Re-Grip used as grip wrap
Discussion in 'Equipment' started by squiffynimrod, Oct 5, 2013.
  1. squiffynimrod
    squiffynimrod maximum shrinkage Supporter
    Mar 23, 2010
    2,196
    Flatskatchewan
    I've had my eye on these ever since I saw them at the local Princess Auto, but at $20 each felt it was too spendy. A recent trip there found them being cleared out at $6.93 each, and an in-store special of 50% off the lowest price gave me two for $6.93. Score!
    So here's a little tutorial of the install on an 02 GSA.
    What's Re-Grip you ask?
    A do it yourself regripping material that shrinks down to a smaller diameter when the plastic inner core is removed. When I first saw it I immediately thought of using it on MC grips. Here's the website of the mfr:
    http://www.re-grip.com/
    It comes in 3 sizes, the middle size with the yellow core was perfect for my grips. Took off the handguards and bar ends and slipped the tube over the grip.
    Position the grip where you want it. They state you can't move it once it's on and they mean it.
    Pull on the exposed plastic end and it starts to uncoil from the opposite end, and the rubber shrinks down. I only pulled a bit out and then snugged the Re-Grip as close to the end as I could. A little more pulling and it's halfway there.
    Kept pulling until all the plastic coil was out and voila!
    Trimmed off the excess material with a utility knife, reinstalled the bar end and guard and it's done!
    The throttle side installs just the same, but needed a little more trimming for the throttle to be able to return smoothly.
    The rubber material they use is great for grips. Really grippy, great feel. The diameter of the grips increases a bit which I like. There is ZERO chance of these slipping on the existing grip, they shrink down and grab on tight. They seem to transmit heat from the heated grips well even though I didn't spend much time with the heat on. But I could feel the heat.
    Stupid easy to install, but you only get one chance. Make a mistake and you're buying another one, but it's so easy only a real moran would screw it up. If you're looking for grip covers I recommend trying these.
    davidji, mervingry and good dog like this.
  2. XICAQUE
    XICAQUE Q' pedo?
    May 11, 2009
    723
    Colorado Springs, CO Yes, we are full, move on
    Very nice dude! I am going to try this!
    :freaky
  3. JimVonBaden
    Feb 11, 2005
    96,269
    Alexandria, VA
    That is very cool! If the Grip Puppies doesn't work out, this would be a great replacement!:deal
  4. rtwpaul
    rtwpaul out riding... Supporter
    Feb 7, 2011
    5,565
    arizona
    if you like this you should spend a couple of bucks on some self amalgamating rubber tape, great for making grips at the exact size you want to fit your hand, and the more worn and warmer it gets the grippier it gets...just a thought
    i have used it on multiple bikes, a little dome in the middle reduces hand cramps like the old grips on British bikes
    link
    one roll makes about three sets of grips
  5. crea58
    crea58 Adventurer
    Oct 14, 2007
    90
  6. tlwood99
    tlwood99 Been here awhile
    Sep 30, 2009
    390
    Dallas
    subscribing to this thread; going to try the Re-Grip solution. Thanks for taking the time to post up Squiffy!
  7. XICAQUE
    XICAQUE Q' pedo?
    May 11, 2009
    723
    Re-Grip is bad ass. I have it on my 2014 and it rocks
  8. good dog
    good dog Been here awhile
    Feb 15, 2013
    227
    Hamilton, ON. Canada
    Princess Auto is the Canadian equivelant to Americas Harbour Freight or as close as it can be. I may have to take an extended lunch break today and see if our local carries this. Thanks for posting.
    #8
  9. BlackBeast
    BlackBeast Been here awhile
    Jul 7, 2006
    991
    Ontario, CANADA
    Great tip, thanks.
    #9
  10. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    6,501
    Central Minn.
    Well portrayed, I was not aware of that stuff.
    #10
  11. XICAQUE
    XICAQUE Q' pedo?
    May 11, 2009
    723
    Got mine at Home Depot. Special order.....
    #11
  12. zdc1775
    zdc1775 Been here awhile
    Oct 30, 2014
    778
    Alabama
    About how much did this add to the diameter of the grips?
    I'm looking to increase the diameter of the grips on my 800xc to approximately the size of 1" grips.
    #12
  13. XICAQUE
    XICAQUE Q' pedo?
    May 11, 2009
    723
    My calipers show 1.39 inches with the Re-grip in place.
    #13
  14. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    1,189
    Lanark County near Ottawa ON
    Just to thank the OP for drawing attention to this slick product and to pass along a tip of my own. I put a hose clamp around the end of the grip and over the Re-grip with the edge of the clamp positioned where I wanted to make the cut. The edge acts as a guide for the blade (I found that a sharp exacto blade worked great) to make a consistent cut around the circumference.
    #14
    Jetpilot5, Way and HighTechCoonass like this.
  15. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    21,241
    Canada's ocean playground
    Nicely done... I can't find it at Princess auto though.
    #15
  16. good dog
    Feb 15, 2013
    227
    Couldn't find it at my local PA either, they said it must have been a regional/provincial purchase. I did find it online at Home Depot Canada, special order about $15+ if I recall correctly. If they had been at PA at that sale price I would have picked up a couple and thrown them in the future use bin. At least we know there's a relatively cheap fix over BMW replacement grips.
    #16
  17. younger06
    younger06 Been here awhile
    May 6, 2015
    334
    Naas, Co.Kildare, Ireland
    I only came across this product in the last couple of days...... for the very purpose of recovering my badly worn GS grips.
    It looks like the product has never made it across the Atlantic.
    I would be interested in hearing from the guys that have used it on the heat transfer topic................... will my heated grips still be effective??
    Sent using hocus pocus........... boo!
    #17
  18. good dog
    Feb 15, 2013
    227
    I think there are few as of yet who have tried it yet but as @stiffynimrod states in their 1st post "They seem to transmit heat from the heated grips well even though I didn't spend much time with the heat on. But I could feel the heat."
    #18
  19. XICAQUE
    XICAQUE Q' pedo?
    May 11, 2009
    723
    Younger,
    I have it on my 2014 and they do work quite well with the heaters. Not an issue at all. I had to order mine with home depot as a special order as this is not locally stocked. Free shipping. Try amazon or fleabay.
    #19
    younger06 likes this.
  20. younger06
    May 6, 2015
    334
    Cheers for the reply. I take it that the yellow medium size is the one to use??
    This product might be worth importing for distribution through Europe.
    #20
