Rear Brake Switch
Discussion in 'Dakar champion (950/990)' started by snarley, Aug 11, 2012.
  1. snarley
    snarley Long timer
    May 24, 2008
    1,037
    Hello All,
    I own an 07 990ADVS which seems to have a problem with the rear brake switch. I just recently replaced the switch that goes into the rear master cylinder because the previous one wasn't activating the taillight. Now with the new switch in place, I've bled the rear brake and refilled the master cylinder with new brake fluid, but.. the rear brake will not activate unless I push down REALY hard on the brake pedal ???
    There's no leaks anywhere, no air in the system, nothing externally bent, or damaged ???
    Any ideas ??
    Cheers
    snarley
  2. norm67
    norm67 Adventurer
    Jul 1, 2010
    87
    BETWEEN UTOPIA AND TOTAL COFUSION
    do the brakes work? master could be bypassing internally
  3. Groundhog
    Groundhog Been here awhile
    Nov 7, 2005
    188
    Kansas Flatlands
    Same with my '07. I almost need to lock it up (or activate the ABS) before the light comes on. I also replaced the switch , bled the system, etc. Brake itself works fine.
  4. snarley
    snarley Long timer
    May 24, 2008
    1,037
    Yeah same, brakes are fine. must be the norm...
    Cheers
  5. Groundhog
    Nov 7, 2005
    188
    Kansas Flatlands
    I just tried yet another switch (not looking forward to getting rear-ended in traffic). This one is working properly.
  6. RobertMtl
    RobertMtl n00b
    Aug 18, 2019
    9
    Montreal, Canada
    Can anyone tell me the part number for the rear brake switch on a 950 adv, I believe it's the same as the 990. I was also told that I can buy a universal one as long as the thread pattern is right "
    M10(10mm)diameter x 1mm thread pitch)
  7. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,402
    Cremona, Italy
    Part number is 50311051100.
  8. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,136
    Mill Spring, NC
    Just for future reference, you can easily look up these part numbers at any online site that sells KTM.
    As for a "universal".... Im sure they exist but most likely won't have the correct electrical connector.
    #8
