Rear master cylinder size
Discussion in 'Airheads' started by Eduardocastrejon, Mar 16, 2020.
  1. Eduardocastrejon
    Eduardocastrejon Been here awhile
    Jun 7, 2018
    179
    Acapulco
    Hi
    Please help me with this
    Some months ago I rebuilt the rear master cylinder on my 81 r100rs, like always was hard to purge but is braking, i tried several pads compounds .
    But the rear braking is not enough for me
    From 81 and newers model the rear master cylinder size is 14.29 and older model are 15.87.
    The travel of the pedal is like 1/3
    With the bigger old style I supose that the pedal travel will be more like 1/2
    somebody tried this or another brand rear master cylinder, i supose a smaller brake master cilinder will be a better idea.
    My k1200rs have the same brembo rear caliper, same compound pads and the braking is far superior. (I believe 13mm).
    My caliper is already rebuilt, new stainlesshose line
    Thanks in advance for your advice
  2. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,713
    Drill a new hole in the lever for the brake rod 6mm lower than the original. You may need to file the lever a bit to make this work. Make sure that you haven't eliminated free play when you reassemble it.
    beemeruss likes this.
  3. mattcfish
    mattcfish R90X Supporter
    Feb 6, 2008
    769
    Bellingham, WA RAIN or shine
    A smaller size will give easier braking but longer travel.
  4. Eduardocastrejon
    Jun 7, 2018
    179
    Acapulco
    Do you have photos ?
  5. Eduardocastrejon
    Jun 7, 2018
    179
    Acapulco
    Thanks, my mistake
  6. Eduardocastrejon
    Jun 7, 2018
    179
    Acapulco
    Something like this, I supose that will have faster action, i already ask for other master cylinder but i will try this
  7. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,713
    Drill the hole in the lever you step on, not the one at the master cylinder. What you've done will give you less power, not more.
  8. Eduardocastrejon
    Jun 7, 2018
    179
    Acapulco
    Did you refer to brake handle lever ?
    #8
  9. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,713
    I guess I should have typed "brake pedal".
    #9
    robtg likes this.
  10. Eduardocastrejon
    Jun 7, 2018
    179
    Acapulco
    Yes, my mistake , brake pedal
    at this place (green dot) or oposite side ?
    #10
  11. Eduardocastrejon
    Jun 7, 2018
    179
    Acapulco
    Maybe here I have a problem
    I read that exist diferent brake pedal shapes
    I sent to polish mine and was changed for other bike
    My bike is 81 rear disc brake
    And the pedal that installed came from 80 with disc brake too ( ate at front -brembo at rear)
    #11
  12. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,713
    AFAIK, they're all the same. You should drill a little farther back than the green dot, and bit lower.
    #12
  13. Eduardocastrejon
    Jun 7, 2018
    179
    Acapulco
    Yes, its an imorivement
    Less pedal travel, brakes works sooner
    I can apply more force
    thanks
    Still is not a good rear brake
    We need an improvent here
    I suppose another type of master cylinder is enough
    #13
  14. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,713
    Replace the rear disc.
    #14
  15. kcoralj
    kcoralj Been here awhile
    Jun 5, 2016
    295
    Wisconsin
    Interesting, those are 9/16 and 5/8 inch.
    Strange they used those sizes for the rear and metric for the front.
    #15
    spokester likes this.
  16. spokester
    spokester Long timer
    Jul 9, 2013
    1,733
    SE USA
    If you have noticed the bleeder bolt takes an 11mm wrench then that's really 7/16 inch. Thank NATO for that!
    #16
  17. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,713
    That always amused me; BMW apparently couldn't bear to admit that they were fractional. When you get a new one now, they're a true 14 and 15mm.
    #17
  18. kcoralj
    Jun 5, 2016
    295
    Wisconsin
    It's quite common with hydraulic parts, U.S manufacturers have switched to metric prints but there's still a mix of metric and SAE fittings and spool valves are still 5/8 and 3/4 they're just called out as 15.875 and 19.05 mm on the print.
    I can't imagine why they called it out that way, front brakes and rear brakes must have been separate engineering departments.
    #18
  19. Eduardocastrejon
    Jun 7, 2018
    179
    Acapulco
    Aftermarket I guess like ebc or ferodo, are pricey !
    #19
  20. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,713
    I didn't think EBC worked as well as stock.
    I'm a little concerned that you want more rear brake. I barely use mine.
    #20
