Bought one of the Earthquake XT ratchet wrenches about a year and a half ago. It has worked fine so far through medium duty use. It can be a bit bulky in some uses but easier to manipulate than it's air powered cousin. It is also easier on the wrist for removing/snugging bolts than a typical ratchet wrench. I think the key with most tools is using it in the right applications and not (overly) abusing them. The only downside I have found so far is not having a second battery. Might pick up the polisher as others have mentioned this spring to alleviate that issue.
I wasn't sure how much I would need one, but it would help for one job I was doing. After watching a few reviews and videos I bought a https://www.amazon.com/Cordless-Electric-Variable-Lithium-Ion-Batteries/dp/B07X37XMX3 though when I bought it, it was $60 and it worked fine so far for me.
I bought a set of the aux LED lights and the wiring harness and fabbed up a couple of mounts for my DRZ. With the coupon I was all in for less than $70. Been on there for a short while and maybe 2000 miles without issue. Compare that to Denali and it is a no brainer. Tractor Supply sells the same setup but no coupons. I like HF for some things. I stay away from their wrenches, sockets, pliers, and other important tools but for things I only need once in a while they are fine.
I can't speak to the HF version but I have a Milwaukee M12 3/8 ratchet and I don't wrench without it if I can help it anymore. The HF one looks like a carbon copy.
Picked up a compact bender last week and finally got a chance to bolt it to the floor. I sunk 4 - 1/2" steel anchors into my floor. I must have jacked the one up since only 3 would line up. No matter, 3 is holding it good. The instructions are ok for putting it together but are useless for setting it up for 90 degree bends. I downloaded the Grizzly manual for it, same bender... different instructions. At last the Central machinery shows you how to make letters. I'll give it a pass but I haven't used it much.
I bought a tube bender last Sunday also. I'm in the process of building my garage so it will not be tested for awhile. I'm anxious to hear how well it works for.
Mine won't do tubing unless I get different dies with a round slot in them. It'll do round, square and flat stock. I did play with some scraps of 1/8" flat stock I had laying around.
I waited till this was on sale 1 ⅛ chuck, SDS bits. I’d been planning on moving my tire changer outside. Went through the concrete like butter. It has drill on and off same with hammer function to give you options. Pass.
I bought one for work, it doesn't get used frequently but the times it does it's given a real hot supper, so to speak. It's been great. I give it a pass and a serious recommendation for any in the market.
Have one of those as well. Did the same to mount my No Mar. Next up will be using it to cut down the hearth at my fireplace to open up options for some Jotul wood stoves.
The cheap $9 4 1/2" grinder. Cheap enough that I bought 2 so I don't have to change out the cutting wheel for the flap disc.
I've got about 6 of those. Cutting discs. Flap wheels, grinding stone and wire brushes. Easier to plug in another grinder than it is to swap wheels! Haven't had a problem with any of them. Oldest is probably 15 yrs.
I've had to fix both cords on them. The strain relief broke and the wires broke. The other one caught the cord while it was winding down and cut it. Easy fix for both.
Wait for the sales and use your coupon! Also after buying a few of those, at least I can find the stupid wrench when I need to swap worn out wheels.
