Rear wheel binding when torqued
Discussion in 'Airheads' started by hairball29, Sep 20, 2019.
Tags:
  1. hairball29
    hairball29 Adventurer
    Sep 6, 2013
    97
    Atlanta, Ga
    Hi,
    I have a '72 R75/5 which after having a puncture repaired and the rear wheel refitted, started binding between the final drive and wheel flanges.
    I put the wheel on, the axle in and torqued to 33lb as the manual states and the wheel binds so badly it will barely turn by hand. If i slacken it, it comes back, but it's on the edge of being too loose at that point.
    This is new behavior, so I'm wondering if a bush, or washer or something was during the puncture repair, but I can't figure what might be missing when I look through the parts diagrams.
    Any clues would be appreciated
  2. Big Bamboo
    Big Bamboo Aircooled & Sunbaked Supporter
    Sep 29, 2010
    16,359
    Big Island of Hawaii
    Take the wheel off and look at the inside of the wheel where the axle goes through. There is a "top hat" spacer/sleeve that should be sticking out slightly proud of the wheel bearing seal. If it is missing, the wheel will bind as you describe.
    36 31 2 301 737 SLEEVE
  3. tlub
    tlub Long timer Supporter
    Oct 23, 2012
    2,738
    Madison, WI
    And it's easy for it to fall out under the wrong circumstances.
  4. hairball29
    Sep 6, 2013
    97
    Atlanta, Ga
    Thanks, guys. I just checked and that spacer is missing. It must have dropped out when i was transporting the wheel or when the guys were doing the tire. At least it's a simple fix.
    Thanks again
  5. Big Bamboo
    Sep 29, 2010
    16,359
    I should mention, there are two different lengths of that spacer available, depending on if you are running a wider than stock tire or not...
  6. ME 109
    ME 109 Long timer
    Jun 25, 2009
    8,679
    Albury Australia
    Does the /5 have different size top hats either side as stock? My 81 does.
  7. Big Bamboo
    Sep 29, 2010
    16,359
    Yep, there are three sizes available:
    36 31 2 301 737 SLEEVE - 10,7MM Wheel bearing thrust sleeve, right hand side, R50/5 - R100RT. Used if using an oversize rear tire (120/90-18).
    08 36 31 4 038 142 SLEEVE - 9,2MM Wheel bearing thrust sleeve, right hand side, R50/5 - R100RT. Used when using a standard rear tire (110/90-18). Also used for the swing arm bearings.
    For the left hand side, there is the:
    36 31 1 230 322 COMPRESSION RING aka Thrust ring, R50/5 - R100RT, R45 - R65, R80 - R80RT.
    ME 109, aptbldr and bmwrench like this.
  8. hairball29
    Sep 6, 2013
    97
    Atlanta, Ga
    Thanks again
    #8
