Reincarnating an 81 R100RS
Discussion in 'Airheads' started by theDQG, Oct 1, 2017.
  1. theDQG
    theDQG Been here awhile
    Jun 29, 2017
    149
    I am replacing the original RS bars with wide renthals.
    I've been lectured on the style of tires I picked for this bike which I have no problem admitting was far more about vanity and image than practicality. We'll see how it goes.
  2. boxerboy81
    boxerboy81 Stay Horizontal
    Jul 22, 2009
    3,736
    Melbourne, Oz
    Before you spend the $, are they 22mm bars? 7/8" don't work apparently.
  3. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    6,418
    Longmont, CO
    I put a wide tire on the front. Not real wide, just a little wide because I could get the tire I wanted in that size. I almost crashed the first time I made a U turn in town the handling was so funky.
  4. theDQG
    Jun 29, 2017
    149
    Beautiful weather today- finally yanked the bike out of storage and looking forward to working on it as soon as I finish wiring the virago project I'm working on.
    Unfortunately as I was wheeling the bike out, I noticed/felt a clicking which increased the faster I moved the bike. I have to think this has something to do with the final drive- anyone have any suggestions as to what I should check first?
  5. ME 109
    ME 109 Long timer Supporter
    Jun 25, 2009
    8,062
    Albury Australia
    Put it on the centre stand in neutral and rotate the wheel. Make sure the tranny is in proper neutral and not a false neutral. Select first and up to neutral. Still clicking? Where's the noise coming from?
    How many clicks per wheel revolution? 7 or 8?
    I have had a failed rear out put shaft bearing in the tranny that showed itself as a click in the final drive.
    theDQG likes this.
  6. ccmickelson
    ccmickelson MonoMania Supporter
    Dec 11, 2013
    1,989
    Fanta Se
    Check for a loose bolt where the drive shaft connects to the gearbox output flange. If there's a bolt floating around the rubber bellows it will 'click' when it hits the driveshaft u-joint as it rotates and increases with velocity.
    WRC51 likes this.
  7. Planetducky
    Planetducky Been here awhile
    Sep 22, 2014
    135
    Austin, TX
    Looking good! As long as you're happy with what you're doing, it's all that matters. I used the same subframe from D&O, just a different seat for my R65 build. Nothing was chopped up or detabbed and I kept all of the original parts. I have a build thread on archive here and the inmates seemed to be a little kinder to me than you. Regardless, I look forward to seeing what you end up with. Cheers! IMG_7870 (2).JPG
    theDQG likes this.
  8. Plaka
    Jun 19, 2010
    6,418
    Longmont, CO
    I like the white wheels. Black wheels just look heavy. Also the lack of the sily pipe wrap. That stuff is hard to maintain and rots the finish on the pipes. Good ol' BBQ black and respray them every few years and they always look good.
    Planetducky likes this.
  9. theDQG
    Jun 29, 2017
    149
    Thanks- unfortunately I have no way to check to see if it's in neutral. The clutch cable and shifter aren't hooked up. Would it be a good idea to temporarily mount the handlebar, clutch lever, connect everything up and check?
  10. theDQG
    Jun 29, 2017
    149
    That's a beautiful bike, and well done! Lucky you re: inmates. Not sure why my particular build has the inmates riled up more than usual. I ought to dig out the peace pipe.
  11. ME 109
    Jun 25, 2009
    8,062
    Albury Australia
    You just need the shifter on the tranny to make sure it's in proper neutral. Most likely is.
    You may also find that moving the shift a little without changing gears will stop the click. I did that with my bike a couple of weeks ago.
    theDQG likes this.
  12. Planetducky
    Sep 22, 2014
    135
    Austin, TX
    Lol! Maybe they care less about the little old R65 than your model. I'm sure you have thick skin, so press on sir!
  13. Plaka
    Jun 19, 2010
    6,418
    Longmont, CO
    the reaction you get may depend on where you start and where you end up. Hacking a nice bike into a me-too....
    Boxerbreath and ccmickelson like this.
  14. theDQG
    Jun 29, 2017
    149
    Just finished my Virago build- it was a fun one. It has all the motogadget bells and whistles, including the M-unit blue and I've enjoyed the benefit of controlling it offsite with my iphone.
    Still a build in progress, but I'm done with it for now as I want to ride it this season. Time to move on to the BMW.
    KildareMan and Cho_Matt like this.
  15. theDQG
    Jun 29, 2017
    149
  16. theDQG
    Jun 29, 2017
    149
    On the stand now.. I have to sort through the mess I got back from the "mechanic." There's a bunch of boxes I have to go through, and try to organize stuff.
    For each snide remark I receive on this thread, I will hack off a tab from the frame which is currently unmolested. You may consider that a threat.
    KildareMan likes this.
  17. Plaka
    Jun 19, 2010
    6,418
    Longmont, CO
    An 81 does't have much in the way of tabs. You should see what a mono has.
  18. theDQG
    Jun 29, 2017
    149
    Well I guess that doesn't allow for much snide remarks then.
    Today, I'll be making a plan of action for putting this bike back together. Since the battery and other accessories are going to be relocated, I'll have to replace the cables and wires, to make them long enough.
  19. Plaka
    Jun 19, 2010
    6,418
    Longmont, CO
    The hrn tabs are quite worthwhile. i made reversing brac,kets out of stainless t go on them to run the hrns reversed (sideways) so more sund would get out from behind the fairing.
    Turns out there is a ton of room under the tank for relays flashers, voltage reg, ignition, connectors. But you have to make a bracket (but no welding) and you need to make part of a loom, which is a bit most "builders" are terrified of.
  20. Carlisja
    Carlisja A wandering soul. Super Supporter
    May 29, 2014
    599
    Beaufort, SC
    That turned out great. I am considering the m-unit blue for my own build. Are you happy enough with it that you will use it on the R100?
