Rate your Harbor Freight Tool Experiences!
Discussion in 'The Garage' started by JimVonBaden, Dec 28, 2011.
  1. TurkeyRun
    TurkeyRun Been here awhile Supporter
    Nov 25, 2012
    820
    Northern California, USA
    Dead after 1 year of use as a shed light.
    Fail
  2. JimVonBaden
    Feb 11, 2005
    91,757
    Alexandria, VA
    SmittyBlackstone likes this.
  3. TurkeyRun
    Nov 25, 2012
    820
    Tried that.
    SmittyBlackstone and JimVonBaden like this.
  4. Mucka
    Mucka Been here awhile
    Jan 10, 2006
    613
    Orrville, Ohio
    No it doesn’t. It goes 19+ but not 20+.
    Coma likes this.
  5. HapHazard
    HapHazard Be Kind - Rewind
    Dec 30, 2009
    5,460
    Central CT
    Probably the switch, then.
    It's the Achilles Heel of all the free flashlights, and the only moving part...
  6. jb882
    jb882 13HP of fury.
    Aug 5, 2014
    1,188
    Peoples republic of Taxachusetts
    NurseBill, ydarg and HapHazard like this.
  7. kenstone
    kenstone worn out
    Mar 3, 2013
    1,927
    Boysee
    18 Gauge Combo Nailer/Stapler... a BIG pass [​IMG]
    I have 2, and bought the 2nd one with a coupon for way less than $24.
    https://www.harborfreight.com/18-gau...ler-68019.html
    Initially finicky as a nailer, until I found out it needs to be run WET, oiled/lubed everywhere.
    Because it's a combo stapler, it leaves a wider dent in the wood when shooting braids/nails.
    I bought a 2nd "gun" because I often changed nail lengths when building something and it's easier to have 2 setup with different lengths.
    I had some concerns when I recently put some staples thru one gun.
    Staples are epoxy coated, the nails are not, and I thought that would be a problem.
    The epoxied staples ran as smooth as the nails [​IMG]
    I used finish nails for small wooden project before I bought these nailers, now things go way faster...
    DeepBarney and HapHazard like this.
  8. JimVonBaden
    Feb 11, 2005
    91,757
    Alexandria, VA
    I forgot that I also have this one. I like it as well.
    kenstone and HapHazard like this.
  9. NurseBill
    NurseBill Been here awhile
    Aug 20, 2017
    958
    Central PA
    Ok I used the oscillating tool to plunge cut a bunch of outlets. 2 in thick paneling and 1 outside outlet that I had to plunge through: T1-11, old tounge and groove panels, shingles (yes my house is old enough that it had shingle like siding) and the original wood siding. It plowed right through everything without a hitch. I did kill the blade that came with it. Big pass.
  10. gmiguy
    gmiguy You rode a what to where?
    Oct 17, 2006
    1,768
    Western NC
    The HF roll of double-sided hook/loop tape is very handy:
    https://www.harborfreight.com/3-4-quarter-inch-x-35-ft-roll-hook-and-loop-cable-strap-96217.html
    Good holding strength, resistant to wearing out, and you can cut it to exactly the size you want.
    I started using it at work to hold instrumentation and insulation in place, and now always have some in my garage tool box and a roll in all my vehicles.
    Their aluminum tape is good but not great:
    https://www.harborfreight.com/2-inch-x-50-yard-flame-retardant-aluminum-foil-tape-96372.html
    It's not quite the same as proper industrial grade aluminum tape, which (to be fair) is a genuine miracle product.
    It is much better than the aluminized mylar tape that I've found at other big box stores, which as far as I can tell is basically garbage.
  11. Lil' Steve
    Lil' Steve PussyWagon™ Chauffeur Supporter
    Oct 3, 2006
    6,092
    Gilbert, AZ
    Good for all the items that are typically excluded from the coupons like tool storage, welders, generators, jacks/lifts etc.
  12. Houstrom46
    Houstrom46 Been here awhile
    Dec 3, 2017
    172
    Houston
    I bought an aluminum racing type floor jack from them in 2006 and still using it to this day. No leaks and pumps up nicely. Only issue was the rubber pad came off a few years ago. Glued it back and was back in business.
  13. MotoChris521
    MotoChris521 motominded
    Aug 30, 2007
    3,240
    south west
    Black Friday coming up! Going to pick up some of those led shop lights and some other shit.
    racer1735 and Rippin209 like this.
  14. rdtrvlr
    rdtrvlr Long timer
    Oct 4, 2007
    1,089
    good luck our store sells out of them within hours of unloading them from the truck. every time. since they opened in sept
  15. MiteyF
    MiteyF Long timer
    Jul 23, 2010
    2,679
    Bay Area
    I still have about $100 hanging around on a HF gift card from a few months ago, I guess I better figure out what to spend it on and get my 15%
    racer1735 likes this.
  16. victor441
    victor441 Long timer
    Jul 27, 2009
    2,808
    Sonoma Co., Calif.
    Bought the $24 MC wheel cleaning stand yesterday and it works OK so far...handy for the stated purpose on bikes that lack a center stand and for rotating the tire valve to the optimum position on wheels that are difficult to air up.
  17. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    3,678
    I was trying to decide between the us general or husky tool boxes. Think I am going to get 44in us general stuff today. Thanks for the posting.
    Lil' Steve likes this.
  18. Rich B
    Rich B Long timer Supporter
    Apr 10, 2010
    4,507
    Stone Creek, OH
    I went with the US General 44" set last year. I don't regret it a bit. I am quite pleased with the set.
  19. greasyfatman
    Oct 18, 2014
    3,678
    44x22 double stack tool box, saved about 140. Little over 700.
  20. racer1735
    racer1735 Long timer
    Dec 30, 2005
    1,415
    Amarillo/Canyon, TX
    At the risk of semi hijacking this thread ( but it does pertain to HF), has anyone ordered parts for their harbor freight motorcycle lift, or can someone point me in the direction of where I might find a replacement part? I was going to check the oil level in the cylinder on my lift last night and the rubber plug had dried so much it tore in half ( The table is 10 years old and has worked flawlessly).
    I left the bottom portion of the plug in the cylinder so that I wouldn’t lose oil until I found a replacement. Didn’t know if it was worth trying to order the little piece from HF, or where I could find search the rubber stopper .
