RATEL engineering design - BMW 650GS/Dakar/Sertao YZ/WR suspension upgrade
Discussion in 'Vendors' started by Aquatic, Feb 3, 2014.
  1. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Buddina, Sunny Coast, Australia
    :thumb:thumb
  2. GrizzLee
    GrizzLee RubiKon Adventures
    Mar 15, 2010
    1,341
    Pacific NorthWest
    Craig,
    Maybe you could include a paint can and a stuffed Kangaroo with your orders.
    :hide
  3. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    :lol3:lol3
    I have in the past sent Kangaroo Scrotum money pouches as gifts
    :jack:jack
    GrizzLee likes this.
  4. Burner25
    Burner25 Been here awhile
    Sep 10, 2019
    165
    Manchester
    Hi
    I’ve , read through this thread, and it does go back a few years so I’ve a quick question.
    I’ve a set of wr 426 forks which I will be setting up in the summer. I’ve been offered a Yamaha excel rim , which are much easier to source than making up an excel bmw rim!
    I know the smaller braking system was a point of debate, so a few years on . Has anyone just used the yz/wr excell wheel and with what results?
    Did the ABS , bracket issue get sorted?
    If you can just drop a yam’ front end on , connnect the brakes and off you go , that’s a lot less messing about!
    And I mile cheaper!
    Like I say it’s a spring/ summer project, so I’m just asking,
  5. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    It is possible to modify the BMW disc to fit the Yamaha hub.
    Use a Ratel Caliper Hanger, BMW brakes and off you go.
    The argument against this is that you will need to modify the disc every time you replace it
  6. Burner25
    Sep 10, 2019
    165
    Manchester
    Thanks for the reply
    How do you modify the disk? What needs doing?
  7. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    You will need to machine the Internal diameter of the disc and ad 6 new screw holes.
  8. Burner25
    Sep 10, 2019
    165
    Manchester
    Is that so it fits the wr hub then?, so I’ll have to get a yz wheel and get the measurements for internal diameter and holes position!
    Thanks Craig
  9. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Exactly!
    You will need to use countersink head screws or button head screws.
    Std capscrews or bolts will not work
  10. Burner25
    Sep 10, 2019
    165
    Manchester
    Hi
    This is probably a idiot question but....
    I’ve been offered a yz front wheel, does it matter what CC 250/450, it comes off are they made the same strength?this is excel!
    So I’ll have a set of WR426 forks, yz front wheel!
    Going to get a bmw disk and adapt it as above,( thanks Craig).
    So I’ll just need
    Ratel
    Calliper bracket
    8mm neck spacer
    Horn and fender bracket
    Brake line
    Abs spacer/ bracket?
    Is that all I need to do the conversation?
    Many thanks!!
  11. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Hey Burner
    I can help you but.....
    Keeping the ABS will be an issue
    The ABS ring doesn't fit the Yamaha hub,
    however, I do have a design for a ring that will fit(the fingers are longer), but.....
    This is and unproven system and I'm not sure if the old style ABS brackets(I have 1 left) will work.
    My current ABS bracket is not an option.
    Also getting a custom ABS ring made will incur a minimum cost. About $80.
    Please give me a little time to see if I can get this to work.
    Please follow up in 2 weeks - craigkrantz@ratel.com.au
  12. BGumm
    BGumm n00b
    Jan 9, 2020
    1
    Denver Colorado
    Looks like Burner25 and I have the same plan over the winter. I have a 2001 Dakar I am planning on doing the swap. I was hoping the save the front week and brake/caliper and put those on a YZ front end. Aquatic, sounds like I would need your front kit, with axle, spacer etc. Also the bracket to modify the caliper placement for the BMW brake. Is that all? Do you have current stock of your products?
    Burner25, we should stay in touch on the progress of our projects.
    Thanks for the help, yall.
  13. Burner25
    Sep 10, 2019
    165
    Manchester
    Yes sounds good !
    I have a set of forks ,WR from a 2001, i was also going to get a 2013 yz 250 excel front wheel, but I’m not sure if it’s compatible yet?. But aquatic said it’s a bit fiddly regarding the abs and getting the bmw disk changed to fit the yz wheel. ( but it would be less expensive!)so I’m not sure if I’m just going with the axle kit, and caliper!
    I’ve bought a old set of top yokes and cut off the ignition bracket so it can be welded on the new set up!
    That’s as far as I’ve gotten so far!!
    I did fit a set of touratech progressive springs and race tech valves to the bike to see how it was , and it’s much better, but I’ve not tried it off road yet. I am on a ride tomorrow, so it might get tested then!!!
  14. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Please email me - craigkrantz@ratel.com.au
  15. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Next project
    KYB SSS closed cartridge forks conversion kit.
    Starting with @Adsun 's Husky Terra
    Elrikas, KayDubbya and Gravel Seeker like this.
  16. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Forks stripped off
    Rear suspension knuckle removed
    Neck bearings were absolutely fucked!!!
    A bunch of measuring, design and machining to do.
    All the conversion parts need to be redesigned
    Gravel Seeker and shortman like this.
  17. shortman
    shortman Beta 500 RS, X-Trainer 250 Supporter
    Jun 14, 2013
    1,473
    Cumming Georgia
    Will be very interested to see what bearings you choose to put back in there... Mine need to be changed now...
  18. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Boring out the lower clamp to take the new forks
    KayDubbya likes this.
  19. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    9,100
    Dreary old Norway, dreaming of adventures past
    Unable to play - video is set to private.
  20. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    And now?
    Elrikas likes this.
