Rear Spring KTM 990 R-2012
Discussion in 'Dakar champion (950/990)' started by jamie1, Nov 21, 2019.
  1. jamie1
    jamie1 Adventurer
    Feb 26, 2009
    61
    Hi All,
    Apologies in advance- suspension baffles me. I have read a number of threads but am still unsure what I am looking for....
    So I have an issue with the stock rear shock bottoming out. We do alot of two up riding heavily loaded, and on some very rough roads. I am sure the best option is to go to a suspension wizard and splash cash on a specific suspension setup. BUT I am looking for an alternative for now.
    On the stock rear shock on the R model, is there a "heavier" spring I can fit straight on for now, assuming the shock is otherwise in good condition? What are the options and where is the best place to buy in the US (ideally near SF as I have someone that can bring it over for me soon).
    Thanks in advance.
  2. jamie1
    jamie1 Adventurer
    Feb 26, 2009
    61
    Sorry...Near San Fransisco....
  3. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,792
    North of North Plains
  4. CC Ryder
    CC Ryder Adventurer
    May 7, 2013
    89
    Salty City, Utah
    Have you cranked up the pre-load on the spring? Crank that thing several turns.. Big black knob that folds out to make adjustments.. on the fly if you like.
  5. jamie1
    jamie1 Adventurer
    Feb 26, 2009
    61
    Yeah fiddled with the setup plenty. Other thing that is definitely making a difference is that I have the Rade underseat tank fitted, so lost some clearance there too. Not very comforting feeling a rear knobbly rasping against a fuel tank, whilst sending shock waves through your spine!
  6. gearheadE30
    gearheadE30 @LC8Adventures
    Jan 20, 2012
    2,292
    Indiana
    Put your passenger on the back and check sag with the preload cranked up. If you are in the 30-40% of total travel range, it's likely close enough. If your sag is okay, I wouldn't mess with the spring. The stock 150kg spring is pretty stiff to start with. Crank the high speed compression damping in a bit and add a few more clicks of low speed compression damping and see if that helps. Sounds like you are fighting damping as much as you are spring rate.
  7. Koen
    Koen Adventurer
    Aug 11, 2013
    54
    The Netherlands
    I found this video usefull to see what i had to do :)
    MOTOTREK :)
