RATEL engineering design - BMW 650GS/Dakar/Sertao YZ/WR suspension upgrade
Discussion in 'Vendors' started by Aquatic, Feb 3, 2014.
  1. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    9,077
    Dreary old Norway, dreaming of adventures past
    :thumb
  2. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Buddina, Sunny Coast, Australia
    First thing to do is fix the root of all the bearing evil. The hole in the spindle. Which ever engineer thought that was a good idea is a fickwit!
    Some 3M tape and problem sorted
    Gravel Seeker likes this.
  3. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Took a bit of effort but I managed to get the old bearing off without cutting it.
    I couldn't find any new seals, but the old ones are still in excellent condition so I'll reuse them
    New bearings - sourced locally
    High temp grease - because the oil is in the frame and the neck area can get quite hot
    greased up bearings
    In the press
    Lower bearing installed
    I didn't take any pictures, but the outer races were installed in the head.
    i used threaded rod and some made up spacers that fitted the races perfectly
    tkach, Gravel Seeker and Christoslazy like this.
  4. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    A quick test fit of the forks
    Headlight and handle bars all back together
    Dummy axle just to check
  5. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    I measured up the fork and and then redesigned the existing caliper hanger to suit the new dimensions
    I 3D printed the new caliper hanger to do the test fit
    Fits exactly as planned
  6. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Looking good so far.
    Next item of business is to redesign the suspension knuckle to raise the rear the same as the front
    I'm hoping to make an adjustable unit.
  7. Christoslazy
    Christoslazy Adventurer
    Aug 5, 2018
    48
    Thessaloniki
    Hello! What is the doner bike of this USD system? I am looking forward to doing the USD transplant on my DAKAR and I have been offered a system from a 2009+ KLX250S and another one from an Aprilia RXV 450! Any suggestions on which one to prefer according to the ease of the process and the performance? Do you offer any caliper hangers for these? Also do you offer any redesigned knuckle for the Dakar in order to raise the rear and increase the wheel travel (with the same stock shock)! Thanks!
  8. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    I think Kawasaki also use KYB.
    These off of a Yamaha yz450. Not sure what year.
    They are the SSS closed cartridge forks
  9. Christoslazy
    Aug 5, 2018
    48
    Thessaloniki
    OK, thanks! Yes Kawasaki forks are KYB for sure! Do you think it’s better to go this way instead of the more exotic aprilia way (48mm)! And what about the altered Dakar knuckle question? Thanks again!
  10. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    I cannot help with a conversion kit for the Aprillia.
    Raising the rear of a Dakar is done with shorter links.
    I have in stock
    Christoslazy likes this.
  11. Gravel Seeker
    Apr 27, 2002
    9,077
    will the shorter raising links level the rear with the WP forks as well? Think they're 930mm.
  12. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Not sure how much longer 930mm is.
    But the links will raise the rear ±26mm no matter what you do up front
  13. Gravel Seeker
    Apr 27, 2002
    9,077
    Does that mean the KYB's raises the front by 26mm?
    Stock is 890mm I think in which case the front has been raised ~30mm (I checked my notes and I've measured the WP's ca920mm from top to center axle (917-920 difficult to measure exactly)).
  14. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    I'm actually no longer sure how much the front gets raised. I used to know.
    If I recall, reducing the length by 25mm still gives you 25mm longer forks
    I will measure when i get a chance.
    I have 2 sets of open cartridge and 2 sets of closed cartridge
  15. Gravel Seeker
    Apr 27, 2002
    9,077
    Yeah, my WP4860 forks are 950-960mm long center to top so it's not unreasonable that the KYB's are around the same length.
    Aquatic likes this.
  16. shortman
    shortman Beta 500 RS, X-Trainer 250 Supporter
    Jun 14, 2013
    1,470
    Cumming Georgia
    @Aquatic
    Do you have the ability to lazer cut a replacement tone wheel so that the speed O can be calibrated? There is an old Cafe Husky thread:
    http://www.cafehusky.com/threads/tr650-speedometer-question.45888/
    That has a guy who had some made to correct his speed O error.... I have tried reaching out to him and all I get is crickets....
    Below is a picture of what his looks like... I only need the rear wheel one cause my bike doesn't have ABS.... The washers are to space it off the wheel. Please let me know....
  17. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Leave it with me
  18. shortman
    Jun 14, 2013
    1,470
    Cumming Georgia
    So does that mean you’ll make one (or more)? I’m sure I’m not the only one who wouldn’t mind correcting the speed o meter error.....
  19. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    :beer
    :thumb:thumb
  20. Aquatic
    Aquatic Long timer
    Dec 23, 2008
    2,747
    Now to test. From Saturday we are allowed to go for a ride. 50km radius from home:clap:clap:clap
    Natron and Gravel Seeker like this.
