthawk tank before I put it up for sale. (I had a $400 estimate from one of those paintless dent removal places - I don't think so). It worked perfectly. You'd have to look really close to see it had ever been dented. So I ended up trading the Nighthawk for a 1985 XL350R. Decent mechanically, but the tank was pretty dented (though super clean inside). Pulled the big dents on that tank too with no problems. It did finally break, but I still got a spare glue gun out of the deal, so I was totally pleased with the purchase. The Apache cases are a great value. I decided to use them as panniers and a top box for my V-Strom. Modified my Givi mounts for them and the cases are far sturdier than the Givi/Kappa bags I had before. And if one breaks, it's only $50 to replace. I highly recommend - PASS.
IMHO it's a solution looking for a problem. Instead dragging out my soldering iron, disassembling the light, cutting a wire I had to buy anyway, soldering it in and then having this thing that only checks the timing is a fantastic idea from the peanut gallery here instead of having a tool that can check trailer wiring connections, wiring harness connections by sneaking in behind the plug, pierce wiring insulation if you really have to, etc, etc. If you want hands free, hook the alligator clip to the damn end of the tester. Not everything you see on Youtube is genius.
^ Shout at any clouds today? I bet you're fun at parties. Jeez, dude. Test circuits with whatever floats your boat. Who gives a shit?
Any reviews on the Toolcart? https://www.harborfreight.com/30-in...iMTk5Ljk5IiwicHJvZHVjdF9p ZCI6IjEyNDIxIn0=
Thanks for the info on the dent puller. I hadn't seen any reviews for using it to pull tank dents before (maybe I'm just sheltered), but glad to hear that it worked out. I suppose the dents were in flatter areas, not on the "high crown" curves?
Go back a few pages and you will find plenty..... Ill give you the cliff notes. Its awesome..... Yes i own one ( red series 2) and i have the optional shelf too. Very happy with mine.
I've got one, (in KTM orange of course) and it's a very good toolbox. I've got it full of tools and push it all over the factory where I work. Like the others said, get the side shelf. My only issue is that I paid $239 for mine and the price is now $199
I have a yellow VFR which is a one year only color. Kinda hard to find a tank in good condition cheaply and then get it shipped, so I'm going to try one of these. Several years ago I had installed a Penske shock and hadn't set the ride height correctly. I had to get off the bike on the rhs and as I did, my foot caught the tail end and the bike slooooowly fell on the rhs. I had a big magnetic tank bag that was sitting on top and one of the magnets put a dent in the tank as a result. I'm still frustrated at myself every time I think about it and would like to remove the dent. Fortunately or unfortunately, now that this might work, pdr guys have all said they can't fix it. I'm going to give this a shot.
I have 2 in my shop. Both with end cabinets and work shelves on them . Work great. Those are the go to work stations for the crew here. https://www.harborfreight.com/145-in-blue-end-cabinet-64450.html One of the best purchases we have from HF. (Had we know we were going to hang work cabinets on them, we may have just bought more 44" cabinets - we have several of those too.)
Kind of thinking of this one but right now I have a shitload of projects. https://www.harborfreight.com/mig-140-professional-welder-with-120-volt-input-64804.html
The one on the NH was right on the side of the tank. There were several on the XL350. One on each side and a few smaller ones around. It won't take out the little ones on the pointy part of the tanks, but overall, I was really impressed.
Here is an upside to HF stuff I never considered. Several years ago I bought the folding engine hoist and engine stand to do a Cherokee engine swap. Which went perfectly. The $200 pull and pay motor was perfect. Lately I have been decluttering my garage. So I put them on CL for like $20 less each than I paid with coupons. They sold in an hour to somebody doing the same thing. That is actually significantly cheaper than renting tools given the project took three weekends. Fittingly, I put the cash in my China bike fund in case I ever decide to go all in.
